Author: wmb Date: 2009-01-04 03:35:30 +0100 (Sun, 04 Jan 2009) New Revision: 1063
Added: cpu/x86/pc/biosload/config-iscsi.fth Modified: cpu/x86/pc/biosload/config-virtualbox.fth cpu/x86/pc/biosload/devices.fth Log: Biosload configurations - enabled pseudo-nvram in the virtualbox configuration now that the floppy driver works.
Added: cpu/x86/pc/biosload/config-iscsi.fth =================================================================== --- cpu/x86/pc/biosload/config-iscsi.fth (rev 0) +++ cpu/x86/pc/biosload/config-iscsi.fth 2009-01-04 02:35:30 UTC (rev 1063) @@ -0,0 +1,52 @@ +\ See license at end of file +purpose: Establish configuration definitions + +\ --- The environment that "boots" OFW --- +\ - Image Format - Example Media - previous stage bootloader + +\ - ELF format w/ Multiboot signature - various media - GRUB +create grub-loaded + +create debug-startup +\ create serial-console +create resident-packages +create addresses-assigned \ Don't reassign PCI addresses +\ create virtual-mode +\ create use-root-isa +create use-timestamp-counter +create use-pci-isa +create use-isa-ide +create use-ega +create use-elf +\ create use-ne2000 +create use-watch-all +create pseudo-nvram +\ create use-null-nvram +\ create no-floppy-node +create use-iscsi + +fload ${BP}/cpu/x86/pc/biosload/addrs.fth + +\ LICENSE_BEGIN +\ Copyright (c) 2006 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Modified: cpu/x86/pc/biosload/config-virtualbox.fth =================================================================== --- cpu/x86/pc/biosload/config-virtualbox.fth 2009-01-04 02:33:00 UTC (rev 1062) +++ cpu/x86/pc/biosload/config-virtualbox.fth 2009-01-04 02:35:30 UTC (rev 1063) @@ -20,7 +20,8 @@ create use-elf \ create use-ne2000 create use-watch-all -create use-null-nvram +create pseudo-nvram +\ create use-null-nvram \ create no-floppy-node
Modified: cpu/x86/pc/biosload/devices.fth =================================================================== --- cpu/x86/pc/biosload/devices.fth 2009-01-04 02:33:00 UTC (rev 1062) +++ cpu/x86/pc/biosload/devices.fth 2009-01-04 02:35:30 UTC (rev 1063) @@ -183,8 +183,9 @@ [ifdef] pseudo-nvram fload ${BP}/cpu/x86/pc/biosload/filenv.fth dev /file-nvram +: fd-nv-file ( -- ) " a:\nvram.dat" ; : hd-nv-file ( -- ) " c:\nvram.dat" ; -' hd-nv-file to nv-file +' fd-nv-file to nv-file device-end stand-init: Pseudo-NVRAM " /file-nvram" open-dev to nvram-node
