Attention is currently required from: Edward O'Callaghan, Angel Pons, Nikolai Artemiev. Hello build bot (Jenkins), Nico Huber, Edward O'Callaghan, Angel Pons, Anastasia Klimchuk,
https://review.coreboot.org/c/flashrom/+/59528
Change subject: spi25_statusreg: inline spi_write_register_flag() ......................................................................
Creating the entire SPI command that should be sent to the chip in spi_write_register() is simpler than splitting it across two functions that have to pass multiple parameters between them.
Additinally, having seperate spi_write_register_flag() function provided little benefit, as it was only ever called from spi_write_register().
BUG=b:195381327,b:153800563 TEST=builds BRANCH=none
Change-Id: I4996b0848d0ed09032bad2ab13ab1f40bbfc0304 Signed-off-by: Nikolai Artemiev nartemiev@google.com --- M spi25_statusreg.c 1 file changed, 46 insertions(+), 53 deletions(-)
git pull ssh://review.coreboot.org:29418/flashrom refs/changes/28/59528/16
