Author: wmb Date: 2008-09-12 02:48:18 +0200 (Fri, 12 Sep 2008) New Revision: 931
Modified: dev/olpc/touchpad/touchpad.fth Log: OLPC touchpad selftest - added support for standard mouse mode for use with Synaptics touchpad.
Modified: dev/olpc/touchpad/touchpad.fth =================================================================== --- dev/olpc/touchpad/touchpad.fth 2008-09-11 08:57:08 UTC (rev 930) +++ dev/olpc/touchpad/touchpad.fth 2008-09-12 00:48:18 UTC (rev 931) @@ -19,6 +19,25 @@ ;
+h# f800.f800 constant red +h# 07e0.07e0 constant green +h# 001f.001f constant blue +h# ffe0.ffe0 constant yellow +h# f81f.f81f constant magenta +h# 07ff.07ff constant cyan +h# ffff.ffff constant white +h# 0000.0000 constant black + +variable pixcolor + +h# 4 value y-offset +0 value fbadr +0 value maxx +0 value maxy +0 value /line +2 value /pixel + + \ This program depends on the following routines from the \ existing Open Firmware mouse driver:
@@ -70,16 +89,16 @@ \ "identify" command; the response (for a mouse-like device) is 0x00 : alps-prefix ( -- ) 3 0 do h# f2 read1 drop loop ;
-variable mode +variable mode \ 0 - unknown 1 - GS 2 - PT 3 - mouse
\ Ref: 5.2.10 (3) of Hybrid-GP2B-T-1.pdf : gs-only ( -- ) - mode @ 1 = if exit then + mode @ dup 1 = swap 3 = or if exit then alps-prefix mouse1:1 \ f2 f2 f2 e6 1 mode ! ; : pt-only ( -- ) - mode @ 2 = if exit then + mode @ dup 2 = swap 3 = or if exit then alps-prefix mouse2:1 \ f2 f2 f2 e7 2 mode ! ; @@ -88,7 +107,14 @@ \ : simultaneous-mode ( -- ) alps-prefix 2 set-resolution ;
\ Put the device into advanced mode and enable it -: start ( -- ) 0 mode ! setup advanced-mode stream-on ; +: start ( -- ) + setup + olpc-touchpad? if + 0 mode ! advanced-mode stream-on + else + remote-mode 3 mode ! + then +;
\ I have been unable to get this to work. The response is always \ 64 0 <something>, which doesn't agree with the spec. @@ -237,7 +263,7 @@ h# ff of decode-gs true exit endof \ h# eb of decode-simultaneous exit endof h# aa of - 0 d# 28 at-xy red-screen white-letters + 0 d# 26 at-xy red-screen white-letters ." Unexpected touchpad reset" white-screen black-letters cr @@ -256,10 +282,30 @@ again ;
+variable mouse-x +variable mouse-y + +: clipx ( delta -- x ) mouse-x @ + 0 max maxx min dup mouse-x ! ; +: clipy ( delta -- y ) mouse-y @ + 0 max maxy min dup mouse-y ! ; + \ Try to receive a GS-format packet. If one arrives within \ 20 milliseconds, return true and the decoded information. \ Otherwise return false. : pad? ( -- false | x y z tap? true ) + mode @ 3 = if + poll-event if ( dx dy buttons ) + >r ( dx dy ) + swap clipx swap negate clipy 0 ( x y z ) + 0 r@ 1 and or ( x y z tap ) + r> 4 and 0<> 2 and or ( x y z tap' ) + 8 or ( x y z tap' ) + true + else + false + then + exit + then + poll-touchpad 0= if false exit then
gx @ gy @ gz @ taps @ 2 lshift switches @ or true @@ -295,31 +341,13 @@ key? until ;
-h# f800.f800 constant red -h# 07e0.07e0 constant green -h# 001f.001f constant blue -h# ffe0.ffe0 constant yellow -h# f81f.f81f constant magenta -h# 07ff.07ff constant cyan -h# ffff.ffff constant white -h# 0000.0000 constant black - -variable pixcolor - -h# 4 value y-offset -0 value fbadr -0 value maxx -0 value maxy -0 value /line -2 value /pixel - : button ( color x -- ) maxy d# 50 - d# 200 d# 30 " fill-rectangle" $call-screen ; : background ( -- ) fbadr maxy 2+ /line * erase - 0 d# 30 at-xy ." Touchpad test. Both buttons clears screen. Type a key to exit" cr - 0 d# 20 at-xy ." Pressure: " + 0 d# 27 at-xy ." Touchpad test. Both buttons clears screen. Type a key to exit" cr + mode @ 3 <> if 0 d# 20 at-xy ." Pressure: " then ; : track-init ( -- ) screen-ih package( @@ -330,7 +358,13 @@
: show-up ( x y z -- ) 3drop d# 10 d# 20 at-xy ." UP " ;
-: show-pressure ( -- ) push-decimal d# 10 d# 20 at-xy 3 u.r pop-base ; +: show-pressure ( z -- ) + mode @ 3 = if + drop + else + push-decimal d# 10 d# 20 at-xy 3 u.r pop-base + then +;
: dot ( x y -- ) y-offset + maxy min /line * ( x line-adr )
