Attention is currently required from: Evan Benn.
Hello build bot (Jenkins), Edward O'Callaghan,
I'd like you to reexamine a change. Please visit
https://review.coreboot.org/c/flashrom/+/69064
to look at the new patch set (#2).
Change subject: flashrom_tester: Change string types to path types where appropriate ......................................................................
string types were being used for paths to files. Change to Path and PathBuf
BUG=b:243460685 BRANCH=None TEST=/usr/bin/flashrom_tester --flashrom_binary /usr/sbin/flashrom host TEST=/usr/bin/flashrom_tester --libflashrom host
Change-Id: I69531bec5436a60430eae975eeab02c8835962bf Signed-off-by: Evan Benn evanbenn@chromium.org --- M util/flashrom_tester/flashrom/src/cmd.rs M util/flashrom_tester/flashrom/src/flashromlib.rs M util/flashrom_tester/flashrom/src/lib.rs M util/flashrom_tester/src/rand_util.rs M util/flashrom_tester/src/tester.rs M util/flashrom_tester/src/tests.rs 6 files changed, 97 insertions(+), 69 deletions(-)
git pull ssh://review.coreboot.org:29418/flashrom refs/changes/64/69064/2
