Author: wmb Date: 2010-01-26 09:00:30 +0100 (Tue, 26 Jan 2010) New Revision: 1703
Added: cpu/x86/pc/olpc/via/thermaltest.fth Log: Checked in thermaltest.fth
Added: cpu/x86/pc/olpc/via/thermaltest.fth =================================================================== --- cpu/x86/pc/olpc/via/thermaltest.fth (rev 0) +++ cpu/x86/pc/olpc/via/thermaltest.fth 2010-01-26 08:00:30 UTC (rev 1703) @@ -0,0 +1,45 @@ +: cool-ms ( ms -- ) + get-msecs + + begin stdin-idle dup get-msecs - 0< until + drop +; +: hot-ms ( ms -- ) + get-msecs + + begin stdin-idle dup get-msecs - 0< until + drop +; +0 value cool-temperature +0 value warm-temperature +0 value hot-temperature +0 value final-temperature +: thermal-run ( -- error? ) + ." Cooling down ... " + d# 30,000 cool-ms + cpu-temperature to cool-temperature + ." Warming up ... " + d# 1,000 hot-ms + cpu-temperature to warm-temperature + d# 30,000 hot-ms + cpu-temperature to hot-temperature + ." Final cooldown ... " + d# 1,000 cool-ms + + cpu-temperature to final-temperature + hot-temperature warm-temperature - dup d# 12 > if + ." Bad heat spreader - temperature rose " .d ." degrees" cr + true exit + then + final-temperature warm-temperature - dup d# 4 > if + ." Bad heat spreader - cooldown spread was " .d ." degrees" cr + true exit + then + false +; + +\ cool down for 30 seconds (good 54, bad 55) +\ hot for 1 second and measure temp - A (good is 62, bad is 65) +\ hot for 30 seconds and measure temp - B (good 71, bad 85) +\ error if B - A > 12 (good machine is 9, bad is 20) +\ cool for 1 second and measure temp - C +\ error if C-A > 4 (good machine is 1, bad is 10) +
