Author: wmb Date: Tue Jul 31 07:09:03 2012 New Revision: 3102 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3102
Log: OLPC CL4 - Use USB2 PHY driver instead of utmiphy driver for MMP3 chip.
Added: cpu/arm/mmp3/usb2phy.fth Modified: cpu/arm/olpc/build-fw.fth
Added: cpu/arm/mmp3/usb2phy.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/mmp3/usb2phy.fth Tue Jul 31 07:09:03 2012 (r3102) @@ -0,0 +1,74 @@ +\ See license at end of file +purpose: Init USB2 Phy in Marvell SoC + +: +usb2 ( offset -- offset' ) h# 20.7000 + ; + +h# 04 +usb2 constant pll-reg0 +h# 08 +usb2 constant pll-reg1 +h# 10 +usb2 constant tx-reg0 +h# 14 +usb2 constant tx-reg1 +h# 18 +usb2 constant tx-reg2 +h# 20 +usb2 constant rx-reg0 +h# 24 +usb2 constant rx-reg1 +h# 28 +usb2 constant rx-reg2 +\ h# 30 +usb2 constant ana-reg0 +\ h# 34 +usb2 constant ana-reg1 +\ h# 38 +usb2 constant ana-reg2 +\ h# 3c +usb2 constant dig-reg0 +\ h# 40 +usb2 constant dig-reg1 +\ h# 44 +usb2 constant dig-reg2 +\ h# 48 +usb2 constant dig-reg3 +\ h# 4c +usb2 constant test-reg0 +\ h# 50 +usb2 constant test-reg1 +\ h# 54 +usb2 constant test-reg2 +\ h# 58 +usb2 constant charger-reg0 +\ h# 5c +usb2 constant otg-reg0 +\ h# 60 +usb2 constant phy-mono +\ h# 64 +usb2 constant resetve-reg0 +\ h# 78 +usb2 constant icid-reg0 +\ h# 7c +usb2 constant icid-reg1 + +: wait-cal ( spins -- ) + 0 do + pll-reg1 io@ h# 8000 and if unloop exit then \ PLL_READY_MASK + 1 ms + loop + ." PLL calibrate timeout" cr +; + +: init-usb-phy ( -- ) + h# f00 h# 100 +pmua io-clr +\ h# d00 h# 100 +pmua io-set \ Select 26 MHz VCXO clock + h# 200 h# 100 +pmua io-set \ Select crystal + + h# 3fff pll-reg0 io-clr \ REFDIV_MASK_B0 3e00, FBDIV_MASK_B0 01ff + h# 1af0 pll-reg0 io-set \ 0xd << 9 , 0xf0 << 0 + + h# 2773 pll-reg1 io-clr \ PU_PLL_MASK 2000, (LOCK_BYPASS) 1000, ICP_MASK 700, KVCO_MASK 70, CALI12_MASK 3 + h# 3333 pll-reg1 io-set \ 1 1 3 3 3 + + h# 0700 tx-reg0 io-clr \ TX_IMPCAL_VTH_MASK 0700 + h# 0200 tx-reg0 io-set \ 2 + + h# 037f tx-reg1 io-clr \ TX_VDD12_MASK 300 , TX_AMP_MASK 70, TX_CK60_PHSEL_MASK f + h# 0344 tx-reg1 io-set \ 3 4 4 + + h# 0c00 tx-reg2 io-clr \ TX_DRV_SLEWRATE_MASK c00 + h# 0800 tx-reg2 io-set \ 2 << 10 + + h# 00f0 rx-reg0 io-clr \ RX_SQ_THRESH_MASK 00f0 + h# 00a0 rx-reg0 io-set \ a + + h# 0008 rx-reg1 io-set \ 1 << OTG_PU_OTG_SHIFT (3) + + \ Calibrate PHY + d# 200 us + h# 0004 pll-reg1 io-set \ 1 << PLL_VCOCAL_START_SHIFT (2) + d# 400 us + h# 2000 tx-reg0 io-set \ 1 << TX_RCAL_START_SHIFT (13) + d# 40 us + h# 2000 tx-reg0 io-clr \ 1 << TX_RCAL_START_SHIFT (13) + d# 400 us + + d# 100 wait-cal +;
Modified: cpu/arm/olpc/build-fw.fth ============================================================================== --- cpu/arm/olpc/build-fw.fth Tue Jul 31 07:03:38 2012 (r3101) +++ cpu/arm/olpc/build-fw.fth Tue Jul 31 07:09:03 2012 (r3102) @@ -293,7 +293,11 @@ then ;
+[ifdef] mmp3 +fload ${BP}/cpu/arm/mmp3/usb2phy.fth +[else] fload ${BP}/cpu/arm/marvell/utmiphy.fth +[then] fload ${BP}/cpu/arm/olpc/usb.fth
fload ${BP}/dev/olpc/mmp2camera/loadpkg.fth
