Nico Huber has posted comments on this change. ( https://review.coreboot.org/23338 )
Change subject: digilent_spi: add a driver for the iCEblink40 development board ......................................................................
Patch Set 4:
(5 comments)
I'm pretty much confused by the padding, did you try what it replies without a padded write?
https://review.coreboot.org/#/c/23338/4/digilent_spi.c File digilent_spi.c:
https://review.coreboot.org/#/c/23338/4/digilent_spi.c@221 PS4, Line 221: uint8_t res[read_follows ? 10 : 6]; Looking at iceBurn, the meaning of the bytes seems known? 2-byte status, received write length, returned read length. Why not check them?
https://review.coreboot.org/#/c/23338/4/digilent_spi.c@230 PS4, Line 230: int len = writecnt + readcnt; This seems flawed or at least confuses me too much. If I read iceBurn correctly, it pads up to `readcnt` so the length of the write is `MAX( writecnt, readcnt)` but not `writecnt + readcnt`. The length of the read in iceBurn seems to always be `readcnt` without anything to drop from the read data.
https://review.coreboot.org/#/c/23338/4/digilent_spi.c@236 PS4, Line 236: memset(buf + writecnt, 0xff, readcnt); iceBurn pads with zeros, aiui. And not by `readcnt` bytes but only up to a total length of `readcnt`.
https://review.coreboot.org/#/c/23338/4/digilent_spi.c@246 PS4, Line 246: ret = libusb_bulk_transfer(handle, DATA_WRITE_EP, buf, len, &tx_len, USB_TIMEOUT); Maybe we should check `tx_len` as well.
https://review.coreboot.org/#/c/23338/4/digilent_spi.c@276 PS4, Line 276: .max_data_read = 64, : .max_data_write = 64, These are about the payload size, i.e. data actually read / written from / to the flash storage. iceBurn seems to use 64 as a limit for the bulk transfers, though, which will include the SPI command and address. So to limit the bulk transfer to 64 bytes, we should set 59 here, I guess. OTOH, if you'd implement a loop around the 64 byte bulk transfers like iceBurn, we wouldn't need a limit here (could speed things a little up due to less protocol overhead).
