Author: wmb Date: Sat Sep 1 20:48:30 2012 New Revision: 3268 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3268
Log: OLPC XO-4 - in the early startup memory sizing code, avoid accessing memory controller registers whose clock is turned off, thus avoiding potential hangs.
Modified: cpu/arm/mmp2/initmmu.fth
Modified: cpu/arm/mmp2/initmmu.fth ============================================================================== --- cpu/arm/mmp2/initmmu.fth Fri Aug 31 21:08:16 2012 (r3267) +++ cpu/arm/mmp2/initmmu.fth Sat Sep 1 20:48:30 2012 (r3268) @@ -236,35 +236,49 @@
[ifdef] mmp3 \ MMP3 memory controller - 2 banks, MMAP registers at 0x10 and 0x14 - ldr r2,[r1,#0x10] \ MMAP0 register - ands r3,r2,#1 \ Test CS_VALID - movne r3,#0x10000 \ Scale factor for memory size - movne r2,r2,lsl #11 \ Clear high bits above AREA_LENGTH field - movne r2,r2,lsr #27 \ Move AREA_LENGTH to LSB - addne r0,r0,r3,lsl r2 \ Compute bank size and add to accumulator - - ldr r2,[r1,#0x14] \ MMAP1 register - ands r3,r2,#1 \ Test CS_VALID - movne r3,#0x10000 \ Scale factor for memory size - movne r2,r2,lsl #11 \ Clear high bits above AREA_LENGTH field - movne r2,r2,lsr #27 \ Move AREA_LENGTH to LSB - addne r0,r0,r3,lsl r2 \ Compute bank size and add to accumulator - - add r1,r1,#0x10000 \ Memory controller base address d0010000 - - ldr r2,[r1,#0x10] \ MMAP0 register - ands r3,r2,#1 \ Test CS_VALID - movne r3,#0x10000 \ Scale factor for memory size - movne r2,r2,lsl #11 \ Clear high bits above AREA_LENGTH field - movne r2,r2,lsr #27 \ Move AREA_LENGTH to LSB - addne r0,r0,r3,lsl r2 \ Compute bank size and add to accumulator - - ldr r2,[r1,#0x14] \ MMAP1 register - ands r3,r2,#1 \ Test CS_VALID - movne r3,#0x10000 \ Scale factor for memory size - movne r2,r2,lsl #11 \ Clear high bits above AREA_LENGTH field - movne r2,r2,lsr #27 \ Move AREA_LENGTH to LSB - addne r0,r0,r3,lsl r2 \ Compute bank size and add to accumulator + + \ Don't access a memory controller whose clock is in reset; it will hang + set r2, #0xd428286c \ PMUA_BUS_CLK_RES_CTRL + ldr r2,[r2] \ Register value + tst r2,#0x1 \ MC_RST bit + 0<> if + + ldr r2,[r1,#0x10] \ MMAP0 register + ands r3,r2,#1 \ Test CS_VALID + movne r3,#0x10000 \ Scale factor for memory size + movne r2,r2,lsl #11 \ Clear high bits above AREA_LENGTH field + movne r2,r2,lsr #27 \ Move AREA_LENGTH to LSB + addne r0,r0,r3,lsl r2 \ Compute bank size and add to accumulator + + ldr r2,[r1,#0x14] \ MMAP1 register + ands r3,r2,#1 \ Test CS_VALID + movne r3,#0x10000 \ Scale factor for memory size + movne r2,r2,lsl #11 \ Clear high bits above AREA_LENGTH field + movne r2,r2,lsr #27 \ Move AREA_LENGTH to LSB + addne r0,r0,r3,lsl r2 \ Compute bank size and add to accumulator + then + + \ Don't access a memory controller whose clock is in reset; it will hang + set r2, #0xd428286c \ PMUA_BUS_CLK_RES_CTRL + ldr r2,[r2] \ Register value + tst r2,#0x2 \ MC2_RST bit + 0<> if + add r1,r1,#0x10000 \ Memory controller base address d0010000 + + ldr r2,[r1,#0x10] \ MMAP0 register + ands r3,r2,#1 \ Test CS_VALID + movne r3,#0x10000 \ Scale factor for memory size + movne r2,r2,lsl #11 \ Clear high bits above AREA_LENGTH field + movne r2,r2,lsr #27 \ Move AREA_LENGTH to LSB + addne r0,r0,r3,lsl r2 \ Compute bank size and add to accumulator + + ldr r2,[r1,#0x14] \ MMAP1 register + ands r3,r2,#1 \ Test CS_VALID + movne r3,#0x10000 \ Scale factor for memory size + movne r2,r2,lsl #11 \ Clear high bits above AREA_LENGTH field + movne r2,r2,lsr #27 \ Move AREA_LENGTH to LSB + addne r0,r0,r3,lsl r2 \ Compute bank size and add to accumulator + then [else] \ MMP2 memory controller - 1 bank, MMAP registers at 0x100 and 0x110 ldr r2,[r1,#0x100] \ MMAP0 register
