Author: wmb Date: Mon Jan 23 18:56:12 2012 New Revision: 2844 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2844
Log: x86 - increased max-kernel size to 128K so builds won't fail if the kernel size creeps over 64K.
Modified: cpu/x86/target.fth forth/kernel/swapmap.fth
Modified: cpu/x86/target.fth ============================================================================== --- cpu/x86/target.fth Mon Jan 23 18:56:08 2012 (r2843) +++ cpu/x86/target.fth Mon Jan 23 18:56:12 2012 (r2844) @@ -43,7 +43,7 @@ \t16-t /w-t constant /user#-t \t32-t /l-t constant /user#-t
-user-size-t th 10000 + constant max-kernel-t +user-size-t h# 20000 + constant max-kernel-t
\ 32 bit host Forth compiling 32-bit target Forth : l->n-t ; immediate
Modified: forth/kernel/swapmap.fth ============================================================================== --- forth/kernel/swapmap.fth Mon Jan 23 18:56:08 2012 (r2843) +++ forth/kernel/swapmap.fth Mon Jan 23 18:56:12 2012 (r2844) @@ -4,7 +4,7 @@ decimal
only forth also meta also definitions -h# 10000 constant max-kernel-t +h# 20000 constant max-kernel-t
\ The swap map has one bit for every 32-bit word, since we assume \ that relocated longwords must start on a 32-bit boundary
