Author: lwalter Date: Tue Aug 9 20:23:58 2011 New Revision: 2441 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2441
Log: Add mfgtest support
Added: cpu/x86/pc/alex/yuv2rgb.fth
Added: cpu/x86/pc/alex/yuv2rgb.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/x86/pc/alex/yuv2rgb.fth Tue Aug 9 20:23:58 2011 (r2441) @@ -0,0 +1,174 @@ +purpose: YUY2 to RGB-565 conversion +\ See license at end of file + +\ B = 1.164(Y - 16) + 2.018(U - 128) +\ G = 1.164(Y - 16) - 0.813(V - 128) - 0.391(U - 128) +\ R = 1.164(Y - 16) + 1.596(V - 128) + +[ifdef] 386-assembler + +\ This code operates on pixel values in memory using scaler of 128 +\ Src bytes are Y0 U Y1 V +\ Dst bytes are 565RGB 565RGB (2 16-bit pixels) + +code yuv2>rgb ( src dst count -- ) + 4 [sp] di xchg \ di: dst + 8 [sp] si xchg \ si: src + + ax push ax push ax push \ Save space on stack for V U Y0 + + begin + \ Get Y0, make signed, multiply by 1.164 * 128, save on stack + ax ax xor al lods d# 16 # ax sub d# 149 # ax ax imul-imm ax 0 [sp] mov + ax ax xor al lods d# 128 # ax sub ax 4 [sp] mov \ Get U, make signed, save on stack + \ Get Y1, make signed, multiply by 1.164 * 128, save in BX + ax ax xor al lods d# 16 # ax sub d# 149 # ax bx imul-imm + ax ax xor al lods d# 128 # ax sub ax 8 [sp] mov \ Get V, make signed, save on stack + + \ Generate R + d# 204 # 8 [sp] ax imul-imm \ Multiply V by 1.596 * 128 + bx ax add \ Add Y1 + d# 7 # ax sar \ Scale down by 128 + + 0< if ax ax xor then \ Clip to 0 + d# 255 # ax cmp > if d# 255 # ax mov then \ Clip to 255 + + h# f8 # ax and \ Use upper 5 bits only + d# 8 # ax shl \ Shift R into position + ax cx mov \ Save it + + \ Generate B + d# 258 # 4 [sp] ax imul-imm \ Multiply U by 2.018 * 128 + bx ax add \ Add Y1 + d# 7 # ax sar \ Scale down by 128 + + 0< if ax ax xor then \ Clip to 0 + d# 255 # ax cmp > if d# 255 # ax mov then \ Clip to 255 + + h# f8 # ax and \ Use upper 5 bits only + d# 3 # ax shr \ Shift B into position + ax cx or \ Save it + + \ Generate G + d# -104 # 8 [sp] dx imul-imm \ Multiply V by -0.813 * 128 + d# -50 # 4 [sp] ax imul-imm \ Multiply U by -0.391 * 128 + dx ax add \ Add + ax dx mov \ Save to be used for the 2nd RGB + bx ax add \ Add Y1 + d# 7 # ax sar \ Scale down by 128 + + 0< if ax ax xor then \ Clip to 0 + d# 255 # ax cmp > if d# 255 # ax mov then \ Clip to 255 + + h# fc # ax and \ Use upper 6 bits only + d# 3 # ax shl \ Shift G into position + ax cx or \ Save it + d# 16 # cx shl \ Save second RGB + + \ Generate 2nd R + 0 [sp] bx mov \ Work on Y0 + d# 204 # 8 [sp] ax imul-imm \ Multiply V by 1.596 * 128 + bx ax add \ Add Y0 + d# 7 # ax sar \ Scale down by 128 + + 0< if ax ax xor then \ Clip to 0 + d# 255 # ax cmp > if d# 255 # ax mov then \ Clip to 255 + + h# f8 # ax and \ Use upper 5 bits only + d# 8 # ax shl \ Shift R into position + ax cx or \ Save it + + \ Generate 2nd B + d# 258 # 4 [sp] ax imul-imm \ Multiply U by 2.018 * 128 + bx ax add \ Add Y0 + d# 7 # ax sar \ Scale down by 128 + + 0< if ax ax xor then \ Clip to 0 + d# 255 # ax cmp > if d# 255 # ax mov then \ Clip to 255 + + h# f8 # ax and \ Use upper 5 bits only + d# 3 # ax shr \ Shift B into position + ax cx or \ Save it + + \ Generate 2nd G + dx ax mov \ v*0.813+u*0.391 + bx ax add \ Add Y- + d# 7 # ax sar \ Scale down by 128 + + 0< if ax ax xor then \ Clip to 0 + d# 255 # ax cmp > if d# 255 # ax mov then \ Clip to 255 + + h# fc # ax and \ Use upper 6 bits only + d# 3 # ax shl \ Shift G into position + cx ax or \ Save it + + ax stos \ Output both RGB + + d# 4 # h# c [sp] sub + 0= until + + d# 16 [sp] sp lea \ Clean stack + di pop + si pop +c; +[then] + +[ifndef] yuv2>rgb + +\ Forth code: no division; use scaler of 128 +0 value y1 +0 value v 0 value v*0.813+u*0.391 0 value v*1.596 +0 value u 0 value u*2.018 + +: do-uv-comp ( -- ) + u d# 258 * to u*2.018 + v d# -104 * u d# -50 * + to v*0.813+u*0.391 + v d# 204 * to v*1.596 +; +: y>rgb ( y -- rgb ) + d# 16 - d# 149 * ( 1.164 ) ( y' ) + dup u*2.018 + 7 >>a 0 max d# 255 min h# f8 and 3 >> ( y b ) + over v*0.813+u*0.391 + 7 >>a 0 max d# 255 min h# fc and 3 << or ( y gb ) + swap v*1.596 + 7 >>a 0 max d# 255 min h# f8 and 8 << or ( rgb ) +; +: yuyv>rgb ( y0uy1v -- rgb0 rgb1 ) + lbsplit ( v y1 u y0 ) + swap d# 128 - to u rot d# 128 - to v ( y1 y0 ) + do-uv-comp ( y1 y0 ) + y>rgb ( y1 rgb0 ) + swap y>rgb ( rgb0 rgb1 ) +; + +: yuv2>rgb ( src dst len -- ) + 4 / 0 do ( src dst ) + over i la+ be-l@ yuyv>rgb ( src dst rgb0 rgb1 ) + wljoin over i la+ le-l! ( src dst ) + loop 2drop +; + +[then] + +\ LICENSE_BEGIN +\ Copyright (c) 2011 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END +
