Author: wmb Date: Thu Nov 8 08:42:50 2012 New Revision: 3419 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3419
Log: OLPC SPI FLASH driver - converted nested case statements to tables.
Modified: dev/olpc/spiflash/spiflash.fth
Modified: dev/olpc/spiflash/spiflash.fth ============================================================================== --- dev/olpc/spiflash/spiflash.fth Wed Nov 7 22:38:16 2012 (r3418) +++ dev/olpc/spiflash/spiflash.fth Thu Nov 8 08:42:50 2012 (r3419) @@ -303,46 +303,87 @@ 0 value spi-id# 0 value jedec-id# 0 0 2value spi-id$ + +: (.spi-id) ( -- ) + push-hex + spi-id# 2 .r [char] . emit jedec-id# 6 .r + pop-base +; + +create jedec-spi-table + \ JEDEC-ID /flash Name + + \ XO-4 + h# 1540c8 , h# 20.0000 , ," GD25Q16B" \ GigaDevice 3V3 + h# 1560c8 , h# 20.0000 , ," GD25LQ16" \ GigaDevice 1V8 + h# 1540ef , h# 20.0000 , ," W25Q16" \ Winbond 3V3 + h# 1520c2 , h# 20.0000 , ," MX25L1606E" \ Macronix 3V3 also MX25L1605D which is EOL (CS# rise time problem) + h# 1524c2 , h# 20.0000 , ," MX25L1633E" \ Macronix 3V3 (this is the preferred Macronyx part) + h# 1525c2 , h# 20.0000 , ," MX25L1635E" \ Macronix 1V8 (CS# rise time problem) + h# 3525c2 , h# 20.0000 , ," MX25U1635E" \ Macronix 1V8 + + \ XO-1.75 and XO-3 and XO-4 A2 + h# 3425c2 , h# 10.0000 , ," MX25U8035" \ Macronix 3V3 + + \ XO-1 and XO-1.5 + h# 1430ef , h# 10.0000 , ," WX25X80" \ Winbond (AB-ID is 13) + h# 130201 , h# 10.0000 , ," S25FL008A" \ Spansion (AB-ID is 13) + h# 8e25bf , h# 10.0000 , ," SST25VF080B" \ SST (AB-ID is bf) + \ ST M25P80 does not support the JEDEC ID command (AB-ID is 13) + + 0 , \ End of list + +\ I don't think this table will ever be used, because the only part +\ that was actually shipped on XO-1 and XO-1.5 was Winbond WX25X80 +create ab-spi-table + \ AB-ID /flash Name + h# 13 , h# 10.0000 , ," Spansion, Winbond, or ST" + h# bf , h# 10.0000 , ," SST" + +\ An infrequent HW error on XO-1 B1 used to falsely report 14 instead of 13 +\ h# 14 , h# 10.0000 , ," Unknown" + + 0 , \ End of list + +create unknown-spi-flash + \ /flash Name + 10.0000 , ," Unknown" + +: search-spi-table ( value table-adr -- true | entry-adr false ) + begin dup @ while ( value adr ) + 2dup @ = if ( value adr ) + nip na1+ ( entry-adr ) + false exit ( entry-adr false ) + then ( value adr ) + 2 na+ +str ( value adr' ) + repeat ( value adr ) + 2drop true ( true ) +; + : spi-identify ( -- ) ab-id to spi-id# jedec-id to jedec-id# - " Unknown" to spi-id$ - spi-id# case - h# 13 of - ['] common-write 1mb-flash - " Spansion, Winbond, or ST" to spi-id$ - endof - h# 14 of - ['] common-write 1mb-flash - jedec-id# h# 1520c2 = if 2mb-flash " MX25L1605D" to spi-id$ then - jedec-id# h# 1540c8 = if 2mb-flash " GD25Q16B" to spi-id$ then - jedec-id# h# 1540ef = if 2mb-flash " W25Q16" to spi-id$ then - endof - h# 24 of - ['] common-write 2mb-flash - jedec-id# h# 1524c2 = if 2mb-flash " MX25L1633E" to spi-id$ then - endof - h# 25 of - ['] common-write 1mb-flash - jedec-id# h# 1525c2 = if 2mb-flash " MX25L1635E" to spi-id$ then - endof - h# 34 of - ['] common-write 1mb-flash - " Macronyx" to spi-id$ - jedec-id# h# 3425c2 = if 1mb-flash " MX25E8035" to spi-id$ then - endof - h# 35 of - ['] common-write 2mb-flash - jedec-id# h# 3525c2 = if 2mb-flash " MX25U1635E" to spi-id$ then - endof - \ the SST part with its unique auto-increment address writing scheme - h# bf of - ['] sst-write 1mb-flash - " SST" to spi-id$ - endof - ( default ) ." Bad SPI FLASH ID " dup . cr ['] null-write swap - endcase ( writer ) - to write-spi-flash + + ['] common-write to write-spi-flash \ The usual case + + \ Special case for an uncommon part + spi-id# h# bf = if ['] sst-write to write-spi-flash then + + jedec-id# jedec-spi-table search-spi-table if ( ) + \ If we don't find it in the JEDEC ID table, fall back to the AB ID table + + ab-id ab-spi-table search-spi-table if ( ) + \ If we still don't find it, complain and disable writes + + ." Unsupported SPI FLASH ID " (.spi-id) cr + ['] null-write to write-spi-flash + + unknown-spi-flash ( entry-adr ) + then ( entry-adr ) + then ( entry-adr ) + dup @ to /flash ( entry-adr' ) + na1+ count to spi-id$ ( ) + spi-unprotect ;
@@ -350,7 +391,7 @@
: .spi-id ( -- ) ." SPI FLASH is type " - spi-id# 2 .r [char] . emit jedec-id# 6 .r + (.spi-id) ." , " spi-id$ type ." , " /flash h# 100000 / .d ." MB." ;
