Author: wmb Date: 2009-05-04 19:05:54 +0200 (Mon, 04 May 2009) New Revision: 1172
Modified: cpu/x86/pc/biosload/config-via.fth Log: Biosload - updated config-via settings so Linux will boot.
Modified: cpu/x86/pc/biosload/config-via.fth =================================================================== --- cpu/x86/pc/biosload/config-via.fth 2009-05-04 17:04:44 UTC (rev 1171) +++ cpu/x86/pc/biosload/config-via.fth 2009-05-04 17:05:54 UTC (rev 1172) @@ -11,6 +11,8 @@
create debug-startup
+create virtual-mode +create linux-support \ create serial-console \ create use-usb-debug-port create pc @@ -20,7 +22,7 @@ create addresses-assigned \ Don't reassign PCI addresses \ create virtual-mode create use-root-isa -create use-isa-ide +\ create use-isa-ide create use-ega create use-elf create use-watch-all
