Author: wmb Date: Mon Aug 29 03:31:47 2011 New Revision: 2483 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2483
Log: ARM - Added assembler support for iwMMX instructions. The disassembler remains ignorant of those instructions.
Modified: cpu/arm/assem.fth cpu/arm/code.fth cpu/arm/scc.fth
Modified: cpu/arm/assem.fth ============================================================================== --- cpu/arm/assem.fth Mon Aug 29 03:30:53 2011 (r2482) +++ cpu/arm/assem.fth Mon Aug 29 03:31:47 2011 (r2483) @@ -49,7 +49,8 @@ : asm, ( n -- ) here /l asm-allot asm! ; previous definitions
-: !op ( -- ) newword asm, ; +: )op ( -- ) newword asm, ; +: {} is newword ;
0 value op-end
@@ -69,8 +70,8 @@
0 value adr-delim
-: xop ( change-bits -- ) newword xor is newword ; -: iop ( on-bits -- ) newword or is newword ; +: xop ( change-bits -- ) newword xor {} ; +: iop ( on-bits -- ) newword or {} ;
: ad-error ( msg$ -- ) \ Types the message passed in, the contents of cbuf and the stack. @@ -105,7 +106,7 @@
: /rem ( n -- ) rem$ rot /string set-rem$ ;
-: init-operands ( -- ) +: op( ( -- ) \ We can't do this because rem$ isn't set if we have an exact match \ rem-len abort" Invalid opcode" 0 0 set-rem$ @@ -157,6 +158,8 @@ next-cons constant adt-shift \ Shift op in Shifter Operands. next-cons constant adt-rrx next-cons constant adt-immed \ #immediate_value. +next-cons constant adt-wmmx \ wr0, wr1, ... +next-cons constant adt-wcx \ wc0, wC1, ... constant adt-last \ Last +1 of the address word types.
: adt? ( n -- adt? ) adt-1st adt-last within ; @@ -284,6 +287,12 @@ : sreg: ( n "name" -- ) create , does> @ adt-sreg ; : sregs: ( 20x"name" -- ) 20 0 do i sreg: loop ;
+\ Define the wireless MMX registers. +: wmmxreg: ( n "name" -- ) create , does> @ adt-wmmx ; +: wmmxregs: ( 10x"name" -- ) 10 0 do i wmmxreg: loop ; +: wcxreg: ( n "name" -- ) create , does> @ adt-wcx ; + + : range-error ( n msg$ -- ) type .d cr abort ;
: expecting ( $ -- ) ." Expecting " ad-error ; @@ -520,24 +529,24 @@ 00ffffff land ; : amode-bbl ( b-adr -- ) - init-operands + op( [ifdef] testing get-whatever drop aoffset [else] get-immediate here [then] >br-offset iop - !op + )op ;
-: amode-bx ( -- ) init-operands get-r00 !op ; +: amode-bx ( -- ) op( get-r00 )op ;
: ?psr ( adt -- ) adt-xpsr <> " [cs]psr" ?expecting ;
-: amode-mrs ( -- ) init-operands get-r12 get-whatever ?psr iop !op ; +: amode-mrs ( -- ) op( get-r12 get-whatever ?psr iop )op ;
: amode-msr ( -- ) - init-operands + op(
\ get xpsr and fields require-field $asm-execute ?psr iop ( ) @@ -554,14 +563,14 @@ \ Get the next field which we expect to be rx, or #num. require-field adr-delim case ( field$ delim ) ascii * of \ Take the address from the stack ( n adt-code field$ ) - 2drop do-#32 newword fff0ffff land 02080000 or is newword + 2drop do-#32 newword fff0ffff land 02080000 or {} endof
ascii # of ( field$ ) \ Immediate address, the field should be empty and the real \ field is the next one. \ get an immediate field, the default is _f = 8, - newword fff0ffff land 02080000 or is newword + newword fff0ffff land 02080000 or {} endof
0 of \ This should be a register. ( field$ ) @@ -576,35 +585,35 @@
expecting-reg/immed endcase - !op + )op ;
-: amode-vmrs ( -- ) init-operands get-r12 get-whatever ?psr iop !op ; -: amode-vmsr ( -- ) init-operands get-whatever ?psr iop get-r12 !op ; +: amode-vmrs ( -- ) op( get-r12 get-whatever ?psr iop )op ; +: amode-vmsr ( -- ) op( get-whatever ?psr iop get-r12 )op ;
-: (amode-mul) ( -- ) init-operands get-r16 get-r00 get-r08 ; -: amode-mul ( -- ) (amode-mul) !op ; -: amode-mla ( -- ) (amode-mul) get-r12 !op ; -: amode-lmul ( -- ) init-operands get-r12 get-r16 get-r00 get-r08 !op ; -: amode-rrop2 ( -- ) init-operands get-r12 get-r16 get-opr2 !op ; -: amode-rnop2 ( -- ) init-operands get-r16 get-opr2 !op ; -: amode-rdop2 ( -- ) init-operands get-r12 get-opr2 !op ; -: amode-rev ( -- ) init-operands get-r12 get-r00 !op ; +: (amode-mul) ( -- ) op( get-r16 get-r00 get-r08 ; +: amode-mul ( -- ) (amode-mul) )op ; +: amode-mla ( -- ) (amode-mul) get-r12 )op ; +: amode-lmul ( -- ) op( get-r12 get-r16 get-r00 get-r08 )op ; +: amode-rrop2 ( -- ) op( get-r12 get-r16 get-opr2 )op ; +: amode-rnop2 ( -- ) op( get-r16 get-opr2 )op ; +: amode-rdop2 ( -- ) op( get-r12 get-opr2 )op ; +: amode-rev ( -- ) op( get-r12 get-r00 )op ;
: set-imm16 ( n -- ) dup fff and 0 set-field d# 12 >> d# 16 set-field ; : amode-movw ( -- ) - init-operands get-r12 get-immediate ( imm ) + op( get-r12 get-immediate ( imm ) dup 0 10000 within 0= if " Immediate value won't fit in 16 bits" ad-error then - set-imm16 !op + set-imm16 )op ;
: amode-lsm ( need-r16? -- ) - init-operands + op( if get-r16 ( ) adr-delim ascii ! = if ( ) @@ -640,11 +649,11 @@
\ We've finished the register list, is there a ^ hanging on the end? ascii ^ parse-1 if flip-b then - !op + )op ;
: amode-vlsm ( need-r16? -- ) - init-operands + op( if get-r16 ( ) adr-delim ascii ! = if ( ) @@ -680,7 +689,7 @@ repeat ( first last )
\ Encode the resulting Vd, imm8 fields - 1+ over - 2* iop false set-vdfield !op + 1+ over - 2* iop false set-vdfield )op ;
\ rd, [rn, <immed12>] {!} @@ -758,16 +767,16 @@
get-r12 ['] get-off12 get-ea ; -: amode-lst ( -- ) init-operands (amode-ls) !op ; +: amode-lst ( -- ) op( (amode-ls) )op ;
: {!} ( -- ) ascii ! parse-1 if flip-w then ;
-: amode-lsr ( -- ) init-operands (amode-ls) {!} !op ; +: amode-lsr ( -- ) op( (amode-ls) {!} )op ;
: amode-pld ( -- ) \ Like amode-ls and friends except r16 vice r12. 0080.0000 iop - ['] get-off12 get-ea !op + ['] get-off12 get-ea )op ;
: get-off8 ( -- ) @@ -794,6 +803,18 @@ p? if {!} then ;
+: imm8-funny ( -- ) + \ Get the immediate value for wshufh + get-whatever case + adt-immed of + d# 8 ?#bits ( immed ) + dup f and 0 iop ( immed ) \ Low bits at field 0 + 4 rshift f and 14 iop ( ) \ High bits at field d# 20 + endof + + " immediate value" expecting + endcase +; : get-imm8 ( -- ) \ Get the offset for v[ldr|str] instructions get-whatever case @@ -821,46 +842,88 @@ \ rd, [rn], +-rm
: amode-lssh ( -- ) - init-operands + op( \ Set the add offset and immediate value as defaults. 00c0.0000 iop get-r12 ['] get-off8 get-ea - !op + )op ;
: amode-imed24 ( -- ) - init-operands get-immediate d# 24 ?#bits iop !op + op( get-immediate d# 24 ?#bits iop )op ;
: get-off0 ( -- ) " Offset not allowed" ad-error ; : amode-swp ( -- ) - init-operands get-r12 get-r00 ['] get-off0 get-ea !op + op( get-r12 get-r00 ['] get-off0 get-ea )op ; : amode-ldrex ( -- ) - init-operands get-r12 ['] get-off0 get-ea !op + op( get-r12 ['] get-off0 get-ea )op ; : amode-copr ( -- ) \ Co-processors: mcr, mrc \ p, #, r, c, c, # - init-operands + op( adt-coproc 0f 08 get-this adt-immed 07 15 get-this adt-reg 0f 0c get-this adt-coreg 0f 10 get-this adt-coreg 0f 00 get-this adt-immed 07 05 get-this - !op + )op ;
: amode-cdp ( -- ) \ Co-processors: cdp \ p, #, c, c, c, # - init-operands + op( adt-coproc 0f 08 get-this adt-immed 0f 14 get-this adt-coreg 0f 0c get-this adt-coreg 0f 10 get-this adt-coreg 0f 00 get-this adt-immed 07 05 get-this - !op + )op +; + +: wcx adt-wcx 0f 10 get-this ; +: wrd adt-wmmx 0f 0c get-this ; +: wrd5 adt-wmmx 0f 05 get-this ; +: wrn adt-wmmx 0f 10 get-this ; +: wrm adt-wmmx 0f 00 get-this ; +: amode-wmmx-cdp ( -- ) + \ wrd, wrn, wrm + op( + wrd + wrn + wrm + )op +; +: amode-wmmx-cdp2 ( -- ) + \ wrd, wrn + op( + wrd + wrn + )op +; +: imm3-0 + adt-immed 07 00 get-this +; +: amode-wmmx-cdp-imm ( -- ) + \ wrn, wrd, wrm + op( + wrn + wrd + wrm + adt-immed 07 14 get-this + )op +; + +: amode-wmmx-transfer ( -- ) + \ wrd, rn, wrm + op( + wrd + adt-reg 0f 0c get-this + wrm + )op ;
\ Get the offset for ldc, stc instructions. @@ -874,19 +937,19 @@ ;
: amode-lsc ( -- ) \ Co-processors: ldc, stc - init-operands + op( adt-coproc 0f 08 get-this adt-coreg 0f 0c get-this ['] get-off-c get-ea - !op + )op ;
: amode-vldst ( -- ) \ vldr, vstr instructions - init-operands + op( \ Set the add offset and 64-bit width as defaults. 0080.0100 iop get-d12 ['] get-imm8 get-ea - !op + )op ;
\ ---------------- @@ -924,6 +987,79 @@ then ;
+: {hwd} ( opc -- ) + {} + ascii h parse-1 if 0040.0000 xop exit then + ascii w parse-1 if 0080.0000 xop exit then + ascii d parse-1 if 00c0.0000 xop exit then + " h w or d" expecting +; +: {bhw} ( -- ) + ascii b parse-1 if 0000.0000 xop exit then + ascii h parse-1 if 0040.0000 xop exit then + ascii w parse-1 if 0080.0000 xop exit then + " b h or w" expecting +; +: {bhw}2 ( -- ) + ascii b parse-1 if 0000.0000 xop exit then + ascii h parse-1 if 0000.0040 xop exit then + ascii w parse-1 if 0000.0080 xop exit then + " b h or w" expecting +; +: {bhwd} ( -- ) + {} + ascii b parse-1 if 0000.0000 iop exit then + ascii h parse-1 if 0040.0000 iop exit then + ascii w parse-1 if 0000.0100 iop exit then + ascii d parse-1 if 0040.0100 iop exit then + " b h w or d" expecting +; +: {us} ( opc -- ) + {} + ascii u parse-1 if 0000.0000 xop exit then + ascii s parse-1 if 0020.0000 xop exit then + " u or s" expecting +; +: {us} ( opc -- ) + {} + ascii u parse-1 if 0000.0000 xop exit then + ascii s parse-1 if 0020.0000 xop exit then + " u or s" expecting +; +: {tb}x ( -- ) + ascii b parse-1 if 0000.0000 xop exit then + ascii t parse-1 if 0002.0000 xop exit then + " t or b" expecting +; +: {tb}y ( -- ) + ascii b parse-1 if 0000.0000 xop exit then + ascii t parse-1 if 0001.0000 xop exit then + " t or b" expecting +; + +: {ml} ( -- ) + ascii l parse-1 if 0000.0000 xop exit then + ascii m parse-1 if 0010.0000 xop exit then + " m or l" expecting +; +: {z} ( -- ) ascii z parse-1 if 0010.0000 iop then ; +: {bh}2 ( -- ) + {} + ascii b parse-1 if 0000.0000 xop exit then + ascii h parse-1 if 0040.0000 xop exit then + " b or h" expecting +; + +: need-s ( -- ) ascii s parse-1 if " us or ss" expecting then ; +: {usss} ( -- ) + ascii u parse-1 if 0010.0000 xop need-s exit then + ascii s parse-1 if 0030.0000 xop need-s exit then + " us or ss" expecting +; +: {g} + ascii g parse-1 if 0000.0100 xop ( !! need to change mode of last operand from wrN to rN ) then +; + : parse-condition? ( -- cond true | false ) \ The next two characters of the input string will be checked for a \ valid condition code. If found, the appropriate code will be @@ -941,8 +1077,7 @@ then ;
-: {cond} ( opcode -- ) - is newword +: +{cond} ( -- ) \ The next two characters of the input string will be checked for a \ valid condition code. If found, the appropriate code will be \ inserted in newword and the string pointer / length will be @@ -951,8 +1086,30 @@ parse-condition? 0= if h# e then d# 28 set-field \ put the condition code in. ; +: {cond} ( opcode -- ) + {} + +{cond} +; : {cond/s} ( opcode -- ) {cond} {s} ; -: {uncond} ( opcode -- ) is newword ; + +: amode-wldst ( -- ) + op( + get-whatever + case + adt-wcx of + 0c set-field + f000.0000 iop + newword 0040.0010 and 0000.0010 <> if + " Size must be W for WLDR or WSTR with wCX" ad-error + then + endof + adt-wmmx of 0c set-field endof + " wRn or wCn" expecting + endcase + ['] get-off-c get-ea + )op +; +: amode-tmia ( -- ) op( wrd5 get-r00 get-r12 )op ;
: parse-inc ( default$ l-flag -- ) \ Parse the increment tag for ldm and stm. @@ -1051,9 +1208,14 @@ regs: r0 r1 r2 r3 r4 r5 r6 r7 r8 r9 r10 r11 r12 r13 r14 r15 dregs: d0 d1 d2 d3 d4 d5 d6 d7 d8 d9 d10 d11 d12 d13 d14 d15 d16 d17 d18 d19 d20 d21 d22 d23 d24 d25 d26 d27 d28 d29 d30 d31 sregs: s0 s1 s2 s3 s4 s5 s6 s7 s8 s9 s10 s11 s12 s13 s14 s15 s16 s17 s18 s19 s20 s21 s22 s23 s24 s25 s26 s27 s28 s29 s30 s31 - +wmmxregs: wr0 wr1 wr2 wr3 wr4 wr5 wr6 wr7 wr8 wr9 wr10 wr11 wr12 wr13 wr14 wr15 +0 wcxreg: wcid 1 wcxreg: wcon 2 wcxreg: wcssf 3 wcxreg: wcasf +8 wcxreg: wcgr0 9 wcxreg: wcgr1 a wcxreg: wcgr2 b wcxreg: wcgr3 + previous definitions
+ + also arm-assembler definitions : and 0000.0000 {cond/s} amode-rrop2 ; : eor 0020.0000 {cond/s} amode-rrop2 ; @@ -1099,6 +1261,72 @@ : mcr 0e00.0010 {cond} amode-copr ; : mrc 0e10.0010 {cond} amode-copr ;
+: do-mmx ( opc -- ) 0e00.0000 or {cond} amode-wmmx-cdp ; +: wor 0000.0000 do-mmx ; +: wxor 0010.0000 do-mmx ; +: wand 0020.0000 do-mmx ; +: wandn 0030.0000 do-mmx ; +: wavg2b 0080.0000 do-mmx ; +: wavg2br 0090.0000 do-mmx ; +: wavg2h 00c0.0000 do-mmx ; +: wavg2hr 00d0.0000 do-mmx ; + +: waligni 0e00.0020 {cond} amode-wmmx-cdp-imm ; +: walignr0 0080.0020 do-mmx ; +: walignr1 0090.0020 do-mmx ; +: walignr2 00a0.0020 do-mmx ; +: walignr3 00b0.0020 do-mmx ; + +: do-mmx-shift ( opc -- ) 0e00.0000 or {hwd} {g} +{cond} amode-wmmx-cdp ; +: wsra 0000.0040 do-mmx-shift ; +: wsll 0010.0040 do-mmx-shift ; +: wsll 0020.0040 do-mmx-shift ; +: wror 0030.0040 do-mmx-shift ; + +: wmcmpeq 0e00.0060 {} {bhw} +{cond} amode-wmmx-cdp ; +: wmcmpgt 0e10.0060 {us} {bhw} +{cond} amode-wmmx-cdp ; + +: wpack 0e00.0080 {hwd} {usss} +{cond} amode-wmmx-cdp ; + +: wunpckeh 0e00.00c0 {us} {bhw} +{cond} amode-wmmx-cdp2 ; +: wunpckel 0e00.00e0 {us} {bhw} +{cond} amode-wmmx-cdp2 ; +: wunpckih 0e10.00c0 {} {bhw} +{cond} amode-wmmx-cdp ; +: wunpckih 0e10.00e0 {} {bhw} +{cond} amode-wmmx-cdp ; + +: wmul 0e00.0100 {us} {ml} +{cond} amode-wmmx-cdp ; +: wmac 0e40.0100 {us} {z} +{cond} amode-wmmx-cdp ; +: wmadd 0e80.0100 {us} +{cond} amode-wmmx-cdp ; + +: wsad 0e00.0120 {bh}2 {z} +{cond} amode-wmmx-cdp ; + +: wmax 0e00.0160 {us} {bhw} +{cond} amode-wmmx-cdp ; +: wmin 0e10.0160 {us} {bhw} +{cond} amode-wmmx-cdp ; + +: wadd 0e00.0180 {} {bhw} {usss} +{cond} amode-wmmx-cdp ; +: wadd 0e00.01a0 {} {bhw} {usss} +{cond} amode-wmmx-cdp ; +: wacc 0e00.01c0 {} {bhw} +{cond} amode-wmmx-cdp2 ; +: wshufh 0e00.01e0 {cond} op( wrd wrn imm8-funny )op ; +: tmcr 0e00.0110 {cond} op( wcx get-r12 )op ; +\ : tmia 0e2c.0010 {} {tb}x {tb}y +{cond} amode-tmia ; +: tmia 0e20.0010 {} +{cond} amode-tmia ; +: tmiaph 0e28.0010 {} +{cond} amode-tmia ; + +: tbcst 0e40.0010 {} {bhw}2 {cond} op( wrd get-r12 )op ; +: tinsr 0e60.0010 {} {bhw}2 {cond} op( wrd get-r12 imm3-0 )op ; + +: tmcrr 0c40.0000 {cond} op( wrm get-r12 get-r16 )op ; +: tmrrc 0c50.0000 {cond} op( get-r12 get-r16 wrm )op ; + +: tmrc 0e10.0110 {cond} op( get-r12 wcx )op ; +: tmovmsk 0e10.0030 {} {bhw} +{cond} op( get-r12 wrn )op ; +: tandc 0e13.f130 {} {bhw} +{cond} op( get-r12 )op ; \ rs must be R15 +: torc 0e13.f150 {} {bhw} +{cond} op( get-r12 )op ; \ rs must be R15 +: textrc 0e13.f170 {} {bhw} +{cond} op( get-r12 imm3-0 )op ; \ rs must be R15 +: textrm 0e10.0070 {us} {bhw} +{cond} op( get-r12 wrn imm3-0 )op ; + +: wldr 0c10.0000 {bhwd} +{cond} amode-wldst ; +: wstr 0c00.0000 {bhwd} +{cond} amode-wldst ; + : swi 0f00.0000 {cond} amode-imed24 ;
: b 0a00.0000 {cond} amode-bbl ; @@ -1146,18 +1374,18 @@ newword -rot ( newword reg# imm ) lwsplit swap ( newword reg# imm.hi imm.lo ) set-imm16 0300.0000 iop ( newword reg# imm.hi ) - over rd-field !op \ movw rN,#<imm> + over rd-field )op \ movw rN,#<imm> ?dup if ( newword reg# imm.hi ) - rot is newword ( reg# imm.hi ) + rot {} ( reg# imm.hi ) set-imm16 0340.0000 iop ( reg# ) - rd-field !op \ movt rN,#<imm> + rd-field )op \ movt rN,#<imm> else 2drop then ; : (set) ( address? -- ) >r - 0000.0000 {cond} init-operands + 0000.0000 {cond} op( \ Put the register number on the return stack so it won't interfere \ with the stack items used by any "*" operands there may be. get-register >r ( r: adr? reg# ) @@ -1186,27 +1414,27 @@ then ( reg# op ) then ( reg# op ) then ( reg# op ) - iop rd-field !op + iop rd-field )op ; : adr ( -- ) true (set) ; : set ( -- ) false (set) ;
\ Wrapper Call - FirmWorks pseudo-op for armsim wrapper calls -: wrc ( -- ) h# 03200010 {cond} init-operands get-r16 !op ; +: wrc ( -- ) 03200010 {cond} op( get-r16 )op ;
-: nop32 ( -- ) h# 0320f000 {cond} !op ; -: yield ( -- ) h# 0320f001 {cond} !op ; -: wfe ( -- ) h# 0320f002 {cond} !op ; -: wfi ( -- ) h# 0320f003 {cond} !op ; -: sev ( -- ) h# 0320f004 {cond} !op ; - -: nop ( -- ) h# e1a00000 asm, ; \ mov r0,r0 -: dsb ( -- ) h# f57ff040 asm, ; -: dmb ( -- ) h# f57ff050 asm, ; -: isb ( -- ) h# f57ff060 asm, ; +: nop32 ( -- ) 0320f000 {cond} op( )op ; +: yield ( -- ) 0320f001 {cond} op( )op ; +: wfe ( -- ) 0320f002 {cond} op( )op ; +: wfi ( -- ) 0320f003 {cond} op( )op ; +: sev ( -- ) 0320f004 {cond} op( )op ; + +: nop ( -- ) e1a00000 {} op( )op ; \ mov r0,r0 +: dsb ( -- ) f57ff040 {} op( )op ; \ "dsb sy" is f57ff04f +: dmb ( -- ) f57ff050 {} op( )op ; +: isb ( -- ) f57ff060 {} op( )op ;
-: pld ( -- ) h# f550.f000 {uncond} amode-pld ; -: pldw ( -- ) h# f510.f000 {uncond} amode-pld ; +: pld ( -- ) f550.f000 {} amode-pld ; +: pldw ( -- ) f510.f000 {} amode-pld ;
: # ( -- adt-immed ) adt-immed ; : reg ( -- adt-reg ) adt-reg ;
Modified: cpu/arm/code.fth ============================================================================== --- cpu/arm/code.fth Mon Aug 29 03:30:53 2011 (r2482) +++ cpu/arm/code.fth Mon Aug 29 03:31:47 2011 (r2483) @@ -80,15 +80,15 @@ : lnk ( -- ) \ [ also register-names ] lk [ previous ] drop ( reg# ) lk drop ( reg# ) - 01a0.0000 or {cond/s} init-operands get-r12 !op + 01a0.0000 or {cond/s} op( get-r12 )op ;
: (incdec) ( op-template -- ) {cond/s} - init-operands + op( get-register dup rd-field rb-field get-opr2 - !op + )op ;
\ inc{cond}{s} rN,<immed> @@ -101,7 +101,7 @@ \ sub{cond}{s} rN,rN,<immed> : dec ( -- ) 0040.0000 (incdec) ;
-: (pshpop) ( op-template -- ) {cond} init-operands get-r12 get-r16 !op ; +: (pshpop) ( op-template -- ) {cond} op( get-r12 get-r16 )op ; \ psh{cond} rN,rM \ is equivalent to \ str{cond} rN,[rM,-1cell]! @@ -118,7 +118,7 @@ : nxt ( -- ) \ [ also register-names ] up [ previous ] drop ( reg# ) up drop - 01a0.f000 or {cond/s} init-operands !op + 01a0.f000 or {cond/s} op( )op ;
also forth definitions
Modified: cpu/arm/scc.fth ============================================================================== --- cpu/arm/scc.fth Mon Aug 29 03:30:53 2011 (r2482) +++ cpu/arm/scc.fth Mon Aug 29 03:31:47 2011 (r2483) @@ -7,6 +7,7 @@ code tlb-type@ ( -- n ) psh tos,sp mrc p15,0,tos,cr0,cr0,3 c; code control@ ( -- n ) psh tos,sp mrc p15,0,tos,cr1,cr0,0 c; code aux-control@ ( -- n ) psh tos,sp mrc p15,0,tos,cr1,cr0,1 c; +code coprocessor-access@ ( -- n ) psh tos,sp mrc p15,0,tos,cr1,cr0,2 c; code ttbase@ ( -- n ) psh tos,sp mrc p15,0,tos,cr2,cr0,0 c; code ttbase0@ ( -- n ) psh tos,sp mrc p15,0,tos,cr2,cr0,0 c; code ttbase1@ ( -- n ) psh tos,sp mrc p15,0,tos,cr2,cr1,0 c; @@ -20,6 +21,7 @@
code control! ( n -- ) mcr p15,0,tos,cr1,cr0,0 pop tos,sp c; code aux-control! ( n -- ) mcr p15,0,tos,cr1,cr0,1 pop tos,sp c; +code coprocessor-access! ( n -- ) mcr p15,0,tos,cr1,cr0,2 pop tos,sp c; code ttbase! ( n -- ) mcr p15,0,tos,cr2,cr0,0 pop tos,sp c; code ttbase0! ( n -- ) mcr p15,0,tos,cr2,cr0,0 pop tos,sp c; code ttbase1! ( n -- ) mcr p15,0,tos,cr2,cr1,0 pop tos,sp c;
