Author: wmb Date: 2009-12-11 06:13:41 +0100 (Fri, 11 Dec 2009) New Revision: 1567
Modified: cpu/x86/pc/olpc/via/smttags.fth Log: OLPC SMT testing script - removed debugging code from tag writeback, and automatically check for missing tags in server response.
Modified: cpu/x86/pc/olpc/via/smttags.fth =================================================================== --- cpu/x86/pc/olpc/via/smttags.fth 2009-12-10 22:57:37 UTC (rev 1566) +++ cpu/x86/pc/olpc/via/smttags.fth 2009-12-11 05:13:41 UTC (rev 1567) @@ -113,7 +113,7 @@
\ Construct the filename used for communicating with the server d# 20 buffer: filename-buf -: smt-filename$ ( -- ) filename-buf count ; +: smt-filename$ ( -- adr len ) filename-buf count ; : set-filename ( -- ) board#$ " %s.txt" sprintf filename-buf place ; @@ -170,6 +170,8 @@
0 0 2value response$
+false value any-tags? + \ If the server sends us tags in the response file, we put \ them in the mfg data : write-new-tags ( adr len -- ) @@ -178,6 +180,7 @@ ?remove-cr ( rem$ line$ ) [char] = left-parse-string ( rem$ value$ key$ ) dup 2 = if ( rem$ value$ key$ ) + true to any-tags? ( rem$ value$ key$ ) put-tag ( rem$ ) else ( rem$ value$ key$ ) 4drop ( rem$ ) @@ -192,10 +195,6 @@
response$ nip 0= if ." Null manufacturing data" cr exit then
-." Type q to skip tag write " key dup emit cr [char] q = if - 2drop false exit -then - flash-write-enable
clear-mfg-buf ( ) @@ -205,14 +204,12 @@ \ " ASSY" " TS" put-ascii-tag ( ) \ " D3" " SG" put-ascii-tag ( ) \ board#$ " B#" put-ascii-tag ( ) - (put-mfg-data) ( ) + any-tags? if (put-mfg-data) then
\ check-tags
no-kbc-reboot kbc-on - - false ;
: silent-probe-usb ( -- ) @@ -248,7 +245,15 @@ begin d# 1000 ms silent-probe-usb usb-key? until then ; +: stall ( -- ) begin halt again ; +: require-int-sd ( -- ) + " int:0" open-dev ?dup if close-dev exit then + " Power off and insert internal SD card" .problem + stall +; + : wait-connections ( -- ) + require-int-sd silent-probe-usb wait-scanner wait-lan @@ -261,13 +266,12 @@ clear-screen test-passed? if ." Selftest passed." cr cr cr - d# 2000 ms green-screen else ." Selftest failed." cr cr cr - d# 2000 ms red-screen then + d# 2000 ms ;
: finish-smt-test ( pass? -- ) @@ -281,6 +285,13 @@ ." Writing tags " parse-smt-response ." Done" cr then
+ any-tag? 0= if + cr cr cr + " WARNING: Invalid response from shop floor server - no tags." .problem + cr cr cr + begin halt again + then ( ) + ." Powering off ..." d# 2000 ms power-off ; @@ -321,5 +332,12 @@ false to diag-switch? ;
+dev /wlan +: selftest ( -- error? ) + true to force-open? open false to force-open? ( opened? ) + if close false else true then ( error? ) +; +dend + \ Automatically run the sequence start-smt-test
