Author: wmb Date: 2009-10-06 05:18:14 +0200 (Tue, 06 Oct 2009) New Revision: 1393
Modified: cpu/x86/pc/olpc/via/demodram.fth cpu/x86/pc/olpc/via/startgfxinit.fth cpu/x86/pc/olpc/via/starthostctl.fth Log: Via 32-bit memory width - final register value fixups as stipulated by Via.
Modified: cpu/x86/pc/olpc/via/demodram.fth =================================================================== --- cpu/x86/pc/olpc/via/demodram.fth 2009-10-02 22:10:09 UTC (rev 1392) +++ cpu/x86/pc/olpc/via/demodram.fth 2009-10-06 03:18:14 UTC (rev 1393) @@ -389,17 +389,15 @@ 4b ff rank-base3 mreg \ Rank base 3 end-table
- acpi-io-base 48 + port-rl h# 1000.0000 # ax and 0<> if \ Memory ID1 bit + acpi-io-base 48 + port-rl h# 1000.0000 # ax and 0<> if \ Memory ID1 bit - set for 32bit memory width 0 3 devfunc 6c 20 20 mreg \ Enable 32-bit memory width mode - channel A d4 30 10 mreg \ ODT off for low 32 bits end-table - - 0388 config-rb ax bx mov 1 # bx shr 0385 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to reg 85 - else - 0388 config-rb ax bx mov 0385 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to reg 85 then
+ 0388 config-rb ax bx mov 0385 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to reg 85 + h# 15 port80
0 [if] \ Very simple memtest
Modified: cpu/x86/pc/olpc/via/startgfxinit.fth =================================================================== --- cpu/x86/pc/olpc/via/startgfxinit.fth 2009-10-02 22:10:09 UTC (rev 1392) +++ cpu/x86/pc/olpc/via/startgfxinit.fth 2009-10-06 03:18:14 UTC (rev 1393) @@ -59,7 +59,12 @@ 6f 3c4 port-wb 00 3c5 port-wb \ Base address [47:37] of SL in System Memory [then] [ifdef] xo-board - 385 config-rb \ AX: totalsize/16M + 385 config-rb ax bx mov \ BX: totalsize/16M + acpi-io-base 48 + port-rl h# 1000.0000 # ax and 0<> if \ Memory ID1 bit - set for 32bit memory width + 1 # bx shr \ Divide size by 2 for 32-bit DRAM width + then + bx ax mov \ AX: totalsize/16M_adjusted + d# 24 # ax shl \ AX: totalsize /fbmem # ax sub \ AX: totalsize-fbmemsize = fbbase d# 21 # ax shr \ AX: fbbase/2M
Modified: cpu/x86/pc/olpc/via/starthostctl.fth =================================================================== --- cpu/x86/pc/olpc/via/starthostctl.fth 2009-10-02 22:10:09 UTC (rev 1392) +++ cpu/x86/pc/olpc/via/starthostctl.fth 2009-10-06 03:18:14 UTC (rev 1393) @@ -67,7 +67,7 @@ [then] end-table
- acpi-io-base 48 + port-rl h# 1000.0000 # ax and 0<> if \ Memory ID1 bit + acpi-io-base 48 + port-rl h# 1000.0000 # ax and 0<> if \ Memory ID1 bit - set for 32bit memory width 0 2 devfunc 55 02 02 mreg \ Host controller to DRAM read cycle control II - 1 means 2T slower
