Author: rsmith Date: Thu Aug 16 04:01:14 2012 New Revision: 3180 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3180
Log: OLPC ARM - Refactor EDI start procedure
Reboot after reflash did not work because the EC chip ID (io3731 vs io3790) was not set in the series of calls that the OFW flash makes. Refactor the EDI startup so that there is a common EDI enable routine for other words to call.
Modified: cpu/arm/olpc/build-fw.fth cpu/arm/olpc/edi.fth
Modified: cpu/arm/olpc/build-fw.fth ============================================================================== --- cpu/arm/olpc/build-fw.fth Thu Aug 16 04:01:07 2012 (r3179) +++ cpu/arm/olpc/build-fw.fth Thu Aug 16 04:01:14 2012 (r3180) @@ -202,6 +202,7 @@
: ignore-power-button ( -- ) edi-spi-start + edi-open-active ['] reset-8051 catch if ['] reset-8051 catch if ." Write Protected EC" cr then then
Modified: cpu/arm/olpc/edi.fth ============================================================================== --- cpu/arm/olpc/edi.fth Thu Aug 16 04:01:07 2012 (r3179) +++ cpu/arm/olpc/edi.fth Thu Aug 16 04:01:14 2012 (r3180) @@ -335,23 +335,23 @@ ecsts edi-b! ( ) then ; - -\ Does a dummy ready and throws away the result. -\ required to get the EDI interface enabled -: edi-start ( -- ) - h# ff22 ['] edi-b@ catch if noop else drop then -; - -: edi-open ( -- ) - \ slow-edi-clock \ Target speed between 1 and 2 MHz +\ This is used to start EDI from routines where you do not want to +\ put the EC into reset. ie the mfg tag reading routines +: edi-open-active ( -- ) spi-start
- edi-start + \ Does a dummy ready and throws away the result. + \ required to get the EDI interface enabled + h# ff22 ['] edi-b@ catch if noop else drop then
set-chip-id
- \ The first operation often fails so retry it - ['] select-flash catch if select-flash then + select-flash +; +\ Full EDI startup sequece. Used when you want to reprogram the EC. +: edi-open ( -- ) + edi-open-active + reset-8051
kb9010? if @@ -360,14 +360,7 @@ else trim-tune then - \ fast-edi-clock \ Target speed up to 16 MHz - \ reset ; -: edi-open-active ( -- ) - spi-start - ['] select-flash catch if select-flash then -; - \ LICENSE_BEGIN \ Copyright (c) 2011 FirmWorks \
