Attention is currently required from: Angel Pons, Nikolai Artemiev, Sergii Dmytruk. Hello build bot (Jenkins), Nico Huber, Edward O'Callaghan, Angel Pons, Anastasia Klimchuk, Sergii Dmytruk,
https://review.coreboot.org/c/flashrom/+/58480
to look at the new patch set (#25).
Change subject: flashchips,writeprotect_ranges: add range decoding function ......................................................................
Allow chips to specify functions that map status register bits to protection ranges. These are used to enumerate available ranges and determine the protection state of chips. The patch also adds a range decoding function for the example chips. Many other chips can also be handled by it, though some will require different functions (e.g. MX25L6406 and related chips).
Another approach that has been tried in cros flashrom is maintaining tables of range data, but it quickly becomes error prone and hard to validate.
Using a function to interpret the ranges allows compact encoding with most chips and is flexible enough to allow chips with less predictable ranges to be handled as well.
BUG=b:195381327,b:153800563 TEST=dumped range tables, checked against datasheets BRANCH=none
Change-Id: Id163ed80938a946a502ed116e48e8236e36eb203 Signed-off-by: Nikolai Artemiev nartemiev@google.com --- M Makefile M chipdrivers.h M flash.h M flashchips.c M meson.build A writeprotect_ranges.c 6 files changed, 105 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/flashrom refs/changes/80/58480/25
