Author: wmb Date: Wed Jan 11 02:45:49 2012 New Revision: 2816 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2816
Log: EXT2/3/4 filesystem - OLPC trac #11184 - fixed problem with journal recovery on EXT4.
Modified: ofw/fs/ext2fs/layout.fth
Modified: ofw/fs/ext2fs/layout.fth ============================================================================== --- ofw/fs/ext2fs/layout.fth Wed Jan 11 01:42:44 2012 (r2815) +++ ofw/fs/ext2fs/layout.fth Wed Jan 11 02:45:49 2012 (r2816) @@ -226,11 +226,16 @@ drop exit ( -- ) then ( d.pblk# ) else ( adr lblk# ) \ find or allocate physical block - get-pblk# u>d ( adr d.pblk# ) + extent? if ( adr lblk# ) + >d.pblk# 0= abort" EXT4: Allocating blocks inside extents not yet supported" + ( adr d.pblk# ) + else ( adr lblk# ) + get-pblk# u>d ( adr d.pblk# ) + then ( adr d.pblk# ) then \ This interferes with journal recovery \ dup h# f8 < if dup . ." attempt to destroy file system" cr abort then - block bsize move update + d.block bsize move update ;
