Attention is currently required from: Arthur Heymans, Felix Held, Martin L Roth.
Hello Arthur Heymans, Martin L Roth, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/79934?usp=email
The following approvals got outdated and were removed: Code-Review+2 by Arthur Heymans, Code-Review+2 by Martin L Roth, Verified+1 by build bot (Jenkins)
The change is no longer submittable: Code-Review and Verified are unsatisfied now.
Change subject: util/showdevicetree: drop unmaintained tool ......................................................................
This tool doesn't have a makefile, when trying to compile it manually with the given instructions it even fails to compile after fixing the paths in the given command, and it references the non-existing PCI_BUS_SEGN_BITS Kconfig symbol, so just drop this.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I8ca75db281a215bf3f194ab72a107f666dc0694e --- M Documentation/util.md M util/README.md D util/showdevicetree/description.md D util/showdevicetree/showdt.c 4 files changed, 0 insertions(+), 159 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/34/79934/6
