Author: wmb Date: Thu Oct 13 03:07:05 2011 New Revision: 2599 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2599
Log: OLPC XO-1.75 - support for new accelerometer chip.
Modified: cpu/arm/olpc/1.75/accelerometer.fth cpu/arm/olpc/1.75/roller.fth
Modified: cpu/arm/olpc/1.75/accelerometer.fth ============================================================================== --- cpu/arm/olpc/1.75/accelerometer.fth Wed Oct 12 23:49:29 2011 (r2598) +++ cpu/arm/olpc/1.75/accelerometer.fth Thu Oct 13 03:07:05 2011 (r2599) @@ -1,9 +1,8 @@ - hex -0 0 " 6,3a" " /twsi" begin-package +0 0 " " " /twsi" begin-package " accelerometer" name
-my-address my-space encode-phys " reg" property +\ my-address my-space encode-phys " reg" property
\ This is for the stand-alone accelerometer chip LIS33DETR
@@ -11,15 +10,18 @@ : acc-reg@ ( reg# -- b ) 1 1 " smbus-out-in" $call-parent ; : acc-reg! ( b reg# -- ) 2 0 " smbus-out-in" $call-parent ; : ctl1! ( b -- ) h# 20 acc-reg! ; +: ctl4! ( b -- ) h# 23 acc-reg! ; : accelerometer-on ( -- ) h# 47 ctl1! ; : accelerometer-off ( -- ) h# 07 ctl1! ;
: bext ( b -- n ) dup h# 80 and if h# ffffff00 or then ; +: wext ( b -- n ) dup h# 8000 and if h# ffff0000 or then ; : acceleration@ ( -- x y z ) - h# 29 acc-reg@ bext - h# 2b acc-reg@ bext - h# 2d acc-reg@ bext + h# 28 acc-reg@ h# 29 acc-reg@ bwjoin wext 5 >>a + h# 2a acc-reg@ h# 2b acc-reg@ bwjoin wext 5 >>a + h# 2c acc-reg@ h# 2d acc-reg@ bwjoin wext 5 >>a ; + : t+ ( x1 y1 z1 x2 y2 z2 -- x3 y3 z3 ) >r >r >r ( x1 y1 z1 r: z2 y2 x2 ) rot r> + ( y1 z1 x3 r: z2 y2 ) @@ -35,12 +37,12 @@ \ Averaging a lot of samples reduces the effect of vibration : average-acceleration@ ( -- x y z ) acceleration@ ( x y z ) - d# 127 0 do + d# 64 0 do acceleration@ t+ ( x' y' z' ) loop - rot 7 >>a - rot 7 >>a - rot 7 >>a + rot 6 >>a + rot 6 >>a + rot 6 >>a ;
: delay ( -- ) d# 30 ms ; @@ -60,25 +62,28 @@ \ - Mitch's unit, 32 \ - James' A3, 41 (on rubber mat on bare ground) \ - James' A2, 39 -d# 50 value max-delta -: out-of-range? ( delta -- error? ) 3 max-delta between 0= ; + +d# 50 value min-x +d# 50 value min-y +d# 150 value min-z +d# 100 value max-x +d# 100 value max-y +d# 300 value max-z +: range? ( delta max-delta -- error? ) between 0= ;
: error? ( dx dy dz -- error? ) - out-of-range? if ." X axis error" cr 2drop true exit then ( dx dy ) - out-of-range? if ." Y axis error" cr drop true exit then ( dx ) - out-of-range? if ." X axis error" cr true exit then ( ) + min-z max-z range? if ." Z axis error" cr 2drop true exit then ( dx dy ) + min-y max-y range? if ." Y axis error" cr drop true exit then ( dx ) + min-x max-x range? if ." X axis error" cr true exit then ( ) false ;
-: selftest ( -- error? ) - open 0= if true exit then - - final-test? if accelerometer-off false exit then - +: lis33de-selftest ( -- error? ) \ Use the device's selftest function to force a change in one direction delay ( ) average-acceleration@ ( x y z ) - h# 4f ctl1! delay ( x y z ) \ Set the STM bit + h# 4f ctl1! ( x y z ) \ Set the STM bit + delay average-acceleration@ t- ( dx dy dz ) \ STM applies negative bias to Y, but our deltas are inverted \ because we subtract the new measurement from the old. @@ -89,15 +94,70 @@ \ Use the device's selftest function to force a change in the opposite direction accelerometer-on delay ( ) \ Back to normal - STM and STP both off average-acceleration@ ( x y z ) - h# 57 ctl1! delay ( x y z ) \ Set the STP bit + h# 57 ctl1! ( x y z ) \ Set the STP bit + delay average-acceleration@ t- ( dx dy dz ) \ STP applies negative bias to X and Z, but our deltas are inverted \ because we subtract the new measurement from the old. swap negate swap ( dx dy' dz ) error? if accelerometer-off true exit then + false +; +: lis3dhtr-selftest ( -- ) + \ Use the device's selftest function to force a change in one direction + delay ( ) + average-acceleration@ ( x y z ) + h# 0a ctl4! ( x y z ) \ High res, Selftest mode 0 + delay + average-acceleration@ t- ( dx dy dz ) + rot negate rot negate rot negate + h# 08 ctl4! ( x y z ) \ High res, Normal mode + error? if accelerometer-off true exit then + + \ Use the device's selftest function to force a change in the opposite direction + accelerometer-on delay ( ) \ Back to normal - STM and STP both off + average-acceleration@ ( x y z ) + h# 0c ctl4! ( x y z ) \ High res, Selftest mode 1 + delay + average-acceleration@ t- ( dx dy dz ) + h# 08 ctl4! ( x y z ) \ High res, Normal mode + error? if accelerometer-off true exit then
accelerometer-off false ; +defer lis-selftest +: selftest ( -- error? ) + open 0= if true exit then + + final-test? if accelerometer-off false exit then + + lis-selftest +; + +: probe ( -- ) + h# 3a 6 " set-address" $call-parent + d# 25,000 " set-bus-speed" $call-parent + ['] accelerometer-on catch if + \ The attempt to talk at the old address failed, so we assume the new chip + \ Support for new LIS3DHTR chip + d# 50 to min-x d# 50 to min-y d# 50 to min-z + d# 150 to max-x d# 150 to max-y d# 300 to max-z + h# 32 6 encode-phys " reg" property + ['] lis3dhtr-selftest to lis-selftest + else + accelerometer-off + \ Something responded to the old address, so we assume it's the old chip + \ Support for old LIS33DE chip + d# 20 to min-x d# 20 to min-y d# 20 to min-z + d# 400 to max-x d# 400 to max-y d# 400 to max-z + h# 3a 6 encode-phys " reg" property + ['] lis33de-selftest to lis-selftest + then +;
end-package + +stand-init: Accelerometer + " /accelerometer" " probe" execute-device-method drop +;
Modified: cpu/arm/olpc/1.75/roller.fth ============================================================================== --- cpu/arm/olpc/1.75/roller.fth Wed Oct 12 23:49:29 2011 (r2598) +++ cpu/arm/olpc/1.75/roller.fth Thu Oct 13 03:07:05 2011 (r2599) @@ -75,7 +75,7 @@
d# 19 d# 20 a/b>fraction value damping
-d# 1 d# 10 a/b>fraction value acc-scale +d# 1 d# 80 a/b>fraction value acc-scale
d# 20 constant ball-radius d# 40 constant ball-diameter
