Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9584
commit bbd2dba7eabfc42433552122fd648063ca8ab5ea Author: Jimmy Zhang jimmzhang@nvidia.com Date: Tue Dec 9 15:37:29 2014 -0800
ryu: display: Move display api to mainboard
Display configuration is board specific. The change here is preparing for supporting other than dsi interface.
BUG=chrome-os-partner:34336 BRANCH=none TEST=build ryu and test dev/rec mode, also build rush ok
Change-Id: Ied39d5d539d2be4983ab70976bffbe51fccba276 Signed-off-by: Stefan Reinauer reinauer@chromium.org Original-Commit-Id: 36be6b2e35c6246d5384d71b9ab9d4ddbf17764a Original-Change-Id: I494a04f7d6c0dbad2d472f4c2cd0aabfb23b8c97 Original-Signed-off-by: Jimmy Zhang jimmzhang@nvidia.com Original-Reviewed-on: https://chromium-review.googlesource.com/234271 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org --- src/mainboard/google/rush_ryu/mainboard.c | 7 +++++++ src/soc/nvidia/tegra132/dsi.c | 2 +- src/soc/nvidia/tegra132/include/soc/display.h | 2 ++ 3 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/src/mainboard/google/rush_ryu/mainboard.c b/src/mainboard/google/rush_ryu/mainboard.c index 8efd0a0..2b23481 100644 --- a/src/mainboard/google/rush_ryu/mainboard.c +++ b/src/mainboard/google/rush_ryu/mainboard.c @@ -32,6 +32,8 @@ #include <soc/funitcfg.h> #include <soc/nvidia/tegra/i2c.h> #include <soc/padconfig.h> +#include <soc/nvidia/tegra/dc.h> +#include <soc/display.h> #include <vendorcode/google/chromeos/chromeos.h> #if IS_ENABLED(CONFIG_CHROMEOS) #include <vboot_struct.h> @@ -280,6 +282,11 @@ static void mainboard_init(device_t dev) configure_display_blocks(); }
+void display_startup(device_t dev) +{ + dsi_display_startup(dev); +} + static void mainboard_enable(device_t dev) { dev->ops->init = &mainboard_init; diff --git a/src/soc/nvidia/tegra132/dsi.c b/src/soc/nvidia/tegra132/dsi.c index cfeb7fd..ad27b3d 100644 --- a/src/soc/nvidia/tegra132/dsi.c +++ b/src/soc/nvidia/tegra132/dsi.c @@ -875,7 +875,7 @@ static int dsi_enable(struct soc_nvidia_tegra132_config *config) return 0; }
-void display_startup(device_t dev) +void dsi_display_startup(device_t dev) { struct soc_nvidia_tegra132_config *config = dev->chip_info; struct display_controller *disp_ctrl = diff --git a/src/soc/nvidia/tegra132/include/soc/display.h b/src/soc/nvidia/tegra132/include/soc/display.h index b0f2573..62c4c0f 100644 --- a/src/soc/nvidia/tegra132/include/soc/display.h +++ b/src/soc/nvidia/tegra132/include/soc/display.h @@ -38,6 +38,8 @@ struct soc_nvidia_tegra132_config; struct display_controller;
+void dsi_display_startup(device_t dev); + int tegra_dc_init(struct display_controller *disp_ctrl); int update_display_mode(struct display_controller *disp_ctrl, struct soc_nvidia_tegra132_config *config);
