John Su has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/72870 )
Change subject: mb/google/skyrim/var/markarth: Override SPI flash bus speed ......................................................................
Add configuration to bump up the SPI flash bus speed from 66 MHz to 100 MHz for starting next phase.
BUG=b:267539952 TEST=None
Signed-off-by: John Su john_su@compal.corp-partner.google.com Change-Id: Id46201351780bb5bc05422ff36dad6972285690e --- M src/mainboard/google/skyrim/Kconfig 1 file changed, 17 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/70/72870/1
diff --git a/src/mainboard/google/skyrim/Kconfig b/src/mainboard/google/skyrim/Kconfig index 55b6ece..1d80bbf 100644 --- a/src/mainboard/google/skyrim/Kconfig +++ b/src/mainboard/google/skyrim/Kconfig @@ -158,6 +158,7 @@ hex default 0x5 if BOARD_GOOGLE_SKYRIM default 0x1 if BOARD_GOOGLE_FROSTFLOW + default 0x1 if BOARD_GOOGLE_MARKARTH default 0xffffffff help Minimum board version starting which the Override EFS SPI Speed
