Felix Singer has uploaded this change for review. ( https://review.coreboot.org/c/flashrom/+/67891 )
Change subject: buspirate_spi.c: Move variable `dev` into parameter struct ......................................................................
Signed-off-by: Felix Singer felixsinger@posteo.net Change-Id: I5a791f1d9204982d7972eed85ccf8eb10ce02b78 --- M buspirate_spi.c 1 file changed, 23 insertions(+), 9 deletions(-)
git pull ssh://review.coreboot.org:29418/flashrom refs/changes/91/67891/1
diff --git a/buspirate_spi.c b/buspirate_spi.c index cf84c9c..2c551c4 100644 --- a/buspirate_spi.c +++ b/buspirate_spi.c @@ -315,10 +315,13 @@ */ #define BP_DIVISOR(baud) ((4000000/(baud)) - 1)
+struct buspirate_spi_parameters { + char *dev; +}; + static int buspirate_spi_init(const struct programmer_cfg *cfg) { char *tmp; - char *dev; int i; int cnt; unsigned int fw_version_major = 0; @@ -332,13 +335,14 @@ bool psu = false; unsigned char *bp_commbuf; int bp_commbufsize; + struct buspirate_spi_parameters parameters = { 0 };
- dev = extract_programmer_param_str(cfg, "dev"); - if (dev && !strlen(dev)) { - free(dev); - dev = NULL; + parameters.dev = extract_programmer_param_str(cfg, "dev"); + if (parameters.dev && !strlen(parameters.dev)) { + free(parameters.dev); + parameters.dev = NULL; } - if (!dev) { + if (!parameters.dev) { msg_perr("No serial device given. Use flashrom -p buspirate_spi:dev=/dev/ttyUSB0\n"); return 1; } @@ -401,13 +405,13 @@ bp_commbuf = malloc(DEFAULT_BUFSIZE); if (!bp_commbuf) { msg_perr("Out of memory!\n"); - free(dev); + free(parameters.dev); return ERROR_OOM; } bp_commbufsize = DEFAULT_BUFSIZE;
- ret = buspirate_serialport_setup(dev); - free(dev); + ret = buspirate_serialport_setup(parameters.dev); + free(parameters.dev); if (ret) { free(bp_commbuf); return ret;
