Raul Rangel has submitted this change. ( https://review.coreboot.org/c/coreboot/+/58197 )
Change subject: vc/amd/fsp/cezanne: Add UPD fsp_owns_pcie_resets to FSP-M for Cezanne ......................................................................
Update UPD to include option for FSP to de-assert PCIe reset GPIOs as specified in the DXIO descriptors. This change requires FSP version 1.0.4 revision 2 otherwise setting this value does affect any FSP behavior.
BUG=b:199780346 TEST=Verify toggling this value is reflected in FSP
Cq-Depend: chrome-internal:4170351 Change-Id: I0dee05fb0a650f026c2f09581117fa7fb5f6a90a Signed-off-by: Matt Papageorge matthewpapa07@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/58197 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Raul Rangel rrangel@chromium.org Reviewed-by: Karthik Ramasubramanian kramasub@google.com --- M src/vendorcode/amd/fsp/cezanne/FspmUpd.h 1 file changed, 2 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Raul Rangel: Looks good to me, approved Karthik Ramasubramanian: Looks good to me, approved
diff --git a/src/vendorcode/amd/fsp/cezanne/FspmUpd.h b/src/vendorcode/amd/fsp/cezanne/FspmUpd.h index 7cb788e..f21ca42 100644 --- a/src/vendorcode/amd/fsp/cezanne/FspmUpd.h +++ b/src/vendorcode/amd/fsp/cezanne/FspmUpd.h @@ -26,7 +26,8 @@ /** Offset 0x0078**/ uint32_t serial_port_refclk; /** Offset 0x007C**/ uint32_t serial_reserved; /** Offset 0x0080**/ uint8_t dxio_descriptor[FSPM_UPD_DXIO_DESCRIPTOR_COUNT][52]; - /** Offset 0x0358**/ uint8_t pcie_reserved[52]; + /** Offset 0x0358**/ uint8_t fsp_owns_pcie_resets; + /** Offset 0x0359**/ uint8_t pcie_reserved[51]; /** Offset 0x038C**/ uint32_t ddi_descriptor[FSPM_UPD_DDI_DESCRIPTOR_COUNT]; /** Offset 0x03A0**/ uint8_t ddi_reserved[6]; /** Offset 0x03A6**/ uint8_t ccx_down_core_mode;
2 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one.
