Hello Brian Norris,
https://review.coreboot.org/22492
Change subject: file: Re-implement file parsing function ......................................................................
This re-does the original file parsing function to be a little bit more robust. The old version just copied the file content and did a string compare. The new version will read the file character-by- character, comparing with the specified string as we go along, until a match is found.
BUG=none BRANCH=none TEST=Works as expected on veyron_mickey to grok thru sysfs. Also tested with an upcoming FDT-related patch to search thru procfs.
Signed-off-by: David Hendricks dhendrix@chromium.org Change-Id: I6e3811acf352d85c3f43192f87388833a997dd2c Reviewed-on: https://chromium-review.googlesource.com/310653 Reviewed-by: Brian Norris briannorris@chromium.org --- M file.c 1 file changed, 58 insertions(+), 28 deletions(-)
git pull ssh://review.coreboot.org:29418/flashrom refs/changes/92/22492/1
diff --git a/file.c b/file.c index 8bc34aa..24ded2a 100644 --- a/file.c +++ b/file.c @@ -45,45 +45,75 @@
#include "flash.h"
-/*returns 1 if contents matches, 0 if not, and <0 to indicate error */ -static int file_contents_match(const char *path, const char *str) +/* returns 1 if string if found, 0 if not, and <0 to indicate error */ +static int find_string(const char *path, const char *str) { - FILE *fp; - char *content; - int len = strlen(str); - int ret = -1; + int fd, ret = 0; + struct stat s; + off_t i;
- content = malloc(len); - if (!content) - return -1; - - if ((fp = fopen(path, "r")) == NULL) { - msg_pdbg("Error opening %s: %s\n", path, strerror(errno)); - goto file_contents_match_done; - } - if (fread(content, 1, len, fp) < 1) { - msg_pdbg("Error reading %s: %s\n", path, strerror(ferror(fp))); - goto file_contents_match_done; + if (stat(path, &s) < 0) { + msg_gerr("Cannot stat file "%s"\n", path); + ret = -1; + goto find_string_exit_0; }
- if (!strncmp(str, content, len)) - ret = 1; - else - ret = 0; + if (s.st_size < strlen(str)) + goto find_string_exit_0;
-file_contents_match_done: - fclose(fp); - free(content); + fd = open(path, O_RDONLY, 0); + if (fd < 0) { + msg_gerr("Cannot open file "%s"\n", path); + ret = -1; + goto find_string_exit_0; + } + + /* mmap() would be nice but it might not be implemented for some + * files in sysfs and procfs */ + for (i = 0; i <= s.st_size - strlen(str); i++) { + int match_found = 1; + off_t j; + + if (lseek(fd, i, SEEK_SET) == (off_t)-1) { + msg_gerr("Failed to seek within "%s"\n", path); + ret = -1; + goto find_string_exit_1; + } + + for (j = 0; j < strlen(str); j++) { + char c; + + if (read(fd, &c, 1) != 1) { + msg_gerr("Failed to read "%s"\n", path); + ret = -1; + goto find_string_exit_1; + } + + if (str[j] != c) { + match_found = 0; + break; + } + } + + if (match_found) { + ret = 1; + break; + } + + } + +find_string_exit_1: + close(fd); +find_string_exit_0: return ret; }
/* - * scanft - scan filetree for file with option to parse some content + * scanft - scan filetree for file with option to search for content * * @root: Where to begin search * @filename: Name of file to search for - * @str: Optional NULL terminated string to check at the beginning - * of the file + * @str: Optional NULL terminated string to search for * @symdepth: Maximum depth of symlinks to follow. A negative value means * follow indefinitely. Zero means do not follow symlinks. * @@ -130,7 +160,7 @@ snprintf(newpath, sizeof(newpath), "%s/%s", root, d->d_name);
if (!strcmp(d->d_name, filename)) { - if (!str || file_contents_match(newpath, str)) + if (!str || (find_string(newpath, str) == 1)) ret = strdup(newpath); }
