Matt DeVillier has submitted this change. ( https://review.coreboot.org/c/coreboot/+/57503?usp=email )
Change subject: sb/intel/lynxpoint: Fix AER and L1 sub-state reporting ......................................................................
Program the AER capability header register in a single write because it's write-once. In addition, only PCH-LP supports L1 sub-states, so only report the L1 sub-state capability on PCH-LP. This follows what Lynx Point PCH reference code version 1.9.1 does.
Change-Id: I08bd107eec7a3b2f1701c4657ae104e0818ae035 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/57503 Reviewed-by: Lean Sheng Tan sheng.tan@9elements.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/southbridge/intel/lynxpoint/pcie.c 1 file changed, 14 insertions(+), 12 deletions(-)
Approvals: Lean Sheng Tan: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/southbridge/intel/lynxpoint/pcie.c b/src/southbridge/intel/lynxpoint/pcie.c index 30a34f7..766ed43 100644 --- a/src/southbridge/intel/lynxpoint/pcie.c +++ b/src/southbridge/intel/lynxpoint/pcie.c @@ -670,20 +670,22 @@ /* Set EOI forwarding disable. */ pci_or_config32(dev, 0xd4, 1 << 1);
- /* Set AER Extended Cap ID to 01h and Next Cap Pointer to 200h. */ - if (CONFIG(PCIEXP_AER)) - pci_update_config32(dev, 0x100, ~0xfffff, (1 << 29) | 0x10001); - else - pci_update_config32(dev, 0x100, ~0xfffff, (1 << 29)); + /* Set AER Extended Cap ID to 01h */ + u32 aech = CONFIG(PCIEXP_AER) ? 0x10001 : 0;
- /* Set L1 Sub-State Cap ID to 1Eh and Next Cap Pointer to None. */ - if (CONFIG(PCIEXP_L1_SUB_STATE)) - pci_update_config32(dev, 0x200, ~0xfffff, 0x001e); - else - pci_update_config32(dev, 0x200, ~0xfffff, 0); - + /* For PCH-LP, set Next Cap Pointer to 200h. */ if (is_lp) - pci_or_config32(dev, 0x100, 1 << 29); + aech |= 1 << 29; + + pci_update_config32(dev, 0x100, ~0xfffff, aech); + + if (is_lp) { + /* Set L1 Sub-State Cap ID to 1Eh and Next Cap Pointer to None. */ + if (CONFIG(PCIEXP_L1_SUB_STATE)) + pci_update_config32(dev, 0x200, ~0xfffff, 0x001e); + else + pci_update_config32(dev, 0x200, ~0xfffff, 0); + }
/* Read and write back write-once capability registers. */ pci_update_config32(dev, 0x34, ~0, 0);
