Author: wmb Date: Thu Nov 25 03:40:12 2010 New Revision: 2039 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2039
Log: OLPC XO-1.75 boardrev.fth - initial revision
Added: cpu/arm/olpc/1.75/boardrev.fth
Added: cpu/arm/olpc/1.75/boardrev.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/1.75/boardrev.fth Thu Nov 25 03:40:12 2010 (r2039) @@ -0,0 +1,47 @@ +purpose: Determine the board revision based on hardware and EC info +\ See license at end of file + +0 value board-revision + +\ Constructs a string like "B4" or "preB4" or "postB4" +: model-name$ ( -- model$ ) + board-revision h# 10 /mod ( minor major ) + swap dup 8 = if ( major minor ) + drop " " ( major prefix$ ) + else ( major minor ) + 8 < if " pre" else " post" then ( major prefix$ ) + then ( major prefix$ ) + push-hex + rot <# u# u# u# drop hold$ 0 u#> ( adr len ) + pop-base + 2dup + 2- 2 upper ( model$ ) \ Upper case for base model +; + +stand-init: board revision + ['] board-id@ catch if 0 then + dup if h# 10 * 8 + then to board-revision +; + +\ LICENSE_BEGIN +\ Copyright (c) 2007 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
