Hello People,
I wanted to summarise the information on the time of Dev meeting. At some
point there was an idea to alternate times, but then we discovered that we
got really lucky and there is one time which everyone agrees on. That was
an open question at the last meeting, to confirm the time with those US
folks who were not present. Since no one was replying to the mailing list,
I reached out to folks and confirmed the time is fine.
SUMMARY
#1 Between November …
[View More]and March (inclusive) time of meeting:
Wednesday 21:00-22:00 UTC+0
also known as
Wednesday 13.00-14.00 Pacific Standard Time UTC-8
Wednesday 22.00-23.00 Central European Time UTC+1
Thursday 8.00-9.00am Australian Eastern Daylight Time UTC+11
#2 Between April and September (inclusive) time of meeting:
Thursday 6.00-7.00am UTC+0
also known as
Wednesday 11pm-midnight Pacific Daylight Time UTC-7
Thursday 8.00-9.00am Central European Summer Time UTC+2
Thursday 16.00-17.00 Australian Eastern Standard Time UTC+10
#3 Note that in the last week of March and 4 weeks of October there will be
no meetings, because daylight saving time changes are happening on
different dates in different locations, and setting up meeting time becomes
too complicated.
Once the regularity is stable, I will add info about Dev meeting on the
Contacts page.
Meanwhile:
FAQ
#1 When is the next meeting?
Look into the meeting notes document
<https://docs.google.com/document/d/18qKvEbfPszjsJJGJhwi8kRVDUG3GZkADzQSH6WF…>.
The top entry, on the first page, with the date in the future, and empty
list of attendees - is the next meeting.
#2 How to join the meeting?
On the top it says “to join, click the link”, click the link.
#3 Where is that document?
Meeting notes document is linked to the Home page of flashrom.org,
Developers menu at the bottom of the page.
#4 Do I need an invitation to join the meeting?
No, just join.
Anastasia.
[View Less]
Hi folks,
people often ask me about a potential next release and what is holding
me back. Long story short, I knew about some bad things in our master
branch that make a release impossible and I was very much afraid that
there could be more that I don't know about.
I've been scrolling through the commit log from v1.1 (the last release
I was involved) to today's master. Some of the things I found are simple
like something missing for a flash chip entry. But most of it are things
I'd rather not …
[View More]have on a release branch. And the list turned out to be
much longer than I expected. OTOH, I didn't find issues of the worst
kind I expected.
Not sure how to go on from here. As this is a lot to do, I suggest
that we freeze the master branch for everything that is neither a fix
nor on the list (or a similar case that I missed). I noted sometimes
that we could just drop the code from a release branch. If we'd decide
to do that, we'd also need a plan how to stop the rot on the master
branch.
Below are my raw notes, I don't have the time to write things up nicely.
I noted the commit hash where things began, but tried to take the cur-
rent state into account. For instance, when it's about a new programmer
driver, I was looking at the file, not the initial patch.
Cheers,
Nico
Recommended clean-ups and investigations before v1.3
* cb973683 Added partial meson support which confuses package main-
tainers.
Should we remove it from or disable CLI building on release
branches?
* 71b706f5 Adds some libflashrom APIs with questionable design, buggy
implementation and no visible user. Would be easiest to drop
and add back when somebody needs it.
Open comment. Partially fixed up.
* 86fc9cf7 Open comment. Partially fixed up.
* 05c629be Looks incomplete, flash would be fully erased with
programmers that lack native 4BA command support.
* ad08aef6 Undocumented programmer. disable? drop from realease branch?
* 703de983 Added `spireadmode` param to sb600spi. (How) does it work?
* 13a2ef6c Added `lspcon_i2c_spi`. Too generic name: LSPCon is a concept
but driver seems to be about a specific vendor/chip. No pro-
bing just starts to write to hardcoded addresses. WP code
contains magic numbers, board specific? Implements `spi_
master` but contains hard-coded SPI opcodes. Not documented?
disable? drop from release branch?
* d97f87b0 Added `realtek_mst_i2c_spi`. No probing, starts by toggling
a GPIO. Are GPIO settings board specific? Timeout checks seem
to have regressed since original commit. Not documented?
Changes clock settings, is this board specific? Implements
`spi_master` with special cases in an opcode LUT, doesn't
bail out on unknown codes. Falls back on unaligned reads/
writes, were these paths tested? Fixups suggest that the
original code wasn't properly tested, was it by now?
* be4682dc Might miss some block erasers.
* f82dd300 Might miss some block erasers.
* a2dc4f7f It seems `clear_spi_id_cache()` is never called. Probably,
should be before probing.
* 3149822c Added variable size in `dummy_programmer`. Didn't look
at it right now, but I remember it caused a lot of trouble.
Probably not fully fixed up yet.
* cb9f3cd0 Possible division by zero.
* ca2e3bce Fixed some libpci usage. IIRC, there are many more similar
cases that might need a fix now that libpci is more strict.
* 0386aa17 sb600spi refactoring. Looks like it dropped an error message
from many error paths.
* f745d0e6, adbae0e2 Added infrastructure for S25F chips. Code style
looks a bit outdated. Probably needs upstream review.
* 8fa792fb Added chips with oddities and w/o reasoning, e.g:
.total_size = 16384, /* This is just half the size.... */
Complete patch needs review.
* 855d6b6f Added Ryzen support to sb600spi. API violations. Stalled
other cleanup work. Soft bricks machines with >16MiB flash.
Patches on Gerrit.
* 32f4cb4f Looks like copy-pasta from Winbond chips. Might miss some
block erasers. Missing 4BA_WRITE is probably wrong.
* 45d50a10 Added support code for per-region file arguments. Review was
interrupted, IIRC. Rebase was borked shortly before merge.
Work never finished.
* d4063bf3 Missed to update the manpage. Literal `-` shouldn't be in
* ce983bcc Missed to update the manpage. Filters only spaces when
converting region names to file names.
* 51e1d0e4 Still selects the wrong chipset, IIRC.
* e98b2d11 Review never really started. See comments on Gerrit.
Backport candidates
* 4ca575dc usbdev: Only match requested USB devices
* 8bbb7648 spi95: Check for success before using send_command's returned
data
* b07c53d7 spi25: Debug flashrom crash when Write Protect is ON
Looks like this covers up a general problem with flash-chip
entries. Why would we know how to disable block protection
if we don't know how to report it? Should probably be added
to self checks.
* 51261541 it87spi.c: Prevent use-after-free bug
* da0825f0 chipset_enable.c: check return value from rphysmap() call
* 705212da chipset_enable.c: Validate physmap() return rcrb value
* b76d2810 dediprog: Fix segmentation fault on no device found
* 1a21cc70 helpers.c: Fix undefined behavior in strndup()
* a2f2f3f5 linux_mtd: Disable buffering on the mtd device
* ab623c65 jlink_spi: Reduce transfer size
* Many fixes in dummy_flasher, not sure if they were applicable earlier.
* aedfb7eb flashrom.8: add missing entry for `--flash-contents`
* 89c73b5a linux_mtd: check ioctl() return value properly
[View Less]
Dear fellow flashrom developers,
I've been reflecting lately about written and unwritten rules around our
review process and our related privileges on Gerrit. I couldn't identify
anything that works well, or let's say well enough. So it might be time
we discuss some things and make changes :)
Before the dawn of our Git repository and using Gerrit as a review plat-
form, we had a Subversion repository. With very few people, usually one
or two I think, that had write access. So practically we …
[View More]had gatekeepers
that watched over the code. Eventually, they became a bottleneck so we
widened that a little when starting the work on Gerrit. Today, I often
catch myself falling back into such a gatekeeper mode. Which is futile
anyway because I'm not the only one who can write to the repository. But
I still wonder why this happens and if it's necessary.
I guess first everyone needs to understand how we imagined things with
Gerrit and how it looks like today. As mentioned above we set up a group
"flashrom developers" which has exclusive write access to the reposi-
tory. The idea was to only have people in this group who are long-term
(I was thinking about years) contributors to flashrom, know each other
from real-time communication (IRC) and trust each other. For the review
right "+2", we used the "Reviewers" group from coreboot. IIRC, I pushed
for the latter. I was hoping to grow the communities a little together
that seemed to have gone separate ways in the years before. After all,
a lot of coreboot developers use flashrom in their everyday work.
Combined with the "flashrom developers" group it shouldn't have been
an issue that people with little flashrom knowledge would review.
Since the original setup (about 2017) things went on rather uncon-
trolled. I think the gist of it is that people didn't expect that
flashrom would need/have different rules compared to coreboot. At
some point somebody whom I only knew from their work on coreboot sud-
denly merged patches for flashrom. And I guess people pushing patches
today pretty much expect that there is nothing more to be done once
they see the first +2. No matter if the reviewer knows anything about
flashrom.
When reviewers disagree then, it can become frustrating for everyone.
So currently, I lean towards aligning our process more with that of
coreboot. The big difference seems to be that at coreboot merging
patches, i.e. hitting the "Submit" button, is more or less considered
an administrative task unrelated to one's opinion on the code. While
for us it was supposed to replace the gatekeeping. Changing this would
imply that we need our own group of reviewers. With this, a +2 would
become both rarer and stronger. If this idea meets some consent, I
would propose to copy the "flashrom developers" group for a start.
And when we identify somebody over time who shows in-depth knowledge
about at least a part of flashrom and good self-judgement if they
are experienced enough for a +2, we could add them. Right now, some
candidates come to mind already, Peter, Nikolai, and Thomas.
The "flashrom developers" group also grants the privilege to block
"-2" a change. I have very conflicting feelings about this. On one
hand, this is a tool that is only ever necessary when people in said
group can't trust each other. On the other, that seems to be the
status quo already. Maybe we should have another group on top for
this? This time really only for trusted, established, long-term
contributors? Or maybe for those who maintain the codebase beyond
what they are paid for?
There is one related idea for a rule that crossed my mind: How about
we forbid blocking reverts that fix a regression and apply cleanly
(i.e. without needing to revert anything else in advance). Also, let
them pass after review without waiting 24 hours. At least for myself
this would reduce a lot pressure to fall back to gatekeeping if I knew
I could keep things safe and sound without discussion. For maintainers,
the patches that are already merged matter the most, cause the most
work. This should also be the case for contributors, but alas many
don't see it like this and don't help to fix things after a patch is
merged. Easing reverts would push the hard work back to the people
who break things.
Looks a bit longer than what I intended to write, as usual when one
starts writing ;) If we come to a conclusion wrt. Gerrit privileges,
we could also discuss more rules for each role. While I'm not a fan
of too many rules and would rather keep things to common sense, these
things depend much on the people we add to the respective groups.
I hope it's not too much to digest at once ;)
Cheers,
Nico
[View Less]
Hello there,
I hope you are well today when you receive this email. I am Aarya Chaumal,
a Computer Engineering student at the College of Engineering Pune, India.
While going through organizations for this year's Google's Summer of Code I
came across your organization, Flashrom.
I am a part of onboard computers subsystem at my college's satellite
initiative. Through this, I have closely worked on Atmel SAM E70 XPLAINED
board. Also, I have strong knowledge about C/C++ and assembly language.
[View More]From your list of GSoC project ideas, I liked the idea of “Remove global
state from flashrom” and "Optimize Erase-Function Selection", although I am
not quite sure which one is more suitable for me. Can you guide me through
this?
As mentioned in your Contributor commitments and requirements, I started to
do one of the easy projects - Add new flash chip definitions. For this, I
read the relevant datasheets, one from the unlisted chips and another of a
listed one (for reference) but still, I am not getting the information
about some fields for the structure in the datasheet, namely the
feature_bits, probe_timing. Also, do I have to write the probe, read, write
and erase functions for the chip separately? Also, how do I test if my code
is working as I don't have relevant hardware with me? Can you help me with
this? Also what resources should I use to learn more about it?
Thank you for looking into this for me.
Sincerely,
Aarya Chaumal
[View Less]
Issue #352 has been reported by Felix Singer.
Bug #352: test issue for mailing list
https://ticket.coreboot.org/issues/352
* Author: Felix Singer
* Status: New
* Priority: Normal
* Target version: none
* Start date: 2022-04-25
This is a test issue for the flashrom mailing list.
You have received this notification because you have either subscribed to it, or are involved in it.
To change your notification …
[View More]preferences, please click here: https://ticket.coreboot.org/my/account
[View Less]
Datasheet at:
https://www.dialog-semiconductor.com/sites/default/files/2021-02/DS-AT25SF1…
Probing for Unknown SFDP-capable chip, 0 kB: SFDP revision = 1.0
SFDP number of parameter headers is 2 (NPH = 1).
SFDP parameter table header 0/1:
ID 0x00, version 1.0
Length 36 B, Parameter Table Pointer 0x000030
Parsing JEDEC flash parameter table...
3-Byte only addressing.
Status register is non-volatile and the standard does not allow vendors
to tell us whether EWSR/WREN is needed for status …
[View More]register writes -
assuming EWSR.
Write chunk size is at least 64 B.
Flash chip size is 16384 kB.
Block eraser 0: 4096 x 4096 B with opcode 0x20
Tried to add a duplicate block eraser: 4096 x 4096 B with opcode 0x20.
Block eraser 1: 512 x 32768 B with opcode 0x52
Block eraser 2: 256 x 65536 B with opcode 0xd8
done.
SFDP parameter table header 1/1:
ID 0x1f, version 1.0
Length 12 B, Parameter Table Pointer 0x000060
SFDP has autodetected a flash chip which is not natively supported by
flashrom yet.
All standard operations (read, verify, erase and write) should work, but to
support all possible features we need to add them manually.
You can help us by mailing us the output of the following command to
flashrom(a)flashrom.org:
'flashrom -VV [plus the -p/--programmer parameter]'
Thanks for your help!
[View Less]
Hello People,
Few weeks ago at the flashrom meeting we had a discussion about code
reviews and the situations that sometimes happen. We decided that it
would be good to have some guidelines… and then we decided that I will
start writing something. I have been thinking about it since then. I
even started writing something, but I wasn’t happy at all: it felt
like composing a wall of text that no one would be reading.
I decided to think about: what problems are we solving? And then it
got much …
[View More]better. I gathered the list of problems that I think are
present and repeatedly happen during code reviews. All of the below is
RFC and of course, if there is a problem that is missing, please tell.
I would really appreciate everyone’s opinions on this!
What I suggest is: after agreeing on the list of problems, compose and
agree the answers to them (yes easier to say then to do :)), and then
it can be like “Code Reviews FAQ” or something like that? Especially
if we can encourage people to read the other point of view first.
## Contributor point of view ##
#1 Is this comment a conversation or an action item?
#2 Is this comment blocking patch from merging or non-blocking?
#3 Are we waiting for anyone [else] to have a look at this patch?
#4 Is my patch ready to be merged? / Why is my patch not being merged?
#5 Who are the best reviewers for this patch?
#6 This patch is a real emergency, what is the process for that?
## Reviewer / Maintainer point of view ##
#1 My important comment(s) got ignored and the patch was merged regardless.
#2 I have so many code reviews, and everyone wants it fast and
complains reviews are too slow.
#3 A patch that was merged broke something, but people don't want to revert.
#4 I asked the patch owner to fix something, but they are arguing with
me instead, and wasting everyone's time.
#5 What this patch is doing, and why is it needed?
#6 I want to review the patch, but I am busy for the next X weeks.
Anastasia.
[View Less]
Hi,
Unable to read “Boyamicro” SPI chip? Any workaround?
Thanks.
ack@ack:~$ flashrom -p ft2232_spi:type=2232H,port=B,divisor=4 -r firmware.bin
flashrom v1.2 on Linux 5.13.0-40-generic (x86_64)
flashrom is free software, get the source code at https://flashrom.org
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
Found Generic flash chip "unknown SPI chip (RDID)…
[View More]" (0 kB, SPI) on ft2232_spi.
This flash part has status NOT WORKING for operations: PROBE READ ERASE WRITE
The test status of this chip may have been updated in the latest development
version of flashrom. If you are running the latest development version,
please email a report to flashrom(a)flashrom.org<mailto:flashrom@flashrom.org> if any of the above operations
work correctly for you with this flash chip. Please include the flashrom log
file for all operations you tested (see the man page for details), and mention
which mainboard or programmer you tested in the subject line.
Read is not working on this chip. Aborting.
[View Less]
# 21th April 2022, 6:00 - 7:00 am UTC+0
Attendees: Thomas, David, Edward, Nico, Anastasia, Nikolai
## Decisions Summary
* Anastasia will be doing next release. She has never done release
before, and needs help from more experienced people.
## Agenda
* [FelixS] Redmine is ready to use
* If you wonder, new registrations require an unlock by an
administrator. This is to prevent spamming and bots. Maybe we can work
out something better in the future.
* I added additional fields to …
[View More]issues, so that important
information is easily visible. For example affected hardware, affected
OS, affected version. Please tell me if you find these useful or if you
need other fields, trackers, ..
* aklm: let’s start using, I will try to create an account and see
how it goes
* [FelixS] Created a proposal for closing GitHub issues and pull
requests automatically
* Closes newly created issues and pull requests and adds a comment
using GitHub Actions hook. Old issues and pull requests stay untouched.
* [flashrom patch](https://review.coreboot.org/c/flashrom/+/63671),
based on GitHub Actions hook and [repo-
lockdown](https://github.com/dessant/repo-lockdown).
* My playground
[https://github.com/felixsinger/awesome-repo](https://github.com/felixsinger…
* [Nico] ChromeOS fork and attempted convergence
* (in case witnesses of that time are present) What led to the
fork?
* [PatrickG] Velocity requirements: stuff needed to happen to
make progress on the products using flashrom and it didn’t happen in
time. Not much of a problem when it’s temporary but stuff just piled up
over time.
* Nico: lots of things went wrong. And it took around 8 months
to converge
* David: Fork happened when Carl-Daniel was the maintainer, and
he was really busy. Tools were worse that time.
* We had irreconcilable differences at that time
* Edward: Stefan asked me to unfork flashrom. I had to work out
how things were done, how to re-write parts of the system. It was just
me, on my own, no other resources. I took upstream and tried to make
chrome os work with upstream. Except for a few patches: mapping hack
inside of sb600spi, I am trying to chase AMD to get documentation , so
that I can improve it.
* David: Timer stuff I was trying to deal locally. There were a
bunch of things that had to be dealt locally.
* David: It was uglier downstream than it should have been.
Trying to minimize the number of hacks. There are things that can be tr
* Edward: Where we are today: I was trying to have a team for
flashrom, to spend dedicated time to work on flashrom. We had good
results on that, but it takes time. Hard to allocate people.
* (in case somebody knows) What is Google’s current strategy to
avoid repeating mistakes of the past?
* [PatrickG] Generally CrOS is willing to go upstream-first (as
with coreboot) after divergence has been resolved. Depends on the
upstream, so probably need to work on the questions raised by Edward et
al.
* [Nico] Upstream-first of a dominant vendor made it harder
for others to work upstream on coreboot. It’s not what I had in mind,
but this would be repeating a mistake, IMHO.
* Nico: There were very good and very bad contributions
during last years
* Edward: how do you quantify that nothing is happening?
* Nico : sb600 is bricking machines , but nothing is
happening
* Edward: maybe it is a visibility problem, also some
things are really hard
* Nico: maybe devs in google need to talk to each other?
* Edward: original patch came from AMD, not from google
* Nico: if it takes a long time to find a solution, maybe
just revert?
* Edward: we didn’t know it would take so long
* David: board bringup. There is 3-4 months time before
chromebooks get into users hands, and then bugs get filed. Bugs in the
code which is 6 months old, but people are already reassigned to other
tasks.
* Edward: maybe have a parameter which turns on the
behaviour, default is turned off. The problem exists, but it is not
trivial.
* Nico: The problem with the “upstream-first” idea: when
something is not trivial, you push it upstream first, and then try to
figure out how to fix it.
* Edward: that was exceptional situation, it is better now
* Nico: most of the issues in the list are from google.
When someone looks at the code, it is clear that code it is not
understood.
* Edward: we opened issues about non-documented programmer,
and added documentation
* Nico: one of the drivers is mixing all layers of
flashrom.
* Nikolai: what are concerns with the code? We will try to
remove them.
* Edward: The datasheet was in mandarin, and lots of
questions were discussed in mandarin with the vendor. Vendors were not
giving documentation, despite us asking them many times.
* Nico: Who is doing reviews for google? We need reviewers
who know all layers of flashrom.
* David: Can we simplify the process of adding a new
chipset? So that it would be easier to contribute without introducing
bugs?
* Thomas: It would be nice to have more structure in the
code repository. It is hard to understand where the code needs to go.
Having a specific place for every component is a good idea
* David : flash.h and flashrom.c are dumping grounds
* Anastasia: Nico do you think it is possible so that we
all work together normally and peacefully? If we resolve issues from
the past, and also write guidelines so that new issues won’t appear and
development goes normally? >> Yes it is possible.
* Let's make a release!
* Nico: I spent a lot of time on this already, I can’t
spend even more time. Anyone else?
* Nikolai: What if the vendor does not give documentation,
do you think it’s better to have a driver which is not documented, or
no driver at all?
* David: for early chromebooks , drivers were not
documented. That’s why an option was called “I want brick”
* Edward: some of the changes in the chromium tree we are
not sending upstream, because there is no documentation
* Nikolai: Can we have a flag for situations like sb600spi
? Finer granularity than the whole driver. Feature flags?
* Nico: other people work on the sb600spi code, affects
everyone who works on the code.
* Edward: something similar in kernel hardware quark
framework.
* Nico: this needs documentation, whatever is needed to
understand the quark. Man pages are for the users, but there also
should be documentation for developers. In what product is this chip?
You can document what you know
* [dhendrix] Is this the kind of finger pointing that Edward
mentioned above? At this point, CrOS has proved more than happy to move
upstream. The Github mirror is probably more of a concern. Perhaps
upstream should consider how to get developers to choose upstream
rather than the Github mirror or some other fork.
* [Nico] Pointing at Google, actually. If one company forks
and later wants their code upstream without proper review, something
seems wrong. As if they never reflected on the problems.
* [aklm] I am not sure we are on the same page on what are
“mistakes of the past”. Everyone has their own idea on what the
mistakes were. I can start from myself. From my observations,
converging the code was considered a purely technical task, and so it
was done as a technical task. However, converging the code means
converging the people/the teams, converging very different workflows
and work cultures. This does not seem to be thought through or ever
discussed, and to me this is a mistake.
* [quasisec] I am also unclear how CrOS convergence had really
much of an impact on upstream considering >99% of the work was
adjusting the CrOS fork to realign with upstream. Only an extremely
small amount of alignment was in the form of upstream commits, e.g.,
missing raiden_debug and some unfortunate part of sb600spi. Is there a
specific area that stands out?
* [Nico] No idea if related to the original reasons for the
fork, but that the convergence is stalling new releases for years
stands out pretty much.
* Anastasia: We currently have more GSOC project proposals than mentors
(5 vs 3). If someone wants to be a mentor, it is not too late. Contact
Anastasia or Felix.
[View Less]
