Author: wmb Date: Fri Oct 8 09:51:35 2010 New Revision: 1971 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1971
Log: OLPC XO-1.75 - added spicmd.fth .
Added: dev/olpc/kb3700/spicmd.fth
Added: dev/olpc/kb3700/spicmd.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ dev/olpc/kb3700/spicmd.fth Fri Oct 8 09:51:35 2010 (r1971) @@ -0,0 +1,260 @@ +\ See license at end of file +purpose: Host to EC SPI protocol + +\ See http://wiki.laptop.org/go/XO_1.75_HOST_to_EC_Protocol + +\ Interface from pckbd.fth to i8042.fth: +\ set-port ( port# -- ) \ Selects keyboard (port#=0) or mouse (port#=1) +\ get-data ( -- data | -1 ) \ Returns a keyboard or mouse byte, or -1 if none after one second +\ get-data? ( -- false | data true ) \ Non-blocking version of get-data +\ clear-out-buf ( -- ) \ Drains pending data, waiting until 120 ms elapses with no data. Built from get-data? +\ put-get-data ( cmd -- data | -1 ) \ Sends cmd and waits for one response byte +\ Used only by "echo?", which is not called on OLPC. +\ put-data ( data -- ) \ Sends a byte to the keyboard or mouse +\ Used only by "cmd". "cmd" is used by set-scan-set, default-disable-kbd, enable-scan, set-leds, toggle-leds, +\ kbd-reset, (obsolete) olpc-set-ec-keymap. set-scan-set is used only by commented-out code guarded by +\ the non-defined ifdef "fix-keyboard". default-disable-kbd is called only by get-initial-state (NC on OLPC). +\ enable-scan is NC on OLPC. set-leds is called by toggle-leds with is called when you press numlock or +\ scrolllock or capslock, none of which the OLPC keyboard has. +\ enable-intf ( -- ) \ Sends "ae" to the keyboard controller (not the keyboard). Not called on OLPC with current FW. +\ test-lines ( -- error? ) \ Tests the keyboard clock and data lines. Not called on OLPC. + +0 0 " d4037000" " /" begin-package \ EC-SPI interface using SSP3 + +headerless + +" ec-spi" device-name + +0 0 encode-bytes + " olpc,ec-spi" encode-string encode+ +" compatible" property + +my-address my-space h# 1000 encode-reg +" reg" property + +1 " #address-cells" integer-property +0 " #size-cells" integer-property + +3 /n* buffer: port-data +: init-queue ( -- ) port-data 3 na+ bounds ?do -1 i ! /n +loop ; +: enque ( data port# -- ) + port-data swap na+ ! ( data adr ) +; +: deque? ( port# -- false | data true ) + port-data swap na+ ( adr ) + dup @ ( adr data ) + dup -1 = if ( adr data ) + 2drop false ( false ) + else ( adr data ) + -1 rot ! ( data ) + true ( data true ) + then +; + +0 value ssp-base +: ssp-sscr0 ( -- adr ) ssp-base ; +: ssp-sscr1 ( -- adr ) ssp-base la1+ ; +: ssp-sssr ( -- adr ) ssp-base 2 la+ ; +: ssp-ssdr ( -- adr ) ssp-base 4 la+ ; + +: init-ssp-in-slave-mode ( -- ) + 7 h# d4015058 l! 3 h# d4015058 l! \ Enable clock to SSP3 + h# 07 ssp-sscr0 rl! \ 8-bit data, SPI normal mode + h# 1380.0000 ssp-sscr1 rl! \ SCFR=1, slave mode, rx w/o tx + \ The enable bit must be set last, after all configuration is done + h# 87 ssp-sscr0 rl! \ Enable, 8-bit data, SPI normal mode +; +: set-ssp-receive-w/o-transmit ( -- ) + ssp-sscr1 rl@ h# 0080.0000 or ssp-sscr1 rl! +; +: clr-ssp-receive-w/o-transmit ( -- ) + ssp-sscr1 rl@ h# 0080.0000 invert and ssp-sscr1 rl! +; +0 value ssp-rx-threshold +: set-ssp-fifo-threshold ( n -- ) to ssp-rx-threshold ; +\ tx fifo trigger threshold? + +: .ssr ssp-sssr rl@ . ; +: ssp-ready? ( -- flag ) + ssp-sssr rl@ d# 12 rshift h# f and ssp-rx-threshold = +; + +: init-ec-spi-gpios ( -- ) + d# 78 gpio-dir-out + d# 79 gpio-dir-out +; +: clr-cmd ( -- ) d# 78 gpio-clr ; +: set-cmd ( -- ) d# 78 gpio-set ; +: clr-ack ( -- ) d# 79 gpio-clr ; +: set-ack ( -- ) d# 79 gpio-set ; +: pulse-ack ( -- ) clr-ack set-ack ; + +0 value ec-spi-cmd-done \ 0 - still waiting, 1 - successful send, 2 - timeout + +6 buffer: ec-cmdbuf +d# 16 buffer: ec-respbuf +: expected-response-length ( -- n ) ec-cmdbuf 1+ c@ h# f and ; + +: write-cmd-to-ssp-fifo ( -- ) + 6 0 do + ec-cmdbuf i + c@ ssp-ssdr rl! + loop +; + +0 value ec-cmd-time-limit +: ec-cmd-timeout? ( -- flag ) + ec-cmd-time-limit 0= if false exit then + get-msecs ec-cmd-time-limit - 0>= +; +: cancel-cmd-timeout ( -- ) 0 to ec-cmd-time-limit ; +: set-cmd-timeout ( -- ) + get-msecs d# 1000 + to ec-cmd-time-limit + ec-cmd-time-limit 0= if 1 to ec-cmd-time-limit then \ Avoid reserved value +; + +defer ec-spi-state ' noop to ec-spi-state + +defer ec-spi-upstream +: ec-spi-response ( -- ) + cancel-cmd-timeout + expected-response-length 0 ?do + ssp-ssdr rl@ ec-respbuf i + c! + loop + 1 to ec-spi-cmd-done + 2 set-ssp-fifo-threshold + clr-cmd + ['] ec-spi-upstream to ec-spi-state +; +: ec-spi-switched ( -- ) + set-ssp-receive-w/o-transmit + expected-response-length if + expected-response-length set-ssp-fifo-threshold + ['] ec-spi-response to ec-spi-state + else + ec-spi-response + then +; +: (ec-spi-upstream) ( -- ) + ssp-ssdr rl@ ssp-ssdr rl@ ( channel# data ) + over 3 = if \ Switched ( channel# data ) + 2drop ( ) + write-cmd-to-ssp-fifo ( ) + clr-ssp-receive-w/o-transmit ( ) + ['] ec-spi-switched to ec-spi-state ( ) + else ( channel# data ) + swap enque ( ) + then +; +' (ec-spi-upstream) to ec-spi-upstream +: init-ec-spi ( -- ) + init-ec-spi-gpios + init-ssp-in-slave-mode + set-ssp-receive-w/o-transmit + clr-cmd + set-ack + ['] ec-spi-upstream to ec-spi-state +; + +: ec-spi-handle-message ( -- ) + ec-spi-state + pulse-ack +; +: poll-ec-spi ( -- ) + ssp-ready? if + exit + then + ec-cmd-timeout? if + clr-cmd + cancel-cmd-timeout + 2 to ec-spi-cmd-done \ Timeout + ['] ec-spi-upstream to ec-spi-state + exit + then +; + +: ec-command ( [ args ] #args #results cmd-code -- [ results ] error? ) + ec-cmdbuf 6 erase ( [ args ] #args #results cmd-code ) + ec-cmdbuf c! ( [ args ] #args #results ) + over 4 lshift or ( [ args ] #args #args|#results ) + ec-cmdbuf 1+ c! ( [ args ] #args ) + dup 4 > abort" Too many EC command arguments" + 0 ?do ( ... arg ) + ec-cmdbuf 2+ i + c! ( ... ) + loop ( ) + + set-cmd-timeout + set-cmd + + 0 to ec-spi-cmd-done + begin + poll-ec-spi + ec-spi-cmd-done + until + + ec-spi-cmd-done 2 = if true exit then + + ec-cmdbuf 1+ c@ 0 ?do \ XXX maybe this loop should go backwards? + ec-respbuf i + c@ + loop + false +; + +0 instance value port# +: set-port ( port# -- ) to port# ; +: put-data ( byte -- ) port# 2 0 d# 99 ec-command ; \ XXX +: get-data? ( -- false | data true ) + port# deque? ( false | data true ) + poll-ec-spi +; +: get-data ( -- data | -1 ) \ Wait for data from our device + d# 1000 0 do + get-data? if unloop exit then ( data ) + 1 ms + loop + true \ abort" Timeout waiting for data from device" +; +: put-get-data ( cmd -- data | -1 ) put-data get-data ; +\ Wait until the device stops sending data +: clear-out-buf ( -- ) begin d# 120 ms get-data? while drop repeat ; + +0 value open-count +: open ( -- flag ) + open-count 0= if + my-address my-space h# 1000 " map-in" $call-parent is ssp-base +\ setup-pin-mux + init-ec-spi + then + open-count 1+ to open-count + true +; +: close ( -- ) + open-count 1 = if + ssp-base h# 1000 " map-in" $call-parent 0 is ssp-base + then + open-count 1- 0 max to open-count +; +end-package + +\ LICENSE_BEGIN +\ Copyright (c) 2010 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
