David Hendricks has uploaded this change for review. ( https://review.coreboot.org/20569
Change subject: layout: Add a function to check if numeric range is included ......................................................................
This adds a helper function to iterate thru ranges to check if a specified numeric range is marked as included in the layout.
If no include -i arguments were used to specify included regions, then all any range will return true.
Change-Id: I096410ea957fe204affa67734e7589a6e4424a26 Signed-off-by: David Hendricks dhendricks@fb.com --- M layout.c M layout.h 2 files changed, 26 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/flashrom refs/changes/69/20569/1
diff --git a/layout.c b/layout.c index 9bf0b03..a35a72c 100644 --- a/layout.c +++ b/layout.c @@ -225,3 +225,27 @@
return ret; } + +/* returns 1 if any offset within [base, base+len) is included in layout */ +int range_is_included(chipoff_t start, chipoff_t end) +{ + int i; + + if (num_include_args == 0) + return 1; + + for (i = 0; i < layout.num_entries; i++) { + struct romentry entry = layout.entries[i]; + + if (!entry.included) + continue; + if (end < entry.start) + continue; + if (start > entry.end) + continue; + + return 1; + } + + return 0; +} diff --git a/layout.h b/layout.h index c93d754..6fc4e2e 100644 --- a/layout.h +++ b/layout.h @@ -66,4 +66,6 @@
int process_include_args(struct flashrom_layout *);
+int range_is_included(chipoff_t start, chipoff_t end); + #endif /* !__LAYOUT_H__ */
