Michael Niewöhner has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/35188 )
Change subject: soc/skylake: lock aesni msr ......................................................................
Change-Id: I97a0d3b1b9b0452e929ca07d29c03237b413e521 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/soc/intel/skylake/cpu.c 1 file changed, 13 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/35188/1
diff --git a/src/soc/intel/skylake/cpu.c b/src/soc/intel/skylake/cpu.c index 0d49d28..984c134 100644 --- a/src/soc/intel/skylake/cpu.c +++ b/src/soc/intel/skylake/cpu.c @@ -420,6 +420,16 @@ wrmsr(MSR_EMULATE_PM_TIMER, msr); }
+void cpu_lock_aesni(void) { + msr_t msr; + + msr = rdmsr(MSR_FEATURE_CONFIG); + if ((msr.lo & 1) == 0) { + msr.lo |= 1; /* Lock it */ + wrmsr(MSR_FEATURE_CONFIG, msr); + } +} + /* All CPUs including BSP will run the following function. */ void soc_core_init(struct device *cpu) { @@ -442,6 +452,9 @@ /* Configure Intel Speed Shift */ configure_isst();
+ /* Lock AES-NI MSR */ + cpu_lock_aesni(); + /* Enable ACPI Timer Emulation via MSR 0x121 */ enable_pm_timer_emulation();
build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35188 )
Patch Set 1:
(2 comments)
https://review.coreboot.org/c/coreboot/+/35188/1/src/soc/intel/skylake/cpu.c File src/soc/intel/skylake/cpu.c:
https://review.coreboot.org/c/coreboot/+/35188/1/src/soc/intel/skylake/cpu.c... PS1, Line 423: void cpu_lock_aesni(void) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/35188/1/src/soc/intel/skylake/cpu.c... PS1, Line 432: trailing whitespace
Hello Patrick Rudolph, build bot (Jenkins),
Change-Id: I97a0d3b1b9b0452e929ca07d29c03237b413e521 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/soc/intel/skylake/cpu.c 1 file changed, 14 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/35188/2
Patch Set 2:
https://review.coreboot.org/c/coreboot/+/35188/2/src/soc/intel/skylake/cpu.c File src/soc/intel/skylake/cpu.c:
https://review.coreboot.org/c/coreboot/+/35188/2/src/soc/intel/skylake/cpu.c... PS2, Line 433: trailing whitespace
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/35188/3
Patch Set 3:
https://review.coreboot.org/c/coreboot/+/35188/3/src/soc/intel/skylake/cpu.c File src/soc/intel/skylake/cpu.c:
https://review.coreboot.org/c/coreboot/+/35188/3/src/soc/intel/skylake/cpu.c... PS3, Line 433: trailing whitespace
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/35188/4
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35188 )
Patch Set 4:
(2 comments)
https://review.coreboot.org/c/coreboot/+/35188/4//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/35188/4//COMMIT_MSG@7 PS4, Line 7: msr MSR
https://review.coreboot.org/c/coreboot/+/35188/4/src/soc/intel/skylake/cpu.c File src/soc/intel/skylake/cpu.c:
https://review.coreboot.org/c/coreboot/+/35188/4/src/soc/intel/skylake/cpu.c... PS4, Line 429: /* Lock it */ This comment is really obnoxious... maybe explain what locking this is useful for?
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35188 )
Patch Set 4:
This comment is really obnoxious... […]
... copied from somewhere below, you can find that multiple times in that file;) Maybe something like "Lock it because the datasheet says so" or "Lock it to prevent unintended disabling" ?
Change subject: soc/skylake: lock AES-NI MSR ......................................................................
Lock AES-NI register to prevent uninteded disabling, as suggested by the MSR datasheet.
Change-Id: I97a0d3b1b9b0452e929ca07d29c03237b413e521 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/soc/intel/skylake/cpu.c 1 file changed, 15 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/35188/5
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35188 )
Patch Set 5:
https://review.coreboot.org/c/coreboot/+/35188/5/src/soc/intel/skylake/cpu.c File src/soc/intel/skylake/cpu.c:
https://review.coreboot.org/c/coreboot/+/35188/5/src/soc/intel/skylake/cpu.c... PS5, Line 428: MSR_FEATURE_CONFIG Before reading the MSR, don't you need to check CPUID to determine if the MSR is really supported?
Patch Set 5:
No, on skylake and it's successors this is always supported
Patch Set 5:
Done
Patch Set 5:
(2 comments)
MSR
Done
Done
Hello Patrick Rudolph, Subrata Banik, Angel Pons, build bot (Jenkins), Furquan Shaikh,
Tested on X11SSM-F
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/35188/6
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/35188/7
Patch Set 7:
*ping* ;-) Any comments on this?
Subrata Banik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35188 )
Patch Set 7:
(2 comments)
https://review.coreboot.org/c/coreboot/+/35188/7//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/35188/7//COMMIT_MSG@6 PS7, Line 6: : soc/skylake soc/intel/skylake ?
https://review.coreboot.org/c/coreboot/+/35188/7//COMMIT_MSG@10 PS7, Line 10: MSR datasheet. any idea on whats been the issue if not getting lock ?
Hello Patrick Rudolph, Subrata Banik, Angel Pons, build bot (Jenkins), Nico Huber, Patrick Georgi, Furquan Shaikh,
Change subject: soc/intel/skylake: lock AES-NI MSR ......................................................................
Lock AES-NI register to prevent unintended disabling, as suggested by the MSR datasheet.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/35188/8
Patch Set 8:
(2 comments)
soc/intel/skylake ?
Done
uhm, it could be disabled unintended...
Patch Set 8:
the same is done in src/soc/intel/apollolake/cpu.c
Patch Set 8:
the same is done in src/soc/intel/apollolake/cpu. […]
Done
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35188 )
Patch Set 8: Code-Review+1
Patch Set 8: -Code-Review
Patch Set 8:
Done
Is the disabling happening in coreboot or is it some other component?
Patch Set 8:
Sorry, what is the question here? it's an MSR
Patch Set 8:
You mentioned that this locking is being done to avoid "unintended disabling". What component is doing the unintended disabling? Is that something you observed in practice? Or is this locking being done just as a precaution?
Patch Set 8:
You mentioned that this locking is being done to avoid "unintended disabling". […]
Ah, well, this is done as precaution
Patch Set 8: Code-Review+2
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35188 )
Patch Set 8: Code-Review-1
According to https://github.com/tianocore/edk2/blob/master/UefiCpuPkg/Library/CpuCommonFe... this should only be written on thread0 of each core. I've to check additional documentation, but it looks like this could #GP on HT enabled platforms. This check should be done for all SoCs, for all MSR accesses in MP init.
Furquan Shaikh has removed a vote from this change. ( https://review.coreboot.org/c/coreboot/+/35188 )
Removed Code-Review+2 by Furquan Shaikh furquan@google.com
Patch Set 8:
Thanks Patrick for pointing out, thats the reason i have asked what problem we are seeing if we like to set this msr then right place might be cpu.c where we are running feature programming
Patch Set 8:
Intel SDM https://www.intel.com/content/dam/www/public/us/en/documents/manuals/64-ia-3... lists that MSR as "Core", not as "Thread". You need to call intel_ht_sibling() or something similar to run it once on every core (I'm looking for a good code example, but can't find it ...).
That might also be the culprit of crashing SGX init with HT enabled...
Patch Set 8:
Patch Set 8:
Thank you, I will look into this later this day and test SGX+HT again then
Done
Patch Set 9:
This change is ready for review.
Hello Patrick Rudolph, Subrata Banik, Angel Pons, Paul Menzel, build bot (Jenkins), Nico Huber, Furquan Shaikh, Patrick Georgi,
Change-Id: I97a0d3b1b9b0452e929ca07d29c03237b413e521 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/soc/intel/skylake/Kconfig M src/soc/intel/skylake/cpu.c 2 files changed, 22 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/35188/10
Patch Set 10: Code-Review+1
Needs test.
Patch Set 10:
https://review.coreboot.org/c/coreboot/+/35188/9/src/soc/intel/skylake/cpu.c File src/soc/intel/skylake/cpu.c:
https://review.coreboot.org/c/coreboot/+/35188/9/src/soc/intel/skylake/cpu.c... PS9, Line 462: if (!intel_ht_sibling()) {
braces {} are not necessary for single statement blocks
Done
Patch Set 10:
ping.
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35188 )
https://review.coreboot.org/c/coreboot/+/35188/10/src/soc/intel/skylake/cpu.... File src/soc/intel/skylake/cpu.c:
https://review.coreboot.org/c/coreboot/+/35188/10/src/soc/intel/skylake/cpu.... PS10, Line 423: /* Lock AES-NI (MSR_FEATURE_CONFIG) to prevent unintended disabling as suggested in Intel Please add a line break after the /*
Also, the line could be broken earlier to enhance readability.
Uploaded patch set 11: Commit message was updated.
Successfully tested by reading the MSR on X11SSM-F
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/35188/11
Change-Id: I97a0d3b1b9b0452e929ca07d29c03237b413e521 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/soc/intel/skylake/Kconfig M src/soc/intel/skylake/cpu.c 2 files changed, 23 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/35188/12
Uploaded patch set 12.
Patch Set 12:
Please add a line break after the /* […]
Done
Patch Set 12: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/35188 )
Change-Id: I97a0d3b1b9b0452e929ca07d29c03237b413e521 Signed-off-by: Michael Niewöhner foss@mniewoehner.de Reviewed-on: https://review.coreboot.org/c/coreboot/+/35188 Reviewed-by: Patrick Georgi pgeorgi@google.com Reviewed-by: Nico Huber nico.h@gmx.de Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/skylake/Kconfig M src/soc/intel/skylake/cpu.c 2 files changed, 23 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Patrick Georgi: Looks good to me, approved Nico Huber: Looks good to me, approved
diff --git a/src/soc/intel/skylake/Kconfig b/src/soc/intel/skylake/Kconfig index 901e5f9..8bdd9b5 100644 --- a/src/soc/intel/skylake/Kconfig +++ b/src/soc/intel/skylake/Kconfig @@ -31,6 +31,7 @@ select COMMON_FADT select CPU_INTEL_COMMON select CPU_INTEL_FIRMWARE_INTERFACE_TABLE + select CPU_INTEL_COMMON_HYPERTHREADING select C_ENVIRONMENT_BOOTBLOCK select FSP_M_XIP if MAINBOARD_USES_FSP2_0 select FSP_T_XIP if FSP_CAR diff --git a/src/soc/intel/skylake/cpu.c b/src/soc/intel/skylake/cpu.c index 1f9ecad..63142b9 100644 --- a/src/soc/intel/skylake/cpu.c +++ b/src/soc/intel/skylake/cpu.c @@ -420,6 +420,25 @@ wrmsr(MSR_EMULATE_PM_TIMER, msr); }
+/* + * Lock AES-NI (MSR_FEATURE_CONFIG) to prevent unintended disabling + * as suggested in Intel document 325384-070US. + */ +static void cpu_lock_aesni(void) +{ + msr_t msr; + + /* Only run once per core as specified in the MSR datasheet */ + if (intel_ht_sibling()) + return; + + msr = rdmsr(MSR_FEATURE_CONFIG); + if ((msr.lo & 1) == 0) { + msr.lo |= 1; + wrmsr(MSR_FEATURE_CONFIG, msr); + } +} + /* All CPUs including BSP will run the following function. */ void soc_core_init(struct device *cpu) { @@ -444,6 +463,9 @@ /* Configure Intel Speed Shift */ configure_isst();
