Edward O'Callaghan has submitted this change. ( https://review.coreboot.org/c/flashrom/+/54873 )
Change subject: par_masters: Reshuffle to remove forward declarations ......................................................................
Dispense with all these forward declarations by way of ordering. Just deal with all the par_masters in one go to be over and done with.
BUG=none BRANCH=none TEST=builds
Change-Id: I88e89992380195fee7c9de7ec57502ab980ec5df Signed-off-by: Edward O'Callaghan quasisec@google.com Reviewed-on: https://review.coreboot.org/c/flashrom/+/54873 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Anastasia Klimchuk aklm@chromium.org Reviewed-by: Angel Pons th3fanbus@gmail.com --- M atahpt.c M atapromise.c M atavia.c M gfxnvidia.c M it8212.c M nic3com.c M nicintel.c M nicnatsemi.c M nicrealtek.c M satamv.c M satasii.c 11 files changed, 258 insertions(+), 293 deletions(-)
Approvals: build bot (Jenkins): Verified Angel Pons: Looks good to me, approved Anastasia Klimchuk: Looks good to me, but someone else must approve
diff --git a/atahpt.c b/atahpt.c index 620e894..327d74b 100644 --- a/atahpt.c +++ b/atahpt.c @@ -40,9 +40,19 @@ };
static void atahpt_chip_writeb(const struct flashctx *flash, uint8_t val, - chipaddr addr); + chipaddr addr) +{ + OUTL((uint32_t)addr, io_base_addr + BIOS_ROM_ADDR); + OUTB(val, io_base_addr + BIOS_ROM_DATA); +} + static uint8_t atahpt_chip_readb(const struct flashctx *flash, - const chipaddr addr); + const chipaddr addr) +{ + OUTL((uint32_t)addr, io_base_addr + BIOS_ROM_ADDR); + return INB(io_base_addr + BIOS_ROM_DATA); +} + static const struct par_master par_master_atahpt = { .chip_readb = atahpt_chip_readb, .chip_readw = fallback_chip_readw, @@ -80,20 +90,6 @@ return 0; }
-static void atahpt_chip_writeb(const struct flashctx *flash, uint8_t val, - chipaddr addr) -{ - OUTL((uint32_t)addr, io_base_addr + BIOS_ROM_ADDR); - OUTB(val, io_base_addr + BIOS_ROM_DATA); -} - -static uint8_t atahpt_chip_readb(const struct flashctx *flash, - const chipaddr addr) -{ - OUTL((uint32_t)addr, io_base_addr + BIOS_ROM_ADDR); - return INB(io_base_addr + BIOS_ROM_DATA); -} - #else #error PCI port I/O access is not supported on this architecture yet. #endif diff --git a/atapromise.c b/atapromise.c index f32bdb4..4941a7c 100644 --- a/atapromise.c +++ b/atapromise.c @@ -53,20 +53,6 @@ {0}, };
-static void atapromise_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr); -static uint8_t atapromise_chip_readb(const struct flashctx *flash, const chipaddr addr); - -static const struct par_master par_master_atapromise = { - .chip_readb = atapromise_chip_readb, - .chip_readw = fallback_chip_readw, - .chip_readl = fallback_chip_readl, - .chip_readn = fallback_chip_readn, - .chip_writeb = atapromise_chip_writeb, - .chip_writew = fallback_chip_writew, - .chip_writel = fallback_chip_writel, - .chip_writen = fallback_chip_writen, -}; - void *atapromise_map(const char *descr, uintptr_t phys_addr, size_t len) { /* In case fallback_map ever returns something other than NULL. */ @@ -106,6 +92,32 @@ } }
+static void atapromise_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr) +{ + uint32_t data; + + atapromise_limit_chip(flash->chip); + data = (rom_base_addr + (addr & ADDR_MASK)) << 8 | val; + OUTL(data, io_base_addr + 0x14); +} + +static uint8_t atapromise_chip_readb(const struct flashctx *flash, const chipaddr addr) +{ + atapromise_limit_chip(flash->chip); + return pci_mmio_readb(atapromise_bar + (addr & ADDR_MASK)); +} + +static const struct par_master par_master_atapromise = { + .chip_readb = atapromise_chip_readb, + .chip_readw = fallback_chip_readw, + .chip_readl = fallback_chip_readl, + .chip_readn = fallback_chip_readn, + .chip_writeb = atapromise_chip_writeb, + .chip_writew = fallback_chip_writew, + .chip_writel = fallback_chip_writel, + .chip_writen = fallback_chip_writen, +}; + int atapromise_init(void) { struct pci_dev *dev = NULL; @@ -150,21 +162,6 @@ return 0; }
-static void atapromise_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr) -{ - uint32_t data; - - atapromise_limit_chip(flash->chip); - data = (rom_base_addr + (addr & ADDR_MASK)) << 8 | val; - OUTL(data, io_base_addr + 0x14); -} - -static uint8_t atapromise_chip_readb(const struct flashctx *flash, const chipaddr addr) -{ - atapromise_limit_chip(flash->chip); - return pci_mmio_readb(atapromise_bar + (addr & ADDR_MASK)); -} - #else #error PCI port I/O access is not supported on this architecture yet. #endif diff --git a/atavia.c b/atavia.c index e04950a..8045e1b 100644 --- a/atavia.c +++ b/atavia.c @@ -54,19 +54,6 @@ {0}, };
-static void atavia_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr); -static uint8_t atavia_chip_readb(const struct flashctx *flash, const chipaddr addr); -static const struct par_master lpc_master_atavia = { - .chip_readb = atavia_chip_readb, - .chip_readw = fallback_chip_readw, - .chip_readl = fallback_chip_readl, - .chip_readn = fallback_chip_readn, - .chip_writeb = atavia_chip_writeb, - .chip_writew = fallback_chip_writew, - .chip_writel = fallback_chip_writel, - .chip_writen = fallback_chip_writen, -}; - static void *atavia_offset = NULL; static struct pci_dev *dev = NULL;
@@ -119,6 +106,43 @@ return (atavia_offset != 0) ? atavia_offset : (void *)phys_addr; }
+static void atavia_chip_writeb(const struct flashctx *flash, uint8_t val, const chipaddr addr) +{ + msg_pspew("%s: 0x%02x to 0x%*" PRIxPTR ".\n", __func__, val, PRIxPTR_WIDTH, addr); + pci_write_long(dev, BROM_ADDR, (addr & ~3)); + pci_write_long(dev, BROM_DATA, val << BYTE_OFFSET(addr)); + pci_write_byte(dev, BROM_ACCESS, BROM_TRIGGER | BROM_WRITE | ENABLE_BYTE(addr)); + + if (!atavia_ready(dev)) { + msg_perr("not ready after write\n"); + } +} + +static uint8_t atavia_chip_readb(const struct flashctx *flash, const chipaddr addr) +{ + pci_write_long(dev, BROM_ADDR, (addr & ~3)); + pci_write_byte(dev, BROM_ACCESS, BROM_TRIGGER | ENABLE_BYTE(addr)); + + if (!atavia_ready(dev)) { + msg_perr("not ready after read\n"); + } + + uint8_t val = (pci_read_long(dev, BROM_DATA) >> BYTE_OFFSET(addr)) & 0xff; + msg_pspew("%s: 0x%02x from 0x%*" PRIxPTR ".\n", __func__, val, PRIxPTR_WIDTH, addr); + return val; +} + +static const struct par_master lpc_master_atavia = { + .chip_readb = atavia_chip_readb, + .chip_readw = fallback_chip_readw, + .chip_readl = fallback_chip_readl, + .chip_readn = fallback_chip_readn, + .chip_writeb = atavia_chip_writeb, + .chip_writew = fallback_chip_writew, + .chip_writel = fallback_chip_writel, + .chip_writen = fallback_chip_writen, +}; + int atavia_init(void) { char *arg = extract_programmer_param("offset"); @@ -164,29 +188,3 @@
return 0; } - -static void atavia_chip_writeb(const struct flashctx *flash, uint8_t val, const chipaddr addr) -{ - msg_pspew("%s: 0x%02x to 0x%*" PRIxPTR ".\n", __func__, val, PRIxPTR_WIDTH, addr); - pci_write_long(dev, BROM_ADDR, (addr & ~3)); - pci_write_long(dev, BROM_DATA, val << BYTE_OFFSET(addr)); - pci_write_byte(dev, BROM_ACCESS, BROM_TRIGGER | BROM_WRITE | ENABLE_BYTE(addr)); - - if (!atavia_ready(dev)) { - msg_perr("not ready after write\n"); - } -} - -static uint8_t atavia_chip_readb(const struct flashctx *flash, const chipaddr addr) -{ - pci_write_long(dev, BROM_ADDR, (addr & ~3)); - pci_write_byte(dev, BROM_ACCESS, BROM_TRIGGER | ENABLE_BYTE(addr)); - - if (!atavia_ready(dev)) { - msg_perr("not ready after read\n"); - } - - uint8_t val = (pci_read_long(dev, BROM_DATA) >> BYTE_OFFSET(addr)) & 0xff; - msg_pspew("%s: 0x%02x from 0x%*" PRIxPTR ".\n", __func__, val, PRIxPTR_WIDTH, addr); - return val; -} diff --git a/gfxnvidia.c b/gfxnvidia.c index fe6f982..6b1efcf 100644 --- a/gfxnvidia.c +++ b/gfxnvidia.c @@ -59,9 +59,17 @@ };
static void gfxnvidia_chip_writeb(const struct flashctx *flash, uint8_t val, - chipaddr addr); + chipaddr addr) +{ + pci_mmio_writeb(val, nvidia_bar + (addr & GFXNVIDIA_MEMMAP_MASK)); +} + static uint8_t gfxnvidia_chip_readb(const struct flashctx *flash, - const chipaddr addr); + const chipaddr addr) +{ + return pci_mmio_readb(nvidia_bar + (addr & GFXNVIDIA_MEMMAP_MASK)); +} + static const struct par_master par_master_gfxnvidia = { .chip_readb = gfxnvidia_chip_readb, .chip_readw = fallback_chip_readw, @@ -107,15 +115,3 @@
return 0; } - -static void gfxnvidia_chip_writeb(const struct flashctx *flash, uint8_t val, - chipaddr addr) -{ - pci_mmio_writeb(val, nvidia_bar + (addr & GFXNVIDIA_MEMMAP_MASK)); -} - -static uint8_t gfxnvidia_chip_readb(const struct flashctx *flash, - const chipaddr addr) -{ - return pci_mmio_readb(nvidia_bar + (addr & GFXNVIDIA_MEMMAP_MASK)); -} diff --git a/it8212.c b/it8212.c index 2f2d43e..7c66a59 100644 --- a/it8212.c +++ b/it8212.c @@ -32,8 +32,16 @@ #define IT8212_MEMMAP_SIZE (128 * 1024) #define IT8212_MEMMAP_MASK (IT8212_MEMMAP_SIZE - 1)
-static void it8212_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr); -static uint8_t it8212_chip_readb(const struct flashctx *flash, const chipaddr addr); +static void it8212_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr) +{ + pci_mmio_writeb(val, it8212_bar + (addr & IT8212_MEMMAP_MASK)); +} + +static uint8_t it8212_chip_readb(const struct flashctx *flash, const chipaddr addr) +{ + return pci_mmio_readb(it8212_bar + (addr & IT8212_MEMMAP_MASK)); +} + static const struct par_master par_master_it8212 = { .chip_readb = it8212_chip_readb, .chip_readw = fallback_chip_readw, @@ -70,13 +78,3 @@ register_par_master(&par_master_it8212, BUS_PARALLEL, NULL); return 0; } - -static void it8212_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr) -{ - pci_mmio_writeb(val, it8212_bar + (addr & IT8212_MEMMAP_MASK)); -} - -static uint8_t it8212_chip_readb(const struct flashctx *flash, const chipaddr addr) -{ - return pci_mmio_readb(it8212_bar + (addr & IT8212_MEMMAP_MASK)); -} diff --git a/nic3com.c b/nic3com.c index 6ff91e7..d60b03c 100644 --- a/nic3com.c +++ b/nic3com.c @@ -54,9 +54,19 @@ };
static void nic3com_chip_writeb(const struct flashctx *flash, uint8_t val, - chipaddr addr); + chipaddr addr) +{ + OUTL((uint32_t)addr, io_base_addr + BIOS_ROM_ADDR); + OUTB(val, io_base_addr + BIOS_ROM_DATA); +} + static uint8_t nic3com_chip_readb(const struct flashctx *flash, - const chipaddr addr); + const chipaddr addr) +{ + OUTL((uint32_t)addr, io_base_addr + BIOS_ROM_ADDR); + return INB(io_base_addr + BIOS_ROM_DATA); +} + static const struct par_master par_master_nic3com = { .chip_readb = nic3com_chip_readb, .chip_readw = fallback_chip_readw, @@ -125,20 +135,6 @@ return 0; }
-static void nic3com_chip_writeb(const struct flashctx *flash, uint8_t val, - chipaddr addr) -{ - OUTL((uint32_t)addr, io_base_addr + BIOS_ROM_ADDR); - OUTB(val, io_base_addr + BIOS_ROM_DATA); -} - -static uint8_t nic3com_chip_readb(const struct flashctx *flash, - const chipaddr addr) -{ - OUTL((uint32_t)addr, io_base_addr + BIOS_ROM_ADDR); - return INB(io_base_addr + BIOS_ROM_DATA); -} - #else #error PCI port I/O access is not supported on this architecture yet. #endif diff --git a/nicintel.c b/nicintel.c index afd2682..3d324da 100644 --- a/nicintel.c +++ b/nicintel.c @@ -41,9 +41,17 @@ #define CSR_FCR 0x0c
static void nicintel_chip_writeb(const struct flashctx *flash, uint8_t val, - chipaddr addr); + chipaddr addr) +{ + pci_mmio_writeb(val, nicintel_bar + (addr & NICINTEL_MEMMAP_MASK)); +} + static uint8_t nicintel_chip_readb(const struct flashctx *flash, - const chipaddr addr); + const chipaddr addr) +{ + return pci_mmio_readb(nicintel_bar + (addr & NICINTEL_MEMMAP_MASK)); +} + static const struct par_master par_master_nicintel = { .chip_readb = nicintel_chip_readb, .chip_readw = fallback_chip_readw, @@ -103,15 +111,3 @@
return 0; } - -static void nicintel_chip_writeb(const struct flashctx *flash, uint8_t val, - chipaddr addr) -{ - pci_mmio_writeb(val, nicintel_bar + (addr & NICINTEL_MEMMAP_MASK)); -} - -static uint8_t nicintel_chip_readb(const struct flashctx *flash, - const chipaddr addr) -{ - return pci_mmio_readb(nicintel_bar + (addr & NICINTEL_MEMMAP_MASK)); -} diff --git a/nicnatsemi.c b/nicnatsemi.c index 77b5440..56297fe 100644 --- a/nicnatsemi.c +++ b/nicnatsemi.c @@ -35,9 +35,35 @@ };
static void nicnatsemi_chip_writeb(const struct flashctx *flash, uint8_t val, - chipaddr addr); + chipaddr addr) +{ + OUTL((uint32_t)addr & 0x0001FFFF, io_base_addr + BOOT_ROM_ADDR); + /* + * The datasheet requires 32 bit accesses to this register, but it seems + * that requirement might only apply if the register is memory mapped. + * Bits 8-31 of this register are apparently don't care, and if this + * register is I/O port mapped, 8 bit accesses to the lowest byte of the + * register seem to work fine. Due to that, we ignore the advice in the + * data sheet. + */ + OUTB(val, io_base_addr + BOOT_ROM_DATA); +} + static uint8_t nicnatsemi_chip_readb(const struct flashctx *flash, - const chipaddr addr); + const chipaddr addr) +{ + OUTL(((uint32_t)addr & 0x0001FFFF), io_base_addr + BOOT_ROM_ADDR); + /* + * The datasheet requires 32 bit accesses to this register, but it seems + * that requirement might only apply if the register is memory mapped. + * Bits 8-31 of this register are apparently don't care, and if this + * register is I/O port mapped, 8 bit accesses to the lowest byte of the + * register seem to work fine. Due to that, we ignore the advice in the + * data sheet. + */ + return INB(io_base_addr + BOOT_ROM_DATA); +} + static const struct par_master par_master_nicnatsemi = { .chip_readb = nicnatsemi_chip_readb, .chip_readw = fallback_chip_readw, @@ -76,36 +102,6 @@ return 0; }
-static void nicnatsemi_chip_writeb(const struct flashctx *flash, uint8_t val, - chipaddr addr) -{ - OUTL((uint32_t)addr & 0x0001FFFF, io_base_addr + BOOT_ROM_ADDR); - /* - * The datasheet requires 32 bit accesses to this register, but it seems - * that requirement might only apply if the register is memory mapped. - * Bits 8-31 of this register are apparently don't care, and if this - * register is I/O port mapped, 8 bit accesses to the lowest byte of the - * register seem to work fine. Due to that, we ignore the advice in the - * data sheet. - */ - OUTB(val, io_base_addr + BOOT_ROM_DATA); -} - -static uint8_t nicnatsemi_chip_readb(const struct flashctx *flash, - const chipaddr addr) -{ - OUTL(((uint32_t)addr & 0x0001FFFF), io_base_addr + BOOT_ROM_ADDR); - /* - * The datasheet requires 32 bit accesses to this register, but it seems - * that requirement might only apply if the register is memory mapped. - * Bits 8-31 of this register are apparently don't care, and if this - * register is I/O port mapped, 8 bit accesses to the lowest byte of the - * register seem to work fine. Due to that, we ignore the advice in the - * data sheet. - */ - return INB(io_base_addr + BOOT_ROM_DATA); -} - #else #error PCI port I/O access is not supported on this architecture yet. #endif diff --git a/nicrealtek.c b/nicrealtek.c index 2208179..788c088 100644 --- a/nicrealtek.c +++ b/nicrealtek.c @@ -35,8 +35,44 @@ {0}, };
-static void nicrealtek_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr); -static uint8_t nicrealtek_chip_readb(const struct flashctx *flash, const chipaddr addr); +static void nicrealtek_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr) +{ + /* Output addr and data, set WE to 0, set OE to 1, set CS to 0, + * enable software access. + */ + OUTL(((uint32_t)addr & 0x01FFFF) | 0x0A0000 | (val << 24), + io_base_addr + bios_rom_addr); + /* Output addr and data, set WE to 1, set OE to 1, set CS to 1, + * enable software access. + */ + OUTL(((uint32_t)addr & 0x01FFFF) | 0x1E0000 | (val << 24), + io_base_addr + bios_rom_addr); +} + +static uint8_t nicrealtek_chip_readb(const struct flashctx *flash, const chipaddr addr) +{ + uint8_t val; + + /* FIXME: Can we skip reading the old data and simply use 0? */ + /* Read old data. */ + val = INB(io_base_addr + bios_rom_data); + /* Output new addr and old data, set WE to 1, set OE to 0, set CS to 0, + * enable software access. + */ + OUTL(((uint32_t)addr & 0x01FFFF) | 0x060000 | (val << 24), + io_base_addr + bios_rom_addr); + + /* Read new data. */ + val = INB(io_base_addr + bios_rom_data); + /* Output addr and new data, set WE to 1, set OE to 1, set CS to 1, + * enable software access. + */ + OUTL(((uint32_t)addr & 0x01FFFF) | 0x1E0000 | (val << 24), + io_base_addr + bios_rom_addr); + + return val; +} + static const struct par_master par_master_nicrealtek = { .chip_readb = nicrealtek_chip_readb, .chip_readw = fallback_chip_readw, @@ -91,44 +127,6 @@ return 0; }
-static void nicrealtek_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr) -{ - /* Output addr and data, set WE to 0, set OE to 1, set CS to 0, - * enable software access. - */ - OUTL(((uint32_t)addr & 0x01FFFF) | 0x0A0000 | (val << 24), - io_base_addr + bios_rom_addr); - /* Output addr and data, set WE to 1, set OE to 1, set CS to 1, - * enable software access. - */ - OUTL(((uint32_t)addr & 0x01FFFF) | 0x1E0000 | (val << 24), - io_base_addr + bios_rom_addr); -} - -static uint8_t nicrealtek_chip_readb(const struct flashctx *flash, const chipaddr addr) -{ - uint8_t val; - - /* FIXME: Can we skip reading the old data and simply use 0? */ - /* Read old data. */ - val = INB(io_base_addr + bios_rom_data); - /* Output new addr and old data, set WE to 1, set OE to 0, set CS to 0, - * enable software access. - */ - OUTL(((uint32_t)addr & 0x01FFFF) | 0x060000 | (val << 24), - io_base_addr + bios_rom_addr); - - /* Read new data. */ - val = INB(io_base_addr + bios_rom_data); - /* Output addr and new data, set WE to 1, set OE to 1, set CS to 1, - * enable software access. - */ - OUTL(((uint32_t)addr & 0x01FFFF) | 0x1E0000 | (val << 24), - io_base_addr + bios_rom_addr); - - return val; -} - #else #error PCI port I/O access is not supported on this architecture yet. #endif diff --git a/satamv.c b/satamv.c index 2640b78..30b7c34 100644 --- a/satamv.c +++ b/satamv.c @@ -38,10 +38,41 @@ #define PCI_BAR2_CONTROL 0x00c08 #define GPIO_PORT_CONTROL 0x104f0
+/* BAR2 (MEM) can map NVRAM and flash. We set it to flash in the init function. + * If BAR2 is disabled, it still can be accessed indirectly via BAR1 (I/O). + * This code only supports indirect accesses for now. + */ + +/* Indirect access to via the I/O BAR1. */ +static void satamv_indirect_chip_writeb(uint8_t val, chipaddr addr) +{ + /* 0x80000000 selects BAR2 for remapping. */ + OUTL(((uint32_t)addr | 0x80000000) & 0xfffffffc, mv_iobar); + OUTB(val, mv_iobar + 0x80 + (addr & 0x3)); +} + +/* Indirect access to via the I/O BAR1. */ +static uint8_t satamv_indirect_chip_readb(const chipaddr addr) +{ + /* 0x80000000 selects BAR2 for remapping. */ + OUTL(((uint32_t)addr | 0x80000000) & 0xfffffffc, mv_iobar); + return INB(mv_iobar + 0x80 + (addr & 0x3)); +} + +/* FIXME: Prefer direct access to BAR2 if BAR2 is active. */ static void satamv_chip_writeb(const struct flashctx *flash, uint8_t val, - chipaddr addr); + chipaddr addr) +{ + satamv_indirect_chip_writeb(val, addr); +} + +/* FIXME: Prefer direct access to BAR2 if BAR2 is active. */ static uint8_t satamv_chip_readb(const struct flashctx *flash, - const chipaddr addr); + const chipaddr addr) +{ + return satamv_indirect_chip_readb(addr); +} + static const struct par_master par_master_satamv = { .chip_readb = satamv_chip_readb, .chip_readw = fallback_chip_readw, @@ -153,41 +184,6 @@ return 0; }
-/* BAR2 (MEM) can map NVRAM and flash. We set it to flash in the init function. - * If BAR2 is disabled, it still can be accessed indirectly via BAR1 (I/O). - * This code only supports indirect accesses for now. - */ - -/* Indirect access to via the I/O BAR1. */ -static void satamv_indirect_chip_writeb(uint8_t val, chipaddr addr) -{ - /* 0x80000000 selects BAR2 for remapping. */ - OUTL(((uint32_t)addr | 0x80000000) & 0xfffffffc, mv_iobar); - OUTB(val, mv_iobar + 0x80 + (addr & 0x3)); -} - -/* Indirect access to via the I/O BAR1. */ -static uint8_t satamv_indirect_chip_readb(const chipaddr addr) -{ - /* 0x80000000 selects BAR2 for remapping. */ - OUTL(((uint32_t)addr | 0x80000000) & 0xfffffffc, mv_iobar); - return INB(mv_iobar + 0x80 + (addr & 0x3)); -} - -/* FIXME: Prefer direct access to BAR2 if BAR2 is active. */ -static void satamv_chip_writeb(const struct flashctx *flash, uint8_t val, - chipaddr addr) -{ - satamv_indirect_chip_writeb(val, addr); -} - -/* FIXME: Prefer direct access to BAR2 if BAR2 is active. */ -static uint8_t satamv_chip_readb(const struct flashctx *flash, - const chipaddr addr) -{ - return satamv_indirect_chip_readb(addr); -} - #else #error PCI port I/O access is not supported on this architecture yet. #endif diff --git a/satasii.c b/satasii.c index c9dfdad..0d22650 100644 --- a/satasii.c +++ b/satasii.c @@ -37,19 +37,6 @@ {0}, };
-static void satasii_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr); -static uint8_t satasii_chip_readb(const struct flashctx *flash, const chipaddr addr); -static const struct par_master par_master_satasii = { - .chip_readb = satasii_chip_readb, - .chip_readw = fallback_chip_readw, - .chip_readl = fallback_chip_readl, - .chip_readn = fallback_chip_readn, - .chip_writeb = satasii_chip_writeb, - .chip_writew = fallback_chip_writew, - .chip_writel = fallback_chip_writel, - .chip_writen = fallback_chip_writen, -}; - static uint32_t satasii_wait_done(void) { uint32_t ctrl_reg; @@ -64,6 +51,48 @@ return ctrl_reg; }
+static void satasii_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr) +{ + uint32_t data_reg; + uint32_t ctrl_reg = satasii_wait_done(); + + /* Mask out unused/reserved bits, set writes and start transaction. */ + ctrl_reg &= 0xfcf80000; + ctrl_reg |= (1 << 25) | (0 << 24) | ((uint32_t) addr & 0x7ffff); + + data_reg = (pci_mmio_readl((sii_bar + 4)) & ~0xff) | val; + pci_mmio_writel(data_reg, (sii_bar + 4)); + pci_mmio_writel(ctrl_reg, sii_bar); + + satasii_wait_done(); +} + +static uint8_t satasii_chip_readb(const struct flashctx *flash, const chipaddr addr) +{ + uint32_t ctrl_reg = satasii_wait_done(); + + /* Mask out unused/reserved bits, set reads and start transaction. */ + ctrl_reg &= 0xfcf80000; + ctrl_reg |= (1 << 25) | (1 << 24) | ((uint32_t) addr & 0x7ffff); + + pci_mmio_writel(ctrl_reg, sii_bar); + + satasii_wait_done(); + + return (pci_mmio_readl(sii_bar + 4)) & 0xff; +} + +static const struct par_master par_master_satasii = { + .chip_readb = satasii_chip_readb, + .chip_readw = fallback_chip_readw, + .chip_readl = fallback_chip_readl, + .chip_readn = fallback_chip_readn, + .chip_writeb = satasii_chip_writeb, + .chip_writew = fallback_chip_writew, + .chip_writel = fallback_chip_writel, + .chip_writen = fallback_chip_writen, +}; + int satasii_init(void) { struct pci_dev *dev = NULL; @@ -104,34 +133,3 @@
return 0; } - -static void satasii_chip_writeb(const struct flashctx *flash, uint8_t val, chipaddr addr) -{ - uint32_t data_reg; - uint32_t ctrl_reg = satasii_wait_done(); - - /* Mask out unused/reserved bits, set writes and start transaction. */ - ctrl_reg &= 0xfcf80000; - ctrl_reg |= (1 << 25) | (0 << 24) | ((uint32_t) addr & 0x7ffff); - - data_reg = (pci_mmio_readl((sii_bar + 4)) & ~0xff) | val; - pci_mmio_writel(data_reg, (sii_bar + 4)); - pci_mmio_writel(ctrl_reg, sii_bar); - - satasii_wait_done(); -} - -static uint8_t satasii_chip_readb(const struct flashctx *flash, const chipaddr addr) -{ - uint32_t ctrl_reg = satasii_wait_done(); - - /* Mask out unused/reserved bits, set reads and start transaction. */ - ctrl_reg &= 0xfcf80000; - ctrl_reg |= (1 << 25) | (1 << 24) | ((uint32_t) addr & 0x7ffff); - - pci_mmio_writel(ctrl_reg, sii_bar); - - satasii_wait_done(); - - return (pci_mmio_readl(sii_bar + 4)) & 0xff; -}
