Author: wmb Date: Tue Jan 25 09:55:42 2011 New Revision: 2149 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2149
Log: Reverted change to inflate.c introduced by r2097. Without the "section text_inflate" attribute on the inflate() function, the GCC optimizer moves code so that huft_build() appears first in the file. OFW expects inflate() to be at the beginning of the image.
Modified: forth/wrapper/zip/inflate.c
Modified: forth/wrapper/zip/inflate.c ============================================================================== --- forth/wrapper/zip/inflate.c Tue Jan 25 04:07:13 2011 (r2148) +++ forth/wrapper/zip/inflate.c Tue Jan 25 09:55:42 2011 (r2149) @@ -165,7 +165,7 @@ * Return size of clear. */ int -inflate(struct workspace *wsptr, int nohdr, u_char* clear, u_char *compr); +inflate(struct workspace *wsptr, int nohdr, u_char* clear, u_char *compr) __attribute__((section ("text_inflate")));
int inflate(struct workspace *wsptr, int nohdr, u_char* clear, u_char *compr)
