Author: wmb Date: 2009-05-04 19:04:44 +0200 (Mon, 04 May 2009) New Revision: 1171
Modified: cpu/x86/pc/olpc/via/romreset.bth Log: Via romreset.bth - added tuning settings for various devices, enabling power control and APIC.
Modified: cpu/x86/pc/olpc/via/romreset.bth =================================================================== --- cpu/x86/pc/olpc/via/romreset.bth 2009-05-03 15:45:53 UTC (rev 1170) +++ cpu/x86/pc/olpc/via/romreset.bth 2009-05-04 17:04:44 UTC (rev 1171) @@ -452,7 +452,7 @@ 85 ff 05 mreg \ Dynamic clocks 89 ff f8 mreg \ Dynamic clocks 8b ff bf mreg \ Dynamic clocks - 8d ff 20 mreg \ Self-refresh in C3 and C4 + 8d ff 30 mreg \ Self-refresh in C3 and C4 90 ff ff mreg \ Gate clocks 91 ff ff mreg \ Gate clocks 92 cc cc mreg \ Dynamic buffer control, power down comparators @@ -474,15 +474,19 @@
d# 12 0 devfunc \ SDIO tuning 44 01 01 mreg \ Enable backdoor - 8b 05 05 mreg \ Report both 1.8V and 3.3V + 8b 05 01 mreg \ Do not report 1.8V support 8c c3 03 mreg \ Falling edge trigger for Slots 1 and 2 data in high speed 8e ff 7e mreg \ Delay host clock for Slots 1, 2, 3 by 4.8 nS - 8f 09 0a mreg \ Falling edge trigger on slot 3 output clock under high speed - 99 ff f9 mreg \ Two slots not 3 (FIXME for OLPC) + 8f 09 01 mreg \ Falling edge trigger on slot 3 output clock under high speed +[ifdef] demo-board + 99 ff f9 mreg \ Two slots +[else] + 99 ff fa mreg \ Three slots +[then] end-table
d# 15 0 devfunc \ EIDE tuning - 40 02 01 mreg \ Enable primary channel + 40 02 02 mreg \ Enable primary channel 4a ff 5e mreg \ Drive1 timing 4b ff 20 mreg \ Drive0 timing 4c f0 60 mreg \ Address setup time @@ -492,6 +496,125 @@ d4 ac 24 mreg \ Config 3 end-table
+ \ USB Tuning + d# 16 0 devfunc \ UHCI Ports 0,1 + 4a 02 02 mreg \ Enable Stop Bus Master Cycle if HALT Bit is Asserted + 4b 60 60 mreg \ Enable New UHCI Dynamic Scheme - 66MHz (40) & 33MHz (20) + c1 20 00 mreg \ Disable USB PIRQ + end-table + + d# 16 1 devfunc \ UHCI Ports 2,3 + 4a 02 02 mreg \ Enable Stop Bus Master Cycle if HALT Bit is Asserted + 4b 60 60 mreg \ Enable New UHCI Dynamic Scheme - 66MHz (40) & 33MHz (20) + c1 20 00 mreg \ Disable USB PIRQ + end-table + + d# 16 2 devfunc \ UHCI Ports 4,5 + 4a 02 02 mreg \ Enable Stop Bus Master Cycle if HALT Bit is Asserted + 4b 60 60 mreg \ Enable New UHCI Dynamic Scheme - 66MHz (40) & 33MHz (20) + c1 20 00 mreg \ Disable USB PIRQ + end-table + + d# 16 4 devfunc \ EHCI + 42 40 40 mreg \ Enable Check PRESOF of ITDOUT Transaction during Fetching Data from DRAM + 43 c0 c0 mreg \ Enable Dynamic Clock Scheme - 66MHz (80) & 33MHz (40) + 48 20 00 mreg \ Disable DMA bursts + 4c 03 03 mreg \ Squelch detector fine tune - 01 is 112.5 mV +\ 4d 01 01 mreg \ reserved bit +\ 4e 03 03 mreg \ reserved bit - setting is appropriate for vx800 + 4f 10 10 mreg \ Enable Clear RUN Bit when EHCI_IDLE + 50 80 80 mreg \ Fetch one more QH before de-asserting Doorbell + 55 ff ff mreg \ Disconnect level fine tune - 575 mV for ports 0-3 + 56 0f 0f mreg \ Disconnect level fine tune - 575 mV for ports 4-5 + 5a ff cc mreg \ HS termination resistor fine tune - 45 ohm, 48 ohm for ports 0,1 + 5b ff cc mreg \ HS termination resistor fine tune - 45 ohm, 48 ohm for ports 2,3 + 5c 0f 00 mreg \ DPLL Track Speed 2, DPLL Lock Speed 2 + 5d ff cc mreg \ HS termination resistor fine tune - 45 ohm, 48 ohm for ports 4,5 + 64 05 05 mreg \ Bump NULL-SOF valid time to 8 micro frames (04), Inhibit C4 state on USB 1.1 ISO activity (01) + end-table + + d# 17 0 devfunc \ Bus control and power management + 40 44 44 mreg \ Enable I/O Recovery time (40), Enable ports 4d0/4d1 for edge/level setting (04) + 42 fc f0 mreg \ Various setting related to DMA line buffers + 43 0f 0b mreg \ Enable PCI delayed transactions (08), Write transaction timer (02), Read transaction timer (01) +\ 4d 01 01 mreg \ Enable LPC TPM + 4e 08 08 mreg \ Enable ports 74/75 for CMOS RAM access + 52 1b 19 mreg \ No wait state between SIRQ transactions (10), Enable SIRQ (08), SIRQ frame is 6 clocks (3>1) + 53 80 80 mreg \ Enable PC/PCI DMA + 55 ff a0 mreg \ INTA and External General interrupt routing - INTA:IRQ10 + 56 ff b9 mreg \ INTB,C routing - INTC:IRQ11, INTB:IRQ9 + 57 f0 a0 mreg \ INTD routing - INTD:IRQ10 + 58 40 40 mreg \ Enable Internal APIC + 5b 10 10 mreg \ Enable APIC Clock Gating + 68 80 80 mreg \ Enable HPETs + 69 ff 00 mreg \ HPET base low + 6a ff d0 mreg \ HPET base mid + 6b ff fe mreg \ HPET base high + 6e ff 18 mreg \ COMB not pos decoded but otherwise set to 2f8, COMA pos decoded at 3f8 + 70 ff 06 mreg \ SVID backdoor + 71 ff 11 mreg \ SVID backdoor + 72 ff 37 mreg \ SVID backdoor + 73 ff 33 mreg \ SVID backdoor + 80 20 20 mreg \ Debounce power button +\ 81 08 00 mreg \ 24-bit ACPI timer - why? + 84 ff da mreg \ IRQs 7,6,4,3,1 are primary wakeups + 85 ff 40 mreg \ IRQ 14 is primary wakeup + 8a 9f 1f mreg \ C-state auto switching with normal latencies +[ifdef] demo-board + 8d 18 18 mreg \ fast clock as throttle timer tick, hold SMI# low until event status cleared (FIXME for OLPC) +[else] + 8d 18 10 mreg \ fast clock as throttle timer tick, do not hold SMI# low +[then] +\ 9b 80 80 mreg \ reserved bit + b4 80 00 mreg \ No positive decoding for UART1 ??? + b8 fc 80 mreg \ UART DMA Control Registers Base low (port is 4080) + b9 ff 40 mreg \ UART DMA Control Registers Base high + ba 77 44 mreg \ COM1 DMA Channel Selects - DMA0 for both Transmit and Receive + bc ff 00 mreg \ SPI MMIO Base Address 15:8 (address is fed30000) + bd ff d3 mreg \ SPI MMIO Base Address 23:16 + be ff fe mreg \ SPI MMIO Base Address 31:24 + d0 f0 00 mreg \ SMBUS IO Base Address low (port is 4100) + d1 ff 41 mreg \ SMBUS IO Base Address high + d2 0f 01 mreg \ Enable SMBUS and set other characteristics + e2 80 80 mreg \ Inhibit C4 during USB isochronous transaction + e4 ff a0 mreg \ Enable short C3/C4 (80), select various multi-function pins + e5 60 60 mreg \ Enable NM bus master as source of bus master status, enable NB int to wakeup from Cx + e6 20 20 mreg \ Enable USB Device Mode Bus Master as Break Event + e7 80 80 mreg \ Enable APIC Cycle Reflect to ALL Bus Master Activity Effective Signal + fc 06 04 mreg \ DPSLP# to SLP# Latency Adjustment - 22.5 us + end-table + + d# 17 7 devfunc \ South-North Module Interface Control + 50 df 08 mreg \ SM priorities - HDAC high priority, others low + 51 80 80 mreg \ Enable subtractive decode for P2P cycle + 54 7b 02 mreg \ CCA REQ timing - synchronize USB REQ but not others +0 [if] + 61 ff 2a mreg \ Page C ROM shadow - C0000-CBFFF RO, CC000-CFFFF off + 62 ff 00 mreg \ Page D ROM shadow - D0000-DFFFF off + 63 f3 a0 mreg \ Page E/F ROM shadow - E0000-EFFFF RO, F0000-FFFFF RO, no memory hole + 64 ff aa mreg \ Page E ROM shadow - E0000-EFFFF RO +[then] + 70 fb 82 mreg \ CPU to PCI flow control - CPU to PCI posted write, Enable Delay Transaction + 72 af ee mreg \ Read caching and prefix - various knobs (40 bit is reserved) + 73 79 01 mreg \ Enable PCI broken master timer & various knobs + 74 d8 08 mreg \ Lock Cycle Issued by CPU Blocks P2C Cycles (04 bit is reserved) + 75 ff 0f mreg \ Use New grant mechanism for PCI arbitration, PCI Master Bus Timeout is 7x16 PCI clock + 76 fd 50 mreg \ Enable PCI parking, Grant to CPU after 2 PC master grants + 77 58 48 mreg \ PCI1 FIFO empty blocks CPU to PCI read, Read FIFO times out after 1 ms + 80 07 07 mreg \ PCI1 and HDAC upstream read does not pass write, APCI blocks upstream write + 82 3e 20 mreg \ Monitor CCA and SDIO2 + e0 e0 80 mreg \ Dynamic CCA clock + e2 1e 00 mreg \ Use dynamic clocks for Downstream Interface, PCI1, Downstream HDAC, Downstream SM Internal PCI device + e3 ff 5e mreg \ PCI1 dynamic clock, PCI clock on when GRANT# asserted, Enable P2CR data timeout at 7*8 PCI clocks +\ e6 1f 1f mreg \ Split APIC decoding, Snoop FEEx.xxxx, Enable top SMM, High SMM, Compat SMM (20 bit is reserved) + e6 1f 19 mreg \ Split APIC decoding, Snoop FEEx.xxxx, Enable top SMM, High SMM, Compat SMM (20 bit is reserved) + fc 40 40 mreg \ Enable CCA Read Clock When MTXCTL state machine is not idle + end-table + + d# 20 0 devfunc + 41 01 01 mreg \ Dynamic clock for HDAC + end-table + \ APIC setup 0 2 devfunc 59 01 01 mreg \ MSI Flat model support @@ -508,8 +631,6 @@ \ 00 to run - Axxxxx hits VGA in normal mode, hits shadow DRAM in SMM \ 01 to access VGA when in SMM (data cycles only)
- \ USB Tuning - h# 1c00.0000 # mem-info-pa 4 + #) mov \ Top of memory
long-offsets on
