Author: wmb Date: Thu Dec 13 01:19:45 2012 New Revision: 3487 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3487
Log: Marvell WLAN driver - moved the host interrupt mask setting code earlier in the startup sequence to make newer 8787 firmware happy. Also fixed a name collision that was causing (harmless) compilation warnings.
Modified: dev/mmc/sdhci/mv8686/fw8686.fth dev/mmc/sdhci/mv8686/sdio.fth
Modified: dev/mmc/sdhci/mv8686/fw8686.fth ============================================================================== --- dev/mmc/sdhci/mv8686/fw8686.fth Wed Dec 12 23:59:24 2012 (r3486) +++ dev/mmc/sdhci/mv8686/fw8686.fth Thu Dec 13 01:19:45 2012 (r3487) @@ -72,7 +72,6 @@
fw-download-ok? 0= if true exit then
- 3 host-int-mask-reg 1 sdio-reg! \ Enable upload (1) and download (2) mv8787? if 2 config-reg 1 sdio-reg! \ Host power up then
Modified: dev/mmc/sdhci/mv8686/sdio.fth ============================================================================== --- dev/mmc/sdhci/mv8686/sdio.fth Wed Dec 12 23:59:24 2012 (r3486) +++ dev/mmc/sdhci/mv8686/sdio.fth Thu Dec 13 01:19:45 2012 (r3487) @@ -21,10 +21,10 @@ instance defer get-write-port ( -- port# )
\ FCode doesn't have 2value so we do it this way -0 value fw-adr -0 value fw-len -: default-fw$ ( -- adr len ) fw-adr fw-len ; -: set-default-fw$ ( adr len -- ) to fw-len to fw-adr ; +0 value fw-name-adr +0 value fw-name-len +: default-fw$ ( -- adr len ) fw-name-adr fw-name-len ; +: set-default-fw$ ( adr len -- ) to fw-name-len to fw-name-adr ;
0 value ioport d# 256 constant blksz \ Block size for data tx/rx @@ -226,11 +226,14 @@ \ Set host interrupt reset to "read to clear" host-int-rsr-reg 1 sdio-reg@ h# 3f or host-int-rsr-reg 1 sdio-reg!
-\ 3 host-int-mask-reg 1 sdio-reg! \ Enable upload (1) and download (2) - \ Set Dnld/upld to "auto reset" card-misc-cfg-reg 1 sdio-reg@ h# 10 or card-misc-cfg-reg 1 sdio-reg! then + \ Newer revisions of the 8787 firmware empirically require that this + \ be enabled early, before firmware download. Older versions, and + \ 8686 firmware, appear to be content with it either here or after + \ firmware startup. + 3 host-int-mask-reg 1 sdio-reg! \ Enable upload (1) and download (2) ;
: sdio-blocks@ ( adr len -- actual )
