Author: wmb Date: Fri Jun 10 18:17:53 2011 New Revision: 2257 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2257
Log: OLPC XO-1.75 - slightly cleaner code in memory test.
Modified: cpu/arm/olpc/1.75/probemem.fth
Modified: cpu/arm/olpc/1.75/probemem.fth ============================================================================== --- cpu/arm/olpc/1.75/probemem.fth Wed Jun 8 02:56:48 2011 (r2256) +++ cpu/arm/olpc/1.75/probemem.fth Fri Jun 10 18:17:53 2011 (r2257) @@ -94,8 +94,8 @@ then ( adr len )
begin dup while ( adr len ) - decode-int >r decode-int ( adr len this-len r: this-padr ) - r> swap test-mem ( adr len ) + 2 decode-ints swap ( adr len this-len r: this-padr ) + test-mem ( adr len ) mem-fail? if ( adr len ) 2drop true exit ( -- error ) then ( adr len )
