Author: wmb Date: Thu Jan 20 01:01:07 2011 New Revision: 2129 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2129
Log: Makefile frobbing - use consistent brace type.
Modified: cpu/x86/Darwin/Makefile cpu/x86/Linux/Makefile
Modified: cpu/x86/Darwin/Makefile ============================================================================== --- cpu/x86/Darwin/Makefile Thu Jan 20 00:40:27 2011 (r2128) +++ cpu/x86/Darwin/Makefile Thu Jan 20 01:01:07 2011 (r2129) @@ -6,8 +6,8 @@ MFLAGS = -m32
OPT = -O -CFLAGS = -g $(MFLAGS) -DTARGET_X86 -LFLAGS = $(MFLAGS) +CFLAGS = -g ${MFLAGS} -DTARGET_X86 +LFLAGS = ${MFLAGS}
# Extra CFLAGS needed by Darwin hosts. GCC doesn't define __unix__ here, # so we must include it ourselves. @@ -49,7 +49,7 @@ # Use x86forth when you need to compile new dictionaries that will # run on x86 systems. forth: ${OBJS} - ${CC} $(MFLAGS) -o $@ ${OBJS} + ${CC} ${MFLAGS} -o $@ ${OBJS} @ln -sf forth x86forth
%.o: ${WRDIR}/%.c @@ -75,7 +75,7 @@ wrapsim.o: ${WRDIR}/wrapper.c ${CC} -c ${ARMCFLAGS} -c $< -o $@
-armsim.trace.o: $(ARMDIR)/armsim.c +armsim.trace.o: ${ARMDIR}/armsim.c ${CC} -c ${ARMCFLAGS} -DTRACE=1 -c $< -o $@
armforth: ${ARMSIMOBJS}
Modified: cpu/x86/Linux/Makefile ============================================================================== --- cpu/x86/Linux/Makefile Thu Jan 20 00:40:27 2011 (r2128) +++ cpu/x86/Linux/Makefile Thu Jan 20 01:01:07 2011 (r2129) @@ -6,8 +6,8 @@ MFLAGS = -m32
# Uncomment these lines to include X windows support to the wrapper # via libxcb. The libxcb development package (headers, etc) must be @@ -44,7 +44,7 @@ @ln -sf forth x86forth
inflate.lo: ${ZIPDIR}/inflate.c - ${CC} -c $(MFLAGS) -Wall -fno-stack-protector -ffreestanding -D_FORTIFY_SOURCE=0 -DNEED_BCOPY -O3 -fpic $< -o $@ + ${CC} -c ${MFLAGS} -Wall -fno-stack-protector -ffreestanding -D_FORTIFY_SOURCE=0 -DNEED_BCOPY -O3 -fpic $< -o $@
inflate.o: inflate.lo ${LD} -melf_i386 -T inflate.ld $< -o $@ @@ -71,14 +71,14 @@ wrapsim.o: ${WRDIR}/wrapper.c ${CC} -c ${ARMCFLAGS} -c $< -o $@
armforth: ${ARMSIMOBJS} - ${CC} ${ARMSIMOBJS} -o $@ + ${CC} ${LFLAGS} ${ARMSIMOBJS} -o $@
armforth.trace: ${ARMTRACEOBJS} - ${CC} ${ARMTRACEOBJS} -o $@ + ${CC} ${LFLAGS} ${ARMTRACEOBJS} -o $@
clean: @rm -f forth x86forth armforth *.o *~ inflate.bin
