Author: rsmith Date: Tue Aug 14 01:19:12 2012 New Revision: 3166 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3166
Log: OLPC 1.75 - Fix EC programming breakage
The changes to support the io3790 on the CL4 broke programming on the 1.75. This fixes up the breakage. It also factors out the dummy read into its own word called edi-start. Not necessary for the fix but was handy during debugging.
Modified: cpu/arm/olpc/edi.fth
Modified: cpu/arm/olpc/edi.fth ============================================================================== --- cpu/arm/olpc/edi.fth Mon Aug 13 23:21:51 2012 (r3165) +++ cpu/arm/olpc/edi.fth Tue Aug 14 01:19:12 2012 (r3166) @@ -18,10 +18,10 @@
: efcfg ( -- reg# ) kb9010? if h# fead else h# fea0 then ; : efcmd ( -- reg# ) kb9010? if h# feac else h# fea7 then ; -: efdat ( -- reg# ) kb9010? if h# feab else h# feaa then ; +: efdat ( -- reg# ) kb9010? if h# feab else h# feaa then ; \ io3731 has different read and write regs +h# feab constant efdat-in : rst8051 ( -- reg# ) kb9010? if h# ff14 else h# f010 then ; : ecreboot ( -- reg# ) kb9010? if h# ff01 else h# f018 then ; - \ Issues with .py code \ A14:A8 should be A15:A8 several places \ inconsistent use of handle vs gd.handle in edi_erase_chip @@ -140,7 +140,7 @@ ;
: finished? ( b -- flag ) - kb9010? if 2 and 0= else h# 80 = then + kb9010? if 2 and 0= else h# 80 and h# 80 = then ; : wait-flash-busy ( -- ) \ Wait for an erase/programming operation to complete get-msecs h# 1000 + ( limit ) @@ -220,8 +220,9 @@ set-offset h# 90 flash-cmd wait-flash-busy - efdat edi-b@ \ reg: efdat + efdat-in edi-b@ \ reg: efdat ; + : trim-tune ( -- ) \ firmware-id 0= if \ Read trim data and write to register (for ENE macros) @@ -334,13 +335,19 @@ ecsts edi-b! ( ) then ; + +\ Does a dummy ready and throws away the result. +\ required to get the EDI interface enabled +: edi-start ( -- ) + h# ff22 ['] edi-b@ catch if noop else drop then +; + : edi-open ( -- ) \ slow-edi-clock \ Target speed between 1 and 2 MHz spi-start
- \ dummy read, to activate EDI and can fail so ignore the fail - h# ff22 ['] edi-b@ catch if noop else drop then - + edi-start + set-chip-id
\ The first operation often fails so retry it
