Kevin Yang has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/84231?usp=email )
Change subject: mb/google/dedede/var/beadrix: Add LTE only daughterboard support ......................................................................
Add FW_CONFIG for no port LTE skus, and probe 1A port in devicetree to match program.star config
BUG=b:364431483 BRANCH=firmware-dedede-13606.B TEST=emerge-dedede coreboot chromeos-bootimage flash and check boot log on DUT.
Change-Id: Ica5a2d6e19421b132a0bdbad77806a17e2c1ce69 Signed-off-by: Kevin Yang kevin.yang@ecs.corp-partner.google.com --- M src/mainboard/google/dedede/variants/baseboard/devicetree.cb M src/mainboard/google/dedede/variants/beadrix/gpio.c M src/mainboard/google/dedede/variants/beadrix/overridetree.cb 3 files changed, 5 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/31/84231/1
diff --git a/src/mainboard/google/dedede/variants/baseboard/devicetree.cb b/src/mainboard/google/dedede/variants/baseboard/devicetree.cb index cc2b66d..d0ed6f1 100644 --- a/src/mainboard/google/dedede/variants/baseboard/devicetree.cb +++ b/src/mainboard/google/dedede/variants/baseboard/devicetree.cb @@ -10,6 +10,7 @@ option DB_PORTS_1C 7 option DB_PORTS_1A_HDMI_LTE 8 option DB_PORTS_LTE 9 + option DB_PORTS_1A 10 end field STYLUS 4 option STYLUS_ABSENT 0 diff --git a/src/mainboard/google/dedede/variants/beadrix/gpio.c b/src/mainboard/google/dedede/variants/beadrix/gpio.c index 131cb96..2662e36 100644 --- a/src/mainboard/google/dedede/variants/beadrix/gpio.c +++ b/src/mainboard/google/dedede/variants/beadrix/gpio.c @@ -122,7 +122,8 @@
static void fw_config_handle(void *unused) { - if (!fw_config_probe(FW_CONFIG(DB_PORTS, DB_PORTS_1C_LTE))) + if (!fw_config_probe(FW_CONFIG(DB_PORTS, DB_PORTS_1C_LTE)) && + !fw_config_probe(FW_CONFIG(DB_PORTS, DB_PORTS_LTE))) gpio_configure_pads(lte_disable_pads, ARRAY_SIZE(lte_disable_pads)); } BOOT_STATE_INIT_ENTRY(BS_DEV_ENABLE, BS_ON_ENTRY, fw_config_handle, NULL); diff --git a/src/mainboard/google/dedede/variants/beadrix/overridetree.cb b/src/mainboard/google/dedede/variants/beadrix/overridetree.cb index 0554baf..0c911e0 100644 --- a/src/mainboard/google/dedede/variants/beadrix/overridetree.cb +++ b/src/mainboard/google/dedede/variants/beadrix/overridetree.cb @@ -141,6 +141,7 @@ register "enable_delay_ms" = "20" device usb 3.3 on probe DB_PORTS DB_PORTS_1C_LTE + probe DB_PORTS DB_PORTS_LTE end end end @@ -239,6 +240,7 @@ register "reg_irq_cfg2" = "0x00" device i2c 28 on probe DB_PORTS DB_PORTS_1C_LTE + probe DB_PORTS DB_PORTS_LTE end end end # I2C 5
