Author: wmb Date: Tue Sep 27 23:21:29 2011 New Revision: 2539 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2539
Log: OLPC XO-1.75 - version of dramrecal.fth used in q4b10mn
Modified: cpu/arm/mmp2/dramrecal.fth
Modified: cpu/arm/mmp2/dramrecal.fth ============================================================================== --- cpu/arm/mmp2/dramrecal.fth Tue Sep 27 22:10:43 2011 (r2538) +++ cpu/arm/mmp2/dramrecal.fth Tue Sep 27 23:21:29 2011 (r2539) @@ -59,66 +59,53 @@ here ddr-recal - constant /ddr-recal
label ddr-self-refresh ( r0:memctrl-va -- ) - mov r1, #0x1 \ Block all data requests - str r1, [r0, #0x7e0] \ SDRAM_CTRL14 + mov r1, #0x1 \ Block all data requests + str r1, [r0, #0x7e0] \ SDRAM_CTRL14
- ldr r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 - orr r1, r1, #0x03000000 \ PAD_TERM_SWITCH_MODE: Termination disabled - str r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 + ldr r2, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 + orr r1, r2, #0x03000000 \ PAD_TERM_SWITCH_MODE: Termination disabled + str r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2
- mov r1, #0x40 \ Enter Self Refresh value - str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + mov r1, #0x40 \ Enter Self Refresh value + str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0
- ldr r1, [r0, #0x1e0] \ PHY_CTRL8 - bic r1,r1,#0x07700000 \ PHY_ADCM_ZPDRV: 0 PHY_ADCM_ZNDRV: 0 (Disable drivers 6:0) - str r1, [r0, #0x1e0] \ PHY_CTRL8 + ldr r3, [r0, #0x1e0] \ PHY_CTRL8 + bic r1, r3, #0x07700000 \ PHY_ADCM_ZPDRV: 0 PHY_ADCM_ZNDRV: 0 (Disable drivers 6:0) + str r1, [r0, #0x1e0] \ PHY_CTRL8
- mov r1, #0x70000 str r1, [r0, #0x110] \ MMAP1 - breadcrumb + dsb \ Data Synchronization Barrier + wfi \ Wait for interrupt
- dsb \ Data Synchronization Barrier - wfi \ Wait for interrupt + str r3, [r0, #0x1e0] \ PHY_CTRL8 - restore previous value
- ldr r1, [r0, #0x1e0] \ PHY_CTRL8 - orr r1,r1,#0x07700000 \ PHY_ADCM_ZPDRV: 7 PHY_ADCM_ZNDRV: 7 (Enable drivers 6:0) - str r1, [r0, #0x1e0] \ PHY_CTRL8 + mov r1, #0x20000000 \ PHY_DLL_RESET + str r1, [r0, #0x240] \ PHY_CTRL14
- mov r1, #0x20000000 \ PHY_DLL_RESET - str r1, [r0, #0x240] \ PHY_CTRL14 + mov r1, #0x40000000 \ DLL_UPDATE_EN + str r1, [r0, #0x240] \ PHY_CTRL14
- mov r1, #0x40000000 \ DLL_UPDATE_EN - str r1, [r0, #0x240] \ PHY_CTRL14 + mov r1, #0x80 \ Exit Self Refresh value + str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0
- mov r1, #0x80 \ Exit Self Refresh value - str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 - - ldr r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 - bic r1, r1, #0x02000000 \ PAD_TERM_SWITCH_MODE: Change 3 to 1 to enable termination for Read and Write - str r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 - - mov r1, #0x20 \ 32 spins, takes about 16 uS (from SRAM) - begin - decs r1, #1 - 0= until + str r2, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 - restore previous value
[ifdef] notdef - mov r1, #0x01000000 \ Chip select 0 - orr r1, r1, #0x00001000 \ Initiate ZQ calibration long - str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 - - \ ZQ calibration long takes 512 memory clock cycles after a reset - \ At 400 MHz, that's a little more than 2 us. We spin here to - \ ensure that the recal is complete before we touch the DRAM again. - mov r1, #0x20 \ 32 spins, takes about 16 uS (from SRAM) - begin - decs r1, #1 - 0= until + mov r1, #0x01000000 \ Chip select 0 + orr r1, r1, #0x00001000 \ Initiate ZQ calibration long + str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + + \ ZQ calibration long takes 512 memory clock cycles after a reset + \ At 400 MHz, that's a little more than 2 us. We spin here to + \ ensure that the recal is complete before we touch the DRAM again. + mov r1, #0x20 \ 32 spins, takes about 16 uS (from SRAM) + begin + decs r1, #1 + 0= until [then] + mov r1, #0x0 \ Unblock data requests + str r1, [r0, #0x7e0] \ SDRAM_CTRL14
- mov r1, #0x0 \ Unblock data requests - str r1, [r0, #0x7e0] \ SDRAM_CTRL14 - - dsb - mov pc, lr + mov pc, lr end-code here ddr-self-refresh - constant /ddr-self-refresh
@@ -154,17 +141,10 @@ set r0,`memctrl-va #` \ Memory controller virtual address
set r1,`'ddr-self-refresh #` \ Address of ddr-self-refresh routine in SRAM - mov r7,sp - set sp,`'ddr-self-refresh-sp #` ldr r2,[r1] \ Force the code translation into the TLB ldr r3,[r0,#0x110] \ Force the memory controller translation into the TLB mov lr,pc mov pc,r1 - -[ifdef] notdef1 - mov r1,#0xa0000 str r1,[r0,#0x110] \ MMAP1 - breadcrumb -[then] - mov sp,r7 c;
: apbc-clr-rst ( offset -- ) +apbc 4 swap io-clr ; @@ -688,7 +668,9 @@ : keyboard-power-on ( -- ) d# 148 gpio-clr ; : keyboard-power-off ( -- ) d# 148 gpio-set ; : wlan-power-on ( -- ) d# 34 gpio-set ; -: wlan-power-off ( -- ) d# 34 gpio-clr ; +: wlan-power-off ( -- ) d# 34 gpio-clr h# 040 d# 34 af! h# 040 d# 57 af! h# 040 d# 58 af! ; +: wlan-stay-on ( -- ) h# 140 d# 34 af! h# 140 d# 57 af! h# 140 d# 58 af! ; + 0 value sleep-mask : screen-off sleep-mask 1 and if \ DCON power down @@ -702,7 +684,7 @@ \ 0 h# 54 pmua! \ Kill the SDIO 0 clocks - insignificant savings \ 0 h# 58 pmua! \ Kill the SDIO 1 clocks - insignificant savings sleep-mask 2 and 0= if keyboard-power-off then \ Should save about 17 mW - sleep-mask 4 and 0= if wlan-power-off then \ saves 100 mW + sleep-mask 4 and if wlan-stay-on else wlan-power-off then \ saves 100 mW ; : screen-on ( -- ) sleep-mask 4 and 0= if wlan-power-on then @@ -767,14 +749,10 @@
disable-clks
-\ hdd-led-off - \ begin mmp2_cpu_do_idle() block-irqs ( ) \ Block IRQs - will be cleared by PMU do-self-refresh ( )
-\ hdd-led-on - restore-run-state \ end mmp2_cpu_do_idle()
@@ -792,7 +770,7 @@ enable-interrupts hdd-led-off ; -: strp ( -- ) ec-rst-pwr str ec-max-pwr .d ." mW " ; +: strp ( -- ) ec-rst-pwr str ec-max-pwr .d ." mW " soc .% space ;
\ LICENSE_BEGIN \ Copyright (c) 2011 FirmWorks
