Author: wmb Date: 2009-05-03 17:45:53 +0200 (Sun, 03 May 2009) New Revision: 1170
Modified: cpu/x86/pc/olpc/via/romreset.bth Log: Via romreset.bth - reorder and fixed some formatting inconsistencies. No functional change.
Modified: cpu/x86/pc/olpc/via/romreset.bth =================================================================== --- cpu/x86/pc/olpc/via/romreset.bth 2009-05-03 08:48:11 UTC (rev 1169) +++ cpu/x86/pc/olpc/via/romreset.bth 2009-05-03 15:45:53 UTC (rev 1170) @@ -354,35 +354,112 @@
\ Also from FinalSetting.c
- 0 4 devfunc \ PM_table - a0 80 80 mreg \ Enable dynamic power management (coreboot for vx800 uses f0; 70 bits are reserved on vx855) - a1 e0 e0 mreg \ Dynamic power management for DRAM - a2 d6 d6 mreg \ Dynamic clock stop controls (coreboot for vx8000 uses ff fe; 29 bits are reserved on vx800) - a3 80 80 mreg \ Toggle reduction on - a5 81 81 mreg \ "Reserved" + 0 4 devfunc \ PM_table + a0 80 80 mreg \ Enable dynamic power management (coreboot for vx800 uses f0; 70 bits are reserved on vx855) + a1 e0 e0 mreg \ Dynamic power management for DRAM + a2 d6 d6 mreg \ Dynamic clock stop controls (coreboot for vx8000 uses ff fe; 29 bits are reserved on vx800) + a3 80 80 mreg \ Toggle reduction on + a5 81 81 mreg \ "Reserved" + end-table
- \ Additional PM settings not in coreboot - 84 ff db mreg \ Dynamic clocks - 85 ff 05 mreg \ Dynamic clocks - 89 ff f8 mreg \ Dynamic clocks - 8b ff bf mreg \ Dynamic clocks - 8d ff 20 mreg \ Self-refresh in C3 and C4 - 90 ff ff mreg \ Gate clocks - 91 ff ff mreg \ Gate clocks - 92 cc cc mreg \ Dynamic buffer control, power down comparators - a8 20 20 mreg \ Central traffic controller dynamic clock stop +\ UMARamSetting.c +\ SetUMARam + 0 3 devfunc + a1 00 80 mreg \ Enable internal GFX + a2 ff ee mreg \ Set GFX timers + a4 ff 01 mreg \ GFX Data Delay to Sync with Clock + a6 ff 76 mreg \ Page register life timer + a7 ff 8c mreg \ Internal GFX allocation + b3 ff 9a mreg \ Disable read past write +\ de ff 06 mreg \ Enable CHA and CHB merge mode (but description says this value disable merging!) 00 for compatibility end-table - + + 0 3 devfunc + a1 70 40 mreg \ Set frame buffer size to 64M (8M:10, 16M:20, 32M:30, etc) - fbsize + end-table + + 1 0 devfunc + \ Reg 1b2 controls the number of writable bits in the BAR at 810 + b2 ff 70 mreg \ Offset of frame buffer, depends on size - fbsize + 04 ff 07 mreg \ Enable IO and memory access to display + end-table + + d000.0000 810 config-wl \ S.L. Base address + f000.0000 814 config-wl \ MMIO Base address + cd01 3a0 config-ww \ Set frame buffer size and CPU-relative address and enable + + 0 0 devfunc + c6 02 02 mreg \ Enable MDA forwarding (not in coreboot) + d4 00 03 mreg \ Enable MMIO and S.L. access in Host Control device + fe 00 10 mreg \ 16-bit I/O port decoding for VGA (no aliases) + end-table + + 1 0 devfunc + b0 07 03 mreg \ VGA memory selection (coreboot uses 03, Phoenix 01. I think 03 is correct) + end-table + + 01 3c3 port-wb \ Graphics chip IO port access on + 10 3c4 port-wb 01 3c5 port-wb \ Turn off register protection + 67 3c2 port-wb \ Enable CPU Display Memory access (2), use color not mono port (1) + + 68 3c4 port-wb e0 3c5 port-wb \ Size of System Local Frame Buffer - Value depends on frame buffer size - fbsize + \ 00:512MB 80:256MB c0:128MB e0:64MB f0:32MB f8:16MB fc:8MB fe:4MB ff:2MB + + \ These 2 are scratch registers that communicate with the VGA BIOS + 3d 3d4 port-wb 74 3d5 port-wb \ Value depends on DIMM frequency - used by VGA BIOS + 39 3c4 port-wb 10 3c5 port-wb \ BIOS Reserved Register 0 - FBsize_MiB/4 - fbsize - VGA BIOS + + 5a 3c4 port-wb 01 3c5 port-wb \ Point to secondary registers + 4c 3c4 port-wb 83 3c5 port-wb \ LCDCK Clock Synthesizer Value 2 + 5a 3c4 port-wb 00 3c5 port-wb \ Point back to primary registers + + 6d 3c4 port-wb e0 3c5 port-wb \ Base address [28:21] of SL in System Memory - base is 1c00.0000 - fbsize, memsize + 6e 3c4 port-wb 00 3c5 port-wb \ Base address [36:29] of SL in System Memory + 6f 3c4 port-wb 00 3c5 port-wb \ Base address [47:37] of SL in System Memory + + 36 3c4 port-wb 11 3c5 port-wb \ Subsystem Vendor ID 1 + 35 3c4 port-wb 06 3c5 port-wb \ Subsystem Vendor ID 0 + 38 3c4 port-wb 51 3c5 port-wb \ Subsystem ID 1 + 37 3c4 port-wb 22 3c5 port-wb \ Subsystem ID 0 + + f3 3c4 port-wb 00 3c5 port-wb \ 1a for snapshot mode + f3 3d4 port-wb 12 3c5 port-wb \ Snapshot mode control - 1a for snapshot mode + +\ cache_as_ram_auto.c : enable_shadow_ram + + 0 3 devfunc +\ Initial DOS hole settings, so the firmware can set things up + 80 ff ff mreg \ Enable R/W memory access to Cxxxx bank + 81 ff ff mreg \ Enable R/W memory access to Dxxxx bank + 82 ff ff mreg \ Enable R/W memory access to Exxxx bank + 83 30 30 mreg \ Enable R/W memory access to Fxxxx bank (30), no memory hole (0c), SMM switching of Axxxx bank (03) + +\ Final DOS hole settings, after stuff has been copied in, for reference +\ 80 ff 2a mreg \ CC000-CFFFF off, C0000-C7FFF RO +\ 81 ff 00 mreg \ D0000-DFFFF off +\ 82 ff aa mreg \ E0000-EFFFF RO +\ 83 ff 20 mreg \ Enable R/W memory access to Fxxxx bank (20), no memory hole (0c), SMM switching of Axxxx bank (03) + end-table + \ Additional Power Management Setup not in coreboot 0 2 devfunc 76 08 08 mreg \ AGTL Power down buffers in S3 92 ff 40 mreg \ ACPI IO Base address end-table
- 0 3 devfunc - 86 38 38 mreg \ SMM and APIC Decoding: enable APIC lowest int arb, IOAPIC split decode, MSI (SMM later) + 0 4 devfunc + 84 ff db mreg \ Dynamic clocks + 85 ff 05 mreg \ Dynamic clocks + 89 ff f8 mreg \ Dynamic clocks + 8b ff bf mreg \ Dynamic clocks + 8d ff 20 mreg \ Self-refresh in C3 and C4 + 90 ff ff mreg \ Gate clocks + 91 ff ff mreg \ Gate clocks + 92 cc cc mreg \ Dynamic buffer control, power down comparators + a8 20 20 mreg \ Central traffic controller dynamic clock stop end-table - + + \ Bus tuning 0 5 devfunc 54 8f 80 mreg \ SM request gets high priority, PCCA occupancy timer off 55 0f 04 mreg \ PCCA P2C Promote Timer value 4 @@ -415,91 +492,6 @@ d4 ac 24 mreg \ Config 3 end-table
-\ UMARamSetting.c -\ SetUMARam - 0 3 devfunc - a1 00 80 mreg \ Enable internal GFX - a2 ff ee mreg \ Set GFX timers - a4 ff 01 mreg \ GFX Data Delay to Sync with Clock - a6 ff 76 mreg \ Page register life timer - a7 ff 8c mreg \ Internal GFX allocation - b3 ff 9a mreg \ Disable read past write -\ de ff 06 mreg \ Enable CHA and CHB merge mode (but description says this value disable merging!) 00 for compatibility - end-table - - 0 3 devfunc - a1 70 40 mreg \ Set frame buffer size to 64M (8M:10, 16M:20, 32M:30, etc) - fbsize - end-table - - 1 0 devfunc - \ Reg 1b2 controls the number of writable bits in the BAR at 810 - b2 ff 70 mreg \ Offset of frame buffer, depends on size - fbsize - 04 ff 07 mreg \ Enable IO and memory access to display - end-table - - d000.0000 810 config-wl \ S.L. Base address - f000.0000 814 config-wl \ MMIO Base address - cd01 3a0 config-ww \ Set frame buffer size and CPU-relative address and enable - - 0 0 devfunc - c6 02 02 mreg \ Enable MDA forwarding (not in coreboot) - d4 00 03 mreg \ Enable MMIO and S.L. access in Host Control device - fe 00 10 mreg \ 16-bit I/O port decoding for VGA (no aliases) - end-table - - 1 0 devfunc - b0 07 03 mreg \ VGA memory selection (coreboot uses 03, Phoenix 01. I think 03 is correct) - end-table - - 01 3c3 port-wb \ Graphics chip IO port access on - 10 3c4 port-wb 01 3c5 port-wb \ Turn off register protection - 67 3c2 port-wb \ Enable CPU Display Memory access (2), use color not mono port (1) - - 68 3c4 port-wb e0 3c5 port-wb \ Size of System Local Frame Buffer - Value depends on frame buffer size - fbsize - \ 00:512MB 80:256MB c0:128MB e0:64MB f0:32MB f8:16MB fc:8MB fe:4MB ff:2MB - - \ These 2 are scratch registers that communicate with the VGA BIOS - 3d 3d4 port-wb 74 3d5 port-wb \ Value depends on DIMM frequency - used by VGA BIOS - 39 3c4 port-wb 10 3c5 port-wb \ BIOS Reserved Register 0 - FBsize_MiB/4 - fbsize - VGA BIOS - - 5a 3c4 port-wb 01 3c5 port-wb \ Point to secondary registers - 4c 3c4 port-wb 83 3c5 port-wb \ LCDCK Clock Synthesizer Value 2 - 5a 3c4 port-wb 00 3c5 port-wb \ Point back to primary registers - - 6d 3c4 port-wb e0 3c5 port-wb \ Base address [28:21] of SL in System Memory - base is 1c00.0000 - fbsize, memsize - 6e 3c4 port-wb 00 3c5 port-wb \ Base address [36:29] of SL in System Memory - 6f 3c4 port-wb 00 3c5 port-wb \ Base address [47:37] of SL in System Memory - - 36 3c4 port-wb 11 3c5 port-wb \ Subsystem Vendor ID 1 - 35 3c4 port-wb 06 3c5 port-wb \ Subsystem Vendor ID 0 - 38 3c4 port-wb 51 3c5 port-wb \ Subsystem ID 1 - 37 3c4 port-wb 22 3c5 port-wb \ Subsystem ID 0 - - f3 3c4 port-wb 00 3c5 port-wb \ 1a for snapshot mode - f3 3d4 port-wb 12 3c5 port-wb \ Snapshot mode control - 1a for snapshot mode - -\ cache_as_ram_auto.c : enable_shadow_ram - 0 3 devfunc - -\ Initial DOS hole settings, so the firmware can set things up - 80 ff ff mreg \ Enable R/W memory access to Cxxxx bank - 81 ff ff mreg \ Enable R/W memory access to Dxxxx bank - 82 ff ff mreg \ Enable R/W memory access to Exxxx bank - 83 30 30 mreg \ Enable R/W memory access to Fxxxx bank (30), no memory hole (0c), SMM switching of Axxxx bank (03) - -\ Final DOS hole settings, after stuff has been copied in, for reference -\ 80 ff 2a mreg \ CC000-CFFFF off, C0000-C7FFF RO -\ 81 ff 00 mreg \ D0000-DFFFF off -\ 82 ff aa mreg \ E0000-EFFFF RO -\ 83 ff 20 mreg \ Enable R/W memory access to Fxxxx bank (20), no memory hole (0c), SMM switching of Axxxx bank (03) - - end-table - - \ Low 2 bits of 86: - \ x1 to write to SMM shadow memory behind VGA - \ 00 to run - Axxxxx hits VGA in normal mode, hits shadow DRAM in SMM - \ 01 to access VGA when in SMM (data cycles only) - \ APIC setup 0 2 devfunc 59 01 01 mreg \ MSI Flat model support @@ -511,6 +503,13 @@ 86 38 38 mreg \ SMM and APIC Decoding: enable APIC lowest int arb, IOAPIC split decode, MSI (SMM later) end-table
+ \ Low 2 bits of 86: + \ x1 to write to SMM shadow memory behind VGA + \ 00 to run - Axxxxx hits VGA in normal mode, hits shadow DRAM in SMM + \ 01 to access VGA when in SMM (data cycles only) + + \ USB Tuning + h# 1c00.0000 # mem-info-pa 4 + #) mov \ Top of memory
long-offsets on
