Author: quozl Date: Thu Sep 6 02:28:28 2012 New Revision: 3294 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3294
Log: OLPC XO-4 - Neonode, graphical absolute signal strength tool, watch-fss
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Thu Sep 6 01:10:40 2012 (r3293) +++ cpu/arm/olpc/nn-touchscreen.fth Thu Sep 6 02:28:28 2012 (r3294) @@ -18,7 +18,7 @@ create nn-os \ open short test create nn-fll \ forced LED levels test create nn-version \ version display -create nn-watch-fll \ forced LED levels test, graphical variant +create nn-watch \ graphical signal tests
\ create nn-fss \ optional fixed signal strength test \ create nn-ls \ optional low signals test @@ -523,7 +523,7 @@
-[ifdef] nn-watch-fll \ forced LED levels test, graphical variant +[ifdef] nn-watch \ graphical signal tests
d# 30 value r \ size of blocks @@ -535,7 +535,7 @@ fill-rectangle-noff ( ) ;
-: signal>colour ( signal-value -- colour ) +: level>colour ( signal-value -- colour ) d# 3 rshift dup d# 5 lshift over d# 11 lshift or or ;
@@ -558,17 +558,19 @@ ;
0 value axis# -: watch-fll-signal ( signal# signal-value led-level -- ) - >r ( signal# signal-value r: led-level ) - signal>colour pixcolor ! ( signal# r: led-level ) - axis# if ( signal# r: led-level ) \ y + +: draw-signal ( signal# level -- x y ) + level>colour pixcolor ! ( signal# ) + axis# if ( signal# ) \ y ys>xy - else ( signal# r: led-level ) \ x + else ( signal# ) \ x xs>xy - then ( x y r: led-level ) - 2dup bigdot ( x y r: led-level ) - r> ( x y led-level ) - h# c > if ( x y ) + then ( x y ) + 2dup bigdot ( x y ) +; + +: ?draw-fail ( x y flag? -- ) + if ( x y ) white pixcolor ! ( x y ) big>little ( x' y' ) dot ( ) @@ -577,6 +579,14 @@ then ( ) ;
+ +: watch-fll-signal ( signal# signal-value led-level -- ) + >r ( signal# signal-value r: led-level ) + draw-signal ( x y r: led-level ) + r> ( x y led-level ) + h# c > ?draw-fail ( ) +; + : watch-fll-axis ( axis# -- ) dup to axis# ( axis# ) (fll) @@ -588,8 +598,12 @@ loop ;
-: watch-fll +: empty black 0 0 screen-w screen-h fill-rectangle-noff +; + +: watch-fll + empty begin 0 watch-fll-axis 1 watch-fll-axis key? @@ -599,6 +613,37 @@ ;
+ +: watch-fss-signal ( signal# level -- ) + dup >r ( signal# level r: level ) + draw-signal ( x y r: level ) + r> ( x y level ) + 1 < ?draw-fail ( ) +; + +d# 64 value fs \ fixed signal strength + +: watch-fss-axis ( axis# -- ) + dup to axis# ( axis# ) + fs swap h# 0f h# 03 h# ee 5 bytes-out + h# 0f d# 20 anticipate + + pbuf 4 + c@ 0 do ( ) + i pbuf 5 + over + c@ ( signal# level ) + watch-fss-signal ( ) + loop +; + +: watch-fss + empty + begin + 0 watch-fss-axis + 1 watch-fss-axis key? + until + key drop + page +; + [then]
