Author: wmb Date: 2009-09-05 11:03:28 +0200 (Sat, 05 Sep 2009) New Revision: 1348
Modified: cpu/x86/pc/olpc/via/boardrev.fth Log: Via - cache the board ID value in CMOS as the raw EC code, not the derived ID, thus making the assembly language startup code easier.
Modified: cpu/x86/pc/olpc/via/boardrev.fth =================================================================== --- cpu/x86/pc/olpc/via/boardrev.fth 2009-09-05 09:02:27 UTC (rev 1347) +++ cpu/x86/pc/olpc/via/boardrev.fth 2009-09-05 09:03:28 UTC (rev 1348) @@ -27,23 +27,13 @@ : stand-init-io stand-init-io
-[ifndef] notdef - ['] board-id@ catch if 0 then case - 0 of 0 endof \ EC broken - ( board-id ) dup h# 10 * 8 + swap \ E.g. b3 -> b38 - endcase -[else] - \ wait-ib-empty - \ autowack-off - 0 h# 68 pc! - h# d08 -[then] + ['] board-id@ catch if 0 then
- to board-revision - \ Cache the board revision in CMOS RAM so the early startup code \ can get it without having to wait for the EC. - board-revision dup h# 82 cmos! invert h# 83 cmos! + dup dup h# 82 cmos! invert h# 83 cmos! ( id ) + + dup if h# 10 * 8 + then to board-revision ; warning !
