Attention is currently required from: Nico Huber, Angel Pons, Nikolai Artemiev. Hello build bot (Jenkins), Nico Huber, Edward O'Callaghan, Angel Pons, Anastasia Klimchuk,
https://review.coreboot.org/c/flashrom/+/62643
Change subject: writeprotect.c: refactor and fix wp_mode functions ......................................................................
This is a follow up on commit 12dbc4e04508aecfff53ad95b6f68865da1b4f07.
Use a lookup table in get_wp_mode() and drop the srp_bit_present check, since a chip without SRP is just FLASHROM_WP_MODE_DISABLED.
Add a srp_bit_present check to set_wp_mode() if the mode requires it.
BUG=b:182223106 BRANCH=none TEST=flashrom --wp-{enable,disable,status} on AMD dut
Change-Id: Ib6c347453f9216e5816e4ed35bf9783fd3c720e0 Signed-off-by: Nikolai Artemiev nartemiev@google.com --- M writeprotect.c 1 file changed, 13 insertions(+), 9 deletions(-)
git pull ssh://review.coreboot.org:29418/flashrom refs/changes/43/62643/11
