Author: wmb Date: 2009-10-06 13:07:53 +0200 (Tue, 06 Oct 2009) New Revision: 1396
Modified: cpu/x86/pc/olpc/via/startcominit.fth Log: Via - poll the PSON gating state bit instead of using a time delay to determine when CMOS reads will work.
Modified: cpu/x86/pc/olpc/via/startcominit.fth =================================================================== --- cpu/x86/pc/olpc/via/startcominit.fth 2009-10-06 03:28:24 UTC (rev 1395) +++ cpu/x86/pc/olpc/via/startcominit.fth 2009-10-06 11:07:53 UTC (rev 1396) @@ -29,9 +29,6 @@ \ First we check for a cached board ID in CMOS RAM, to avoid the \ possibly time-consuming operation of asking the EC.
- d# 17 0 devfunc - end-table - \ Configure the I/O decoding to enable access to the EC \ Do this outside the if..then so the setup is consistent in all cases d# 17 0 devfunc @@ -55,13 +52,10 @@ 70 fb 82 mreg \ CPU to PCI flow control - CPU to PCI posted write, Enable Delay Transaction end-table
- acpi-io-base 4 + port-rw \ Get APCI Status register - d# 10 # ax shr 7 # ax and 1 # ax cmp <> if \ Type 1 is wakeup from S3 - \ The following applies only to power-up; no delay is needed for wakeup from S3 - \ This delay is empirically necessary before reading CMOS - minimum is 36000 - about 50 ms - \ Before the delay has elapsed, the CMOS RAM returns 0 instead of the stored value. - d# 40000 wait-us - then + \ Wait until RTC PSON Gating is complete. See PG_VX855_VX875_092 page 139 (pdf page 160) + \ This takes about 48 mS in the power-on case, and is almost instantaneous in the + \ resume-from-S3 case due to the clearing of D17F0 Rx81[2] above. + begin 8882 config-rb h# 40 # al and 0<> until
\ As an optimization to avoid long waits for the EC to respond, read the board ID \ that is cached in CMOS RAM.
