Author: wmb Date: Mon Jan 16 22:05:34 2012 New Revision: 2832 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2832
Log: OLPC trac #11577 - Fixed problem in unix-seconds> that caused off-by-one-day errors for dates later than Jan 28, 2000. The problem was that the year 2000 is a leap year. The 100-year rule says that it shouldn't be leap, but the 400-year rule overrides that.
Modified: ofw/fs/unixtime.fth
Modified: ofw/fs/unixtime.fth ============================================================================== --- ofw/fs/unixtime.fth Mon Jan 16 22:05:30 2012 (r2831) +++ ofw/fs/unixtime.fth Mon Jan 16 22:05:34 2012 (r2832) @@ -32,12 +32,10 @@ swap 1- swap 0 ?do i days/month + c@ + loop ( day-in-year ) ;
-\ d# 365 constant d/y -d/y d# 30 * \ Years from 1970 to 2000 -d# 7 + \ Leap days from 1970 to 2000 -d# 31 + \ Days in January 2000 -d# 28 + \ Days in February 2000 (not a leap year) +d/y d# 2 * \ Days in the 2 years from 1970 to 1972 +d# 31 + \ Days in January 1972 +d# 29 + \ Days in February 1972 (a leap year) constant days-to-break
: unix-seconds> ( seconds -- s m h d m y ) @@ -45,14 +43,10 @@ \ at the expense of breaking dates before 1970. d# 60 /mod d# 60 /mod d# 24 /mod ( s m h days )
- \ Rotate the number space so that day 0 is March 1, 2000 - \ That's convenient because it begins a 4 year + 1 day leap cycle + \ Rotate the number space so that day 0 is March 1, 1972, + \ the beginning of a 4 year + 1 day leap cycle days-to-break -
- \ Adjust days before day 0 for the fact that 2000, unlike other - \ 0mod4 years, is not a leap year - dup 0< if 1- then ( s m h days' ) - \ Reduce modulo the number of days in a 4-year leap cycle \ This depends on floored division [ d/y 4 * 1+ ] literal /mod >r ( s m h day-in-cycle r: cycles ) @@ -77,11 +71,11 @@ d# 12 - r> 1+ >r ( s m h d month' r: year' ) then ( s m h d month r: year )
- r> d# 2000 + ( s m h d m y ) + r> d# 1972 + ( s m h d m y ) ;
: >unix-seconds ( s m h d m y -- seconds ) \ since 1970 - d# 2000 - >r ( s m h d m r: y' ) + d# 1972 - >r ( s m h d m r: y' )
\ Move January and February to the end so the leap day is day number 365 dup 3 < if ( s m h d month' r: y ) @@ -98,13 +92,9 @@ r> d/y * + ( s m h day-in-year year-days ) + ( s m h days )
- \ Adjust for the missing leap day in 2000 - dup 0< if 1+ then ( s m h days' ) - \ Adjust to 1970 days-to-break + ( s m h days' )
- \ Changing the 3 *'s below to u*'s would "fix" the year 2038 problem \ at the expense of breaking dates before 1970. d# 24 * + d# 60 * + d# 60 * + ( seconds )
