Author: wmb Date: Sat Oct 22 07:20:01 2011 New Revision: 2640 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2640
Log: OLPC XO-1.75 - synchronized mfpr.fth with the version in CForth. Should be no functional change.
Modified: cpu/arm/mmp2/mfpr.fth
Modified: cpu/arm/mmp2/mfpr.fth ============================================================================== --- cpu/arm/mmp2/mfpr.fth Sat Oct 22 07:19:56 2011 (r2639) +++ cpu/arm/mmp2/mfpr.fth Sat Oct 22 07:20:01 2011 (r2640) @@ -36,7 +36,7 @@ : gpio>mfpr ( gpio# -- mfpr-pa ) mfpr-offsets swap wa+ w@ h# 01.e000 + -; +;
: dump-mfprs ( -- ) base @ @@ -47,7 +47,20 @@ : no-update, ( -- ) 8 w, ; \ 8 is a reserved bit; the code skips these : af@ ( gpio# -- function# ) gpio>mfpr io@ ; : af! ( function# gpio# -- ) gpio>mfpr io! ; -: af, ( n -- ) h# c0 + w, ; -: +fast ( n -- n' ) h# 1800 or ; -: pull-up, ( n -- ) h# c0c0 + w, ; -: pull-dn, ( n -- ) h# a0c0 + w, ; + +: +edge-clr ( n -- n' ) h# 40 or ; +: +medium ( n -- n' ) h# 1000 or ; +: +fast ( n -- n' ) h# 1800 or ; +: +twsi ( n -- n' ) h# 400 or ; +: +pull-up ( n -- n' ) h# c000 or ; +: +pull-dn ( n -- n' ) h# a000 or ; +: +pull-up-alt ( n -- n' ) h# 4000 or ; +: +pull-dn-alt ( n -- n' ) h# 2000 or ; + +\ We always start with edge detection off; it can be turned on later as needed +: af, ( n -- ) +edge-clr w, ; + +: sleep- ( n -- n' ) h# 0200 or ; +: sleep0 ( n -- n' ) h# 0000 or ; +: sleep1 ( n -- n' ) h# 0100 or ; +: sleepi ( n -- n' ) h# 0080 or ;
