Forwarding filtered message w/o the huge attachment.
It showed the usual
SMBus revision 0x61 does not match any known values.
Nico
-------- Forwarded Message --------
Subject: Bug with AMD chipset.
Date: Sat, 08 Jan 2022 18:17:05 +0000
From: IlIlIIIIlIlIIIIIlIlIlIIlI <IlIlIIIIlIlIIIIIlIlIlIIlI(a)protonmail.com>
Reply-To: IlIlIIIIlIlIIIIIlIlIlIIlI
To: flashrom(a)flashrom.org <flashrom(a)flashrom.org>
Hello, I've got a bug with Flashrom on AMD CPU and chipset.
Here is an output from Flashrom...
[7208f703_IMG_20220108_185448.jpg]
... and from lspci -nnvx.
> 00:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex [1022:1480]
> Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex [1022:1480]
> Flags: fast devsel
> 00: 22 10 80 14 00 00 00 00 00 00 00 06 00 00 80 00
> 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> 20: 00 00 00 00 00 00 00 00 00 00 00 00 22 10 80 14
> 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> 00:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU [1022:1481]
> Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU [1022:1481]
> Flags: fast devsel, IRQ 25
> Capabilities: [40] Secure device <?>
> Capabilities: [64] MSI: Enable+ Count=1/4 Maskable- 64bit+
> Capabilities: [74] HyperTransport: MSI Mapping Enable+ Fixed+
> Capabilities: [c8] Vendor Specific Information: Len=18 <?>
> 00: 22 10 81 14 40 04 10 00 00 00 06 08 00 00 80 00
> 20: 00 00 00 00 00 00 00 00 00 00 00 00 22 10 81 14
> 30: 00 00 00 00 40 00 00 00 00 00 00 00 ff 00 00 00
> 00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
> Flags: fast devsel, IOMMU group 0
> 00: 22 10 82 14 00 00 00 00 00 00 00 06 00 00 80 00
> 20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> 00:01.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483] (prog-if 00 [Normal decode])
> Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 1
> Bus: primary=00, secondary=01, subordinate=05, sec-latency=0
> I/O behind bridge: 0000f000-0000ffff [size=4K]
> Memory behind bridge: fcc00000-fcdfffff [size=2M]
> Prefetchable memory behind bridge: 00000000e0000000-00000000e00fffff [size=1M]
> Capabilities: [50] Power Management version 3
> Capabilities: [58] Express Root Port (Slot+), MSI 00
> Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
> Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1234]
> Capabilities: [c8] HyperTransport: MSI Mapping Enable+ Fixed+
> Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
> Capabilities: [150] Advanced Error Reporting
> Capabilities: [270] Secondary PCI Express
> Capabilities: [2a0] Access Control Services
> Capabilities: [370] L1 PM Substates
> Capabilities: [3c4] Designated Vendor-Specific: Vendor=1022 ID=0001 Rev=1 Len=44 <?>
> Capabilities: [400] Data Link Feature <?>
> Capabilities: [410] Physical Layer 16.0 GT/s <?>
> Capabilities: [440] Lane Margining at the Receiver <?>
> Kernel driver in use: pcieport
> 00: 22 10 83 14 07 04 10 00 00 00 04 06 10 00 81 00
> 10: 00 00 00 00 00 00 00 00 00 01 05 00 f1 f1 00 20
> 20: c0 fc d0 fc 01 e0 01 e0 00 00 00 00 00 00 00 00
> 30: 00 00 00 00 50 00 00 00 00 00 00 00 ff 00 12 00
> 00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
> Flags: fast devsel, IOMMU group 2
> 00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
> Flags: fast devsel, IOMMU group 3
> 00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483] (prog-if 00 [Normal decode])
> Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 4
> Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
> I/O behind bridge: 0000e000-0000efff [size=4K]
> Memory behind bridge: fcf00000-fcffffff [size=1M]
> Prefetchable memory behind bridge: 00000000d0000000-00000000dfffffff [size=256M]
> 10: 00 00 00 00 00 00 00 00 00 06 06 00 e1 e1 00 20
> 20: f0 fc f0 fc 01 d0 f1 df 00 00 00 00 00 00 00 00
> 30: 00 00 00 00 50 00 00 00 00 00 00 00 ff 00 1a 00
> 00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
> Flags: fast devsel, IOMMU group 5
> 00:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
> Flags: fast devsel, IOMMU group 6
> 00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
> Flags: fast devsel, IOMMU group 7
> 00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484] (prog-if 00 [Normal decode])
> Flags: bus master, fast devsel, latency 0, IRQ 30, IOMMU group 8
> Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
> I/O behind bridge: [disabled]
> Memory behind bridge: [disabled]
> Prefetchable memory behind bridge: [disabled]
> Capabilities: [58] Express Root Port (Slot-), MSI 00
> Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
> 00: 22 10 84 14 07 04 10 00 00 00 04 06 10 00 81 00
> 10: 00 00 00 00 00 00 00 00 00 07 07 00 f1 01 00 00
> 20: f0 ff 00 00 f1 ff 01 00 00 00 00 00 00 00 00 00
> 30: 00 00 00 00 50 00 00 00 00 00 00 00 ff 01 12 00
> 00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
> Flags: fast devsel, IOMMU group 9
> 00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484] (prog-if 00 [Normal decode])
> Flags: bus master, fast devsel, latency 0, IRQ 31, IOMMU group 10
> Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
> Memory behind bridge: fc900000-fcbfffff [size=3M]
> 10: 00 00 00 00 00 00 00 00 00 08 08 00 f1 01 00 00
> 20: 90 fc b0 fc f1 ff 01 00 00 00 00 00 00 00 00 00
> 00:08.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484] (prog-if 00 [Normal decode])
> Flags: bus master, fast devsel, latency 0, IRQ 32, IOMMU group 11
> Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
> Memory behind bridge: fce00000-fcefffff [size=1M]
> 10: 00 00 00 00 00 00 00 00 00 09 09 00 f1 01 00 00
> 20: e0 fc e0 fc f1 ff 01 00 00 00 00 00 00 00 00 00
> 00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 61)
> Subsystem: Gigabyte Technology Co., Ltd FCH SMBus Controller [1458:5001]
> Flags: 66MHz, medium devsel, IOMMU group 12
> Kernel modules: i2c_piix4, sp5100_tco
> 00: 22 10 0b 79 03 04 20 02 61 00 05 0c 00 00 80 00
> 20: 00 00 00 00 00 00 00 00 00 00 00 00 58 14 01 50
> 00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
> Subsystem: Gigabyte Technology Co., Ltd FCH LPC Bridge [1458:5001]
> Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 12
> 00: 22 10 0e 79 0f 00 20 02 51 00 01 06 00 00 80 00
> 00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0 [1022:1440]
> Flags: fast devsel, IOMMU group 13
> 00: 22 10 40 14 00 00 00 00 00 00 00 06 00 00 80 00
> 00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1 [1022:1441]
> 00: 22 10 41 14 00 00 00 00 00 00 00 06 00 00 80 00
> 00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2 [1022:1442]
> 00: 22 10 42 14 00 00 00 00 00 00 00 06 00 00 80 00
> 00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3 [1022:1443]
> Kernel driver in use: k10temp
> Kernel modules: k10temp
> 00: 22 10 43 14 00 00 00 00 00 00 00 06 00 00 80 00
> 00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4 [1022:1444]
> 00: 22 10 44 14 00 00 00 00 00 00 00 06 00 00 80 00
> 00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5 [1022:1445]
> 00: 22 10 45 14 00 00 00 00 00 00 00 06 00 00 80 00
> 00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6 [1022:1446]
> 00: 22 10 46 14 00 00 00 00 00 00 00 06 00 00 80 00
> 00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7 [1022:1447]
> 00: 22 10 47 14 00 00 00 00 00 00 00 06 00 00 80 00
> 01:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset USB 3.1 XHCI Controller [1022:43d5] (rev 01) (prog-if 30 [XHCI])
> Subsystem: ASMedia Technology Inc. 400 Series Chipset USB 3.1 XHCI Controller [1b21:1142]
> Flags: bus master, fast devsel, latency 0, IRQ 58, IOMMU group 14
> Memory at fcda0000 (64-bit, non-prefetchable) [size=32K]
> Capabilities: [50] MSI: Enable+ Count=1/8 Maskable- 64bit+
> Capabilities: [78] Power Management version 3
> Capabilities: [80] Express Legacy Endpoint, MSI 00
> Capabilities: [100] Advanced Error Reporting
> Capabilities: [200] Secondary PCI Express
> Capabilities: [300] Latency Tolerance Reporting
> Capabilities: [400] L1 PM Substates
> Kernel driver in use: xhci_hcd
> Kernel modules: xhci_pci
> 00: 22 10 d5 43 06 04 10 00 01 30 03 0c 10 00 80 00
> 10: 04 00 da fc 00 00 00 00 00 00 00 00 00 00 00 00
> 20: 00 00 00 00 00 00 00 00 00 00 00 00 21 1b 42 11
> 30: 00 00 00 00 50 00 00 00 00 00 00 00 0b 01 00 00
> 01:00.1 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset SATA Controller [1022:43c8] (rev 01) (prog-if 01 [AHCI 1.0])
> Subsystem: ASMedia Technology Inc. 400 Series Chipset SATA Controller [1b21:1062]
> Flags: bus master, fast devsel, latency 0, IRQ 40, IOMMU group 14
> Memory at fcd80000 (32-bit, non-prefetchable) [size=128K]
> Expansion ROM at fcd00000 [disabled] [size=512K]
> Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
> Kernel driver in use: ahci
> Kernel modules: ahci
> 00: 22 10 c8 43 06 04 10 00 01 01 06 01 10 00 80 00
> 20: 00 00 00 00 00 00 d8 fc 00 00 00 00 21 1b 62 10
> 30: 00 00 d0 fc 50 00 00 00 00 00 00 00 0a 02 00 00
> 01:00.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Bridge [1022:43c6] (rev 01) (prog-if 00 [Normal decode])
> Flags: bus master, fast devsel, latency 0, IRQ 33, IOMMU group 14
> Bus: primary=01, secondary=02, subordinate=05, sec-latency=0
> Memory behind bridge: fcc00000-fccfffff [size=1M]
> Capabilities: [80] Express Upstream Port, MSI 00
> Capabilities: [c0] Subsystem: ASMedia Technology Inc. 400 Series Chipset PCIe Bridge [1b21:0201]
> 00: 22 10 c6 43 07 04 10 00 01 00 04 06 10 00 81 00
> 10: 00 00 00 00 00 00 00 00 01 02 05 00 f1 f1 00 00
> 20: c0 fc c0 fc 01 e0 01 e0 00 00 00 00 00 00 00 00
> 30: 00 00 00 00 50 00 00 00 00 00 00 00 05 03 12 00
> 02:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01) (prog-if 00 [Normal decode])
> Flags: bus master, fast devsel, latency 0, IRQ 35, IOMMU group 14
> Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
> Capabilities: [80] Express Downstream Port (Slot+), MSI 00
> Capabilities: [c0] Subsystem: ASMedia Technology Inc. 400 Series Chipset PCIe Port [1b21:3306]
> 00: 22 10 c7 43 07 04 10 00 01 00 04 06 10 00 01 00
> 10: 00 00 00 00 00 00 00 00 02 03 03 00 f1 01 00 00
> 30: 00 00 00 00 50 00 00 00 00 00 00 00 0b 01 12 00
> 02:01.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01) (prog-if 00 [Normal decode])
> Flags: bus master, fast devsel, latency 0, IRQ 37, IOMMU group 14
> Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
> 10: 00 00 00 00 00 00 00 00 02 04 04 00 f1 f1 00 00
> 30: 00 00 00 00 50 00 00 00 00 00 00 00 0a 01 12 00
> 02:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01) (prog-if 00 [Normal decode])
> Flags: bus master, fast devsel, latency 0, IRQ 38, IOMMU group 14
> Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
> 10: 00 00 00 00 00 00 00 00 02 05 05 00 f1 01 00 00
> 04:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 0c)
> Subsystem: Gigabyte Technology Co., Ltd Onboard Ethernet [1458:e000]
> Flags: bus master, fast devsel, latency 0, IRQ 36, IOMMU group 14
> I/O ports at f000 [size=256]
> Memory at fcc00000 (64-bit, non-prefetchable) [size=4K]
> Memory at e0000000 (64-bit, prefetchable) [size=16K]
> Capabilities: [40] Power Management version 3
> Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
> Capabilities: [70] Express Endpoint, MSI 01
> Capabilities: [b0] MSI-X: Enable+ Count=4 Masked-
> Capabilities: [d0] Vital Product Data
> Capabilities: [140] Virtual Channel
> Capabilities: [160] Device Serial Number 01-00-00-00-68-4c-e0-00
> Capabilities: [170] Latency Tolerance Reporting
> Kernel driver in use: r8169
> Kernel modules: r8169
> 00: ec 10 68 81 07 04 10 00 0c 00 00 02 10 00 00 00
> 10: 01 f0 00 00 00 00 00 00 04 00 c0 fc 00 00 00 00
> 20: 0c 00 00 e0 00 00 00 00 00 00 00 00 58 14 00 e0
> 30: 00 00 00 00 40 00 00 00 00 00 00 00 0a 01 00 00
> 06:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Oland PRO [Radeon R7 240/340] [1002:6613] (prog-if 00 [VGA controller])
> Subsystem: Micro-Star International Co., Ltd. [MSI] Oland PRO [Radeon R7 240/340] [1462:8094]
> Flags: bus master, fast devsel, latency 0, IRQ 76, IOMMU group 15
> Memory at d0000000 (64-bit, prefetchable) [size=256M]
> Memory at fcf00000 (64-bit, non-prefetchable) [size=256K]
> I/O ports at e000 [size=256]
> Expansion ROM at 000c0000 [disabled] [size=128K]
> Capabilities: [48] Vendor Specific Information: Len=08 <?>
> Capabilities: [58] Express Legacy Endpoint, MSI 00
> Kernel driver in use: radeon
> Kernel modules: radeon, amdgpu
> 00: 02 10 13 66 07 04 10 00 00 00 00 03 10 00 80 00
> 10: 0c 00 00 d0 00 00 00 00 04 00 f0 fc 00 00 00 00
> 20: 01 e0 00 00 00 00 00 00 00 00 00 00 62 14 94 80
> 30: 00 00 f4 fc 48 00 00 00 00 00 00 00 0b 01 00 00
> 06:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series] [1002:aab0]
> Subsystem: Micro-Star International Co., Ltd. [MSI] Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series] [1462:aab0]
> Flags: bus master, fast devsel, latency 0, IRQ 73, IOMMU group 15
> Memory at fcf60000 (64-bit, non-prefetchable) [size=16K]
> Kernel driver in use: snd_hda_intel
> Kernel modules: snd_hda_intel
> 00: 02 10 b0 aa 07 04 10 00 00 00 03 04 10 00 80 00
> 10: 04 00 f6 fc 00 00 00 00 00 00 00 00 00 00 00 00
> 20: 00 00 00 00 00 00 00 00 00 00 00 00 62 14 b0 aa
> 30: 00 00 00 00 48 00 00 00 00 00 00 00 0a 02 00 00
> 07:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
> Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
> Flags: fast devsel, IOMMU group 16
> Capabilities: [64] Express Endpoint, MSI 00
> 00: 22 10 8a 14 00 00 10 00 00 00 00 13 10 00 00 00
> 20: 00 00 00 00 00 00 00 00 00 00 00 00 22 10 8a 14
> 30: 00 00 00 00 48 00 00 00 00 00 00 00 ff 00 00 00
> 08:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
> Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
> Flags: fast devsel, IOMMU group 17
> 00: 22 10 85 14 00 00 10 00 00 00 00 13 10 00 80 00
> 20: 00 00 00 00 00 00 00 00 00 00 00 00 22 10 85 14
> 08:00.1 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP [1022:1486]
> Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP [1022:1486]
> Flags: bus master, fast devsel, latency 0, IRQ 68, IOMMU group 18
> Memory at fca00000 (32-bit, non-prefetchable) [size=1M]
> Memory at fcb08000 (32-bit, non-prefetchable) [size=8K]
> Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
> Capabilities: [c0] MSI-X: Enable+ Count=2 Masked-
> Capabilities: [370] Transaction Processing Hints
> Kernel driver in use: ccp
> Kernel modules: ccp
> 00: 22 10 86 14 06 04 10 08 00 00 80 10 10 00 80 00
> 10: 00 00 00 00 00 00 00 00 00 00 a0 fc 00 00 00 00
> 20: 00 00 00 00 00 80 b0 fc 00 00 00 00 22 10 86 14
> 30: 00 00 00 00 48 00 00 00 00 00 00 00 05 01 00 00
> 08:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c] (prog-if 30 [XHCI])
> Subsystem: Gigabyte Technology Co., Ltd Matisse USB 3.0 Host Controller [1458:5007]
> Flags: bus master, fast devsel, latency 0, IRQ 59, IOMMU group 19
> Memory at fc900000 (64-bit, non-prefetchable) [size=1M]
> Capabilities: [a0] MSI: Enable- Count=1/8 Maskable- 64bit+
> Capabilities: [c0] MSI-X: Enable+ Count=8 Masked-
> 00: 22 10 9c 14 07 04 10 00 00 30 03 0c 10 00 80 00
> 10: 04 00 90 fc 00 00 00 00 00 00 00 00 00 00 00 00
> 20: 00 00 00 00 00 00 00 00 00 00 00 00 58 14 07 50
> 30: 00 00 00 00 48 00 00 00 00 00 00 00 0a 03 00 00
> 08:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
> Subsystem: Gigabyte Technology Co., Ltd Starship/Matisse HD Audio Controller [1458:a182]
> Flags: bus master, fast devsel, latency 0, IRQ 75, IOMMU group 20
> Memory at fcb00000 (32-bit, non-prefetchable) [size=32K]
> 00: 22 10 87 14 06 04 10 00 00 00 03 04 10 00 80 00
> 10: 00 00 b0 fc 00 00 00 00 00 00 00 00 00 00 00 00
> 20: 00 00 00 00 00 00 00 00 00 00 00 00 58 14 82 a1
> 30: 00 00 00 00 48 00 00 00 00 00 00 00 0b 04 00 00
> 09:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51) (prog-if 01 [AHCI 1.0])
> Subsystem: Gigabyte Technology Co., Ltd FCH SATA Controller [AHCI mode] [1458:b002]
> Flags: bus master, fast devsel, latency 0, IRQ 42, IOMMU group 21
> Memory at fce00000 (32-bit, non-prefetchable) [size=2K]
> Capabilities: [a0] MSI: Enable+ Count=16/16 Maskable- 64bit+
> Capabilities: [d0] SATA HBA v1.0
> 00: 22 10 01 79 07 04 10 00 51 01 06 01 10 00 00 00
> 20: 00 00 00 00 00 00 e0 fc 00 00 00 00 58 14 02 b0
I hope it will get resolved.
