Hello build bot (Jenkins),
https://review.coreboot.org/18985
Change subject: [WIP] mainboards/hp: Add HP Elitebook 8470p ......................................................................
The code is based on the code generated by autoport.
The EHCI debug port is between the DP port and eSATA port. It also has a serial port on dock, but I haven't used it for debug yet.
Tested and work: - memory: 0+4G, 4G+0, 4G+4G - Linux (Arch Linux with kernel 4.10.6) boot from SeaBIOS payload with native graphics init - WLAN - keyboard, trackpoint and touchpad - USB
Not working: - fan control - AC and battery status
(EC) blobs:
This laptop uses SMSC KBC1126 EC, and there are two blobs needed by it.
You can use the tools in util/kbc1126/ to extract them and insert them to the coreboot image using the following configuration:
-> Chipset -> Add firmware images for KBC1126 firmware
Change-Id: Icbc051e2272b8ea73627940db15a56901d737472 Signed-off-by: Iru Cai mytbk920423@gmail.com --- A src/mainboard/hp/8470p/Kconfig A src/mainboard/hp/8470p/Kconfig.name A src/mainboard/hp/8470p/Makefile.inc A src/mainboard/hp/8470p/acpi/ec.asl A src/mainboard/hp/8470p/acpi/platform.asl A src/mainboard/hp/8470p/acpi/superio.asl A src/mainboard/hp/8470p/acpi_tables.c A src/mainboard/hp/8470p/board_info.txt A src/mainboard/hp/8470p/devicetree.cb A src/mainboard/hp/8470p/dsdt.asl A src/mainboard/hp/8470p/gpio.c A src/mainboard/hp/8470p/hda_verb.c A src/mainboard/hp/8470p/mainboard.c A src/mainboard/hp/8470p/romstage.c 14 files changed, 938 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/85/18985/2
