Author: wmb Date: 2009-08-28 22:09:23 +0200 (Fri, 28 Aug 2009) New Revision: 1335
Modified: cpu/x86/pc/olpc/via/devices.fth Log: Via - implemented ignore-power-button .
Modified: cpu/x86/pc/olpc/via/devices.fth =================================================================== --- cpu/x86/pc/olpc/via/devices.fth 2009-08-28 20:08:38 UTC (rev 1334) +++ cpu/x86/pc/olpc/via/devices.fth 2009-08-28 20:09:23 UTC (rev 1335) @@ -213,7 +213,17 @@ fload ${BP}/dev/olpc/spiflash/spiif.fth \ Generic low-level SPI bus access fload ${BP}/dev/olpc/spiflash/spiflash.fth \ SPI FLASH programming fload ${BP}/dev/olpc/kb3700/ecspi.fth \ EC chip SPI FLASH access -.( XXX Implement ignore-power-button) cr : ignore-power-button ( -- ) ; + +\ ignore-power-button is unnecessary on XO-1.5 because the PWR_BUT_OUT# signal +\ is driven by the EC. If the EC is turned off for SPI FLASH writing, it won't +\ assert PWR_BUT_OUT# . When the EC is on, it will "pull the plug" on the CPU +\ after the power button has been held down for several seconds, regardless of +\ what the CPU is doing. So the following implementation of ignore-power-button +\ is mostly pointless in the system context. It does prevent the CPU from +\ shutting down of its own accord, but the EC override pretty much masks that. + +: ignore-power-button ( -- ) h# 889b config-b@ 2 or h# 889b config-b! ; + fload ${BP}/dev/olpc/kb3700/ecio.fth \ I/O space access to EC chip fload ${BP}/dev/via/spi/spi.fth \ Driver for Via SPI controller fload ${BP}/dev/via/spi/bbspi.fth \ Tethered SPI FLASH programming
